User Info
Quick Forum Search
Who's Online
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 20161211 222531
Posted by robenster
Dec 14, 2016
in Checkout My Rig
Recent Topics
So what's a good quiet generator? by FarmerDave
[Today at 05:14:33 AM]
Personal introduction by Joan Pringle
[Today at 04:40:27 AM]
Trailer audio. by Whiteycracker
[Today at 03:35:07 AM]
2017 Kick Off to Summer by Snow
[Today at 03:23:08 AM]
looking to install a sterio what do i need to do ? by Whiteycracker
[Today at 02:59:49 AM]
Hi From KS by WiseFamily
[Today at 01:35:24 AM]
Do you have a campfire? by Haybale
[Today at 01:02:10 AM]
Official 2017 Winter SoCal Rally Carizzo Plains by Haybale
[Today at 12:41:01 AM]
2017 CA Winter Rally Round 2, Red Rock Canyon SP by Haybale
[Today at 12:38:21 AM]
Spongy floor in 85 Coleman by Sharonjh
[Today at 12:21:24 AM]
2017 Quad-State Rally by ChocoChock01
[Today at 12:02:23 AM]
2017 West Coast Total Solar Eclipse Rally by ChocoChock01
[Yesterday at 11:57:50 PM]
Author Topic: Rockwood 1640 ltd  (Read 2881 times)
Offline warrenm
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
Rockwood 1640 ltd
« on: June 26, 2008, 07:26:24 PM »
I have a 2007 Rockwood Freedom 1640 LTD 8ft, just purchased last week. I seem to be having a little trouble with the sink. No water comes out. I flipped the switch on for the pump, nothing. I also tried to drain old water by turning the knob, on the under seat container. No water came out the bottom of trailer or through (grey water outlet?). Also the pump switch makes a churping sound when it's off, stops when on. Help greatly appreciated.
Offline Digger
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My Pics Website
Rockwood 1640 ltd
« Reply #1 on: June 26, 2008, 07:44:53 PM »
Welcome to the Portal Warren!
Let's clarify here....you have a freshwater tank under your dinette seat.  It is full, and doesn't pump through to the sink after you've turned the pump on and opened the faucet.
Sounds like it may be a bad pump, or an empty tank.  Are you sure that the safety cutoff switch is turned off appropriately?  The churping noise when off certainly doesn't sound correct...did someone rewire the pump or the switch at some point?
~Cheers~ igger
'04 Fleetwood Westlake (StonyBlue)/'02 Ford E-150
2008 nights camping: PUP - 13
~Cheers~  igger
Nites camped: 2007-8, 2008-39, 2009-50 (camped every month), 2010-14, 2011-14
Offline warrenm
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
Rockwood 1640 ltd
« Reply #2 on: June 26, 2008, 08:25:31 PM »
Yes, I have a freshwater tank under the dinette that is full.  The water was left there from a previous owner.  I turned the faucet on and the pump, no water in sink.  I then tried to turn knob on tank itself under dinette, opened grey water pipe on outside of trailer.  Water will not drain from tank.
Where is the safety shut off valve located?
It does appear that the pump switch is backward, on is off, etc.
Is the churping a low battery alert?
Thank You
Offline Digger
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My Pics Website
Rockwood 1640 ltd
« Reply #3 on: June 26, 2008, 08:31:56 PM »
Yep, the chirping may be a low battery alert...I'm not sure how Rockwood does things.  The safety cutoff switch may be located under your galley (if it is a folding galley), or sometimes they are located on the top edge of the camper box so the roof depresses the switch when down in the travel position.
Did you try turning the faucet on when the pump was making it's chirping noise?
Have you checked the fuses/breakers in the converter whcih is usually located under the dinette or couch?
~Cheers~ igger
~Cheers~  igger
Offline warrenm
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
Rockwood 1640 ltd
« Reply #4 on: June 26, 2008, 09:04:52 PM »
There is a red button under the galley, I read on this portal that it controlled the lights.  Afraid to press red button. I will have a look at the fuses, but the pump did turn on briefly.  I believe the low battery is causing the trouble.  When I was plugged into shore power though, the water still did not drain from under the dinette.  Is the pump also necessary to drain water using the valve located under the dinette?
Offline Digger
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My Pics Website
Rockwood 1640 ltd
« Reply #5 on: June 26, 2008, 09:20:55 PM »
It shouldn't be necessary for the drain.  The switch under the galley is a safety cutoff switch that should turn off the overhead lights and the water pump (I think) when you place the galley in the travel position.  This is so you don't accidently leave the lights on and burn up the camper.  If your lights work when the galley is up, then that switch isn't the issue.
You may want to disconnect the outlet from the pump to see if water is coming out of the pump when it is on.  If so, then you may have a kink in the line between the pump and the sink.
Is this camper still under warranty?  That may be your easiest solution!
~Cheers~ igger
~Cheers~  igger
Offline warrenm
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
Rockwood 1640 ltd
« Reply #6 on: June 26, 2008, 09:25:41 PM »
Thank you for the suggestions.  I'll see what works.  No warranty, bought the pup used, dirt cheap.
Offline Digger
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My Pics Website
Rockwood 1640 ltd
« Reply #7 on: June 26, 2008, 09:36:49 PM »
Always a good way to get a pup Big Smile
Hopefully another Rocky owner will give you some further insight....
~Cheers~ igger
~Cheers~  igger
Offline warrenm
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
Rockwood 1640 ltd
« Reply #8 on: June 26, 2008, 09:52:51 PM »
WinkThanks again, and congratulations on the moderator promotion.
Offline Gambit...
  • Camper, 1st Class
    • MO [MO]
    • US [USA]
    • View Profile
Rockwood 1640 ltd
« Reply #9 on: June 27, 2008, 05:31:30 PM »
I had this problem with my Rockwood.
I bought it used, the water tank was half-full and the hand pump, the elctric pump nor the drain would work.
City water did work.
Turns out, the tank was full of little plastic shavings from when it was manufactured. They had gotten into EVERYTHING!!! Clogging it all up!
I ran a siphon down into the tank from the filler neck and siphoned all the old, foul smelling water out, removed the tank, all hoses, pump and faucet and cleaned it all out.
I installed a filter screen between the pump and the tank and put it all back together and all is well.
Kim
'95 Rockwood Freedom 1940
'87 Volvo 245
"Give me Yellow Death, Silver Magic and a Blue Tip Wrench and I can fix anything!"
Offline Digger
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My Pics Website
Rockwood 1640 ltd
« Reply #10 on: June 27, 2008, 05:35:50 PM »
Excellent thoughts Kim.  Always good to have the experience around here....
~Cheers~ igger
~Cheers~  igger
Offline warrenm
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
Rockwood 1640 ltd
« Reply #11 on: June 28, 2008, 10:27:41 PM »
I took the PUP out camping yesterday, hooked it up to a 30 amp connection at the campground. The pump and sink started working fine.  The 1640's heater did not work when I bought (how I negotiated dirt cheap price).  I plugged in a 1500 watt heater to the shore power.  Camper stayed warm and toasty.  I am hooked on PUP camping, should have bought one years ago.
