Help with Poles for awning
User Info
Quick Forum Search
Who's Online
Weekly Photo
Zoom Details 3
bon echo cg ontario
 Comments: 3
Posted by PopUpPortal
Oct 08, 2008
in This Week's Photo Winner
Checkout My Rig
95 Coleman fleetwood rio grande
Posted by eric hamilton
Yesterday
in Checkout My Rig
Recent Topics
BedWedgies Brand new and made from high-quality cast aluminum, these are the solution to your broken plastic bed rail slider ends.
See fewer ads! Become a free PopUpPortal member. Click here to Register
Author Topic: Help with Poles for awning  (Read 1844 times)
Offline Gilbert
  • Camper, 2nd Class
  • Gender: Male
    • FL [FL]
    • US [USA]
    • View Profile
« on: March 09, 2008, 11:46:16 AM »
HI , I just "discovered that my camper has a awning, but all the poles are missing.
Anyone thare that could take measurements of theyr poles?
Is a 1992 Coleman, Fleetwood Americana Williamsburg and the awning seems to be the OEM.
Edited by - Gilbert on March 09 2008  11:47:06
Offline Digger
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My Pics Website
« Reply #1 on: March 09, 2008, 12:11:57 PM »
Which poles are missing?  There should be poles attached to the awning that swing down bewteen the awning and the ground (vertical poles).  And poles that go under the awning between the outside edge and the camper roof (horizontal poles).
I believe that all the poles are adjustable to account for differing terrain and conditions.  I know Walmart sells some aluminum adjustable tent poles that may do the trick for the vertical poles.
~Cheers~
Ðigger
2004 Fleetwood Westlake - StonyBlue
2002 Econoline E-150
~Cheers~  Ðigger
'04 Fleetwood Westlake (StonyBlue)/'02 Ford E-150
Nites camped: 2007-8, 2008-39, 2009-50 (camped every month), 2010-14, 2011-14
Online buckerbie
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #2 on: March 09, 2008, 01:38:29 PM »
Hi Gilbert -
Is your awning bag a grey color?  I had a factory Coleman awning on my 94 Destiny.  There are 2 poles attached and folded up inside the front awning rail.  These 2 poles have special rubber feet and are ones that go back to the camper roof.  Some other Coleman folks mentioned that they had some loops attached inside the awning bag where the ends of these poles would be supported against the roof.  I never found them in my awning bag.  I also don't have any brackets on the roof for the poles attach.  I read somewhere that these poles were pressure supported against the roof, thus the little rubber feet on the end of poles.
I also had 3 additional ground poles with little plastic points on the top that fit into the holes in the awning rail.  All 5 poles are adjustable in length.
I've seen folks post here with mods and replacement poles using painter's poles from the hardware store.  If your poles need the skinny plastic piece on the top to fit in the holes of the awning rail, I recall someone attaching a screw at one of the replacement pole w/ a screw head large enough to "catch" in the hole.
Offline Gilbert
  • Camper, 2nd Class
  • Gender: Male
    • FL [FL]
    • US [USA]
    • View Profile
« Reply #3 on: March 09, 2008, 04:15:01 PM »
hi, THANKS FOR THE REPLYS, THE ONLY HARDWARE THAT i HAVE ARE THE RAIL AND THE 2 HALF PLOES THAT FOLD IN TO THE RAIL, BUT THOSE ARE TOO SHORT FOR ANYTHING
Offline barb_dave
  • Eagle Camper
  • Gender: Male
    • WI [WI]
    • US [USA]
    • View Profile
« Reply #4 on: March 09, 2008, 07:28:12 PM »
The half poles in the rail extend and the length is held in place by spring tension pins.  I would think you would be able to replace the missing poles by contacting a local camper dealer
I use to have a life but my job ate it.
http://community.webshots.com/user/Barb_Dave
1998 Coleman Mesa
[PU]-1998 Coleman Mesa  [TV]- 97 Plymouth Voyager
[CP] 2013 = 8
Offline Grim54
  • Star Camper
  • Gender: Male
    • MI [MI]
    • US [USA]
    • View Profile
    • Webshots
« Reply #5 on: March 09, 2008, 07:33:15 PM »
When I bought my ntu '95 Coleman Sequoia I found the awning poles locked in the rear bumper of the pup.
Just a thought. They might be there.
Grim
'95 Coleman Sequoia
'02 Chevy Blazer 4x4
http://community.webshots.com/user/Grim1954
Grim '54 [}:)]  Paige '56 [XK]
Sadie  the camping dachshund '06 [DOG]
'00 Trail Lite Bantam Expandable [PU][TV] '02 Dodge Ram 1500 4x4
Offline Gilbert
  • Camper, 2nd Class
  • Gender: Male
    • FL [FL]
    • US [USA]
    • View Profile
« Reply #6 on: March 09, 2008, 08:35:29 PM »
Rear bumper is empty, thanks for the tip anyway.
Offline Digger
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My Pics Website
« Reply #7 on: March 09, 2008, 10:31:25 PM »
It sounds as if the poles that fold into the awning had the extendable part removed.  Are there a series of holes towards the bottom of the 'half-poles'?  That is where the adjustments happened if you had the bottom half of the poles.
Give these PPLMotorHomes - RV Parts Superstore a call and they may be able to help you:  1-800-325-9250
~Cheers~
Ðigger
~Cheers~  Ðigger
Awning Pro-Tech - Protect your awning fabric from the damaging effects of the sun and weather with Awning Pro-Tech. Awning Pro-Tech is the only patented product of its kind on the market.
