User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
Towing 4 pin wiring by Rusty2192
[Today at 07:53:52 PM]
Outlet anchors ? by Rusty2192
[Today at 07:44:41 PM]
Do you cover your outside stored pup? by Kalinedrive
[Today at 07:24:52 PM]
Good by to Orville and those here by HiFiDave
[Today at 06:54:27 PM]
Porta- cabin no title? by vade11
[Today at 06:47:38 PM]
Roof question pre purchase - Dutchmen by tw12
[Today at 06:31:23 PM]
Considering purchasing 2010 Fleetwood Coleman E-3 by kitphantom
[Today at 06:18:01 PM]
How to upload a photo?? by kitphantom
[Today at 06:15:50 PM]
It begins, lets rebuild the roof..LOTS of pics by BigAdm
[Today at 06:02:53 PM]
GFCI Won't Reset by rccs
[Today at 06:01:55 PM]
replacing the aux shower hose by Snow
[Today at 05:56:01 PM]
PU tail lights and turn signals by arthuruscg
[Today at 05:35:51 PM]
Author Topic: 3-way refrigerator - How to use it  (Read 47441 times)
Offline tnchuck100
  • Star Camper
  • Gender: Male
    • US [USA]
    • View Profile
« on: September 10, 2008, 08:04:20 AM »
There have been many questions about the operation of these refrigerators. I have posted this as a comment on another thread but I thought it warranted its own topic.
It is amazing how many different thoughts are out there about how 3 way refrigerators work. Most seem to be the result of following advice by others rather that actual experience. Here I will mix theory and experience.
First, we will assume the refrigerator is not defective in some way. It should make no difference which heat source is used. It's just heat. Be it one of the 115 watt (110V or 12V) electric heaters or a propane flame. It's just heat.
Second, the refrigerator must be level to operate efficiently. If it is not level the liquid in the system can pool and restrict or even block circulation. Damage to the system can result if operated off level for an extended period of time. While traveling level does not matter because the liquids are "sloshing around" and do not get a chance to pool.
Next, The units do take time to cool when started. The normal rate of cooling is about 3 - 6 degrees per hour. Ambient temperature and having a fan to blow air across the condenser fins will affect this rate. I start the cooling about 18 hours before leaving. Also, the food placed in the refrigerator should be cold already.
Now, when to use which heat source and why.
110V - use this whenever it is available. The thermostat will control the temperature.
12V - use this when traveling. There is no thermostatic control. It is possible to freeze things. If you are traveling less than 6 hours it should not be a problem. If you stop for less than 1 hour you should not have any battery problems. If more than an hour switch to propane.
Propane - use when 110V is not available (dry camping). Normally it should be set to HIGH. Adjusted to MED or LOW if it gets too cold. There is also no thermostatic control in this mode. Contrary to what is generally said there is no "pilot light". It is just a constant flame. The refrigerator uses very little propane.
You may have seen the sticker that tells you to use only one heat source at a time. The system has been designed to use a specific amount of heat to produce the heat exchange cycle. Increasing the amount of heat will not lower the refrigerator temperature. In the case of the propane you are decreasing the amount of heat (MED and LOW) to increase the refrigerator temperature if needed since there is no thermostat control.
To monitor the temperature in the refrigerator I use a wireless indoor/outdoor electronic thermometer. (Acurite, About $10-$15 at Wal-Mart)
It hope this clears up some mis-information on the operation of these refrigerators.
Chuck & Mary - Sparta, Tennessee
'00 Dodge Dakota Tow Vehicle '08 Flagstaff Micro Lite 18FBR
'03 Harley Davidson Ultra Classic Bicycle '04 Timeout PopUp
Chuck - Sparta, Tennessee
'07 Chevy Suburban '12 Jayco JayFlight 22FB
Offline LynnAllen02
  • Eagle Camper
  • Gender: Female
    • NY [NY]
    • US [USA]
    • View Profile
« Reply #1 on: September 10, 2008, 08:20:25 AM »
Chuck:
You ought to turn this into and submit as an article!
Lynn
2006 Pony 283*2008 Liberty* Reserved 2008: 16 days Camped: 11 nights
2007 Palomino Pony/2010 Jeep Liberty
2013 Reserved: 12 Camped: 0
Offline theseus
  • Eagle Camper
  • Gender: Male
    • OH [OH]
    • US [USA]
    • View Profile
« Reply #2 on: September 10, 2008, 09:27:03 AM »
Nicely stated! I agree with Lynn - This should be a sticky topic in the refrigerator section...
______________
2004 Expedition & 2000 Palomino Mustang SL-SG-FT
http://www.thecampingchild.com
Edited by - theseus on September 10 2008  09:27:21
Bruce        ______________
2004 Expedition & 1998 Coleman Bayside
Previous PUPs owned: 66 Nimrod Capri, 86 Coleman Columbia, 99 Palomino Mustang SL-SG-FT
Offline Luv2ridebikes
  • Eagle Camper
  • Gender: Male
    • IN [IN]
    • US [USA]
    • View Profile
« Reply #3 on: September 10, 2008, 01:47:42 PM »
Thanks Chuck - I remember reading your post on this subject and it certainly improved my understanding of the topic.
Steve & Deb (boys are grown & gone)
Aspen & Riley (the 4 legged children)
05 Fleetwood Sequoia & lot's of bikes! BicycleBicycle
Steve and Deb
Gus - our four legged offspring
2005 Sequoia towed by an 04 Ext Trailblazer and lots of bikes
Offline jushavnfun
  • Camper, 2nd Class
  • Gender: Male
    • MI [MI]
    • US [USA]
    • View Profile
    • Patriot Guard Riders of Michigan
« Reply #4 on: September 13, 2008, 11:51:18 PM »
Chuck,
 Thanks...This is my next project along with the heater to be tackled on the camper rebuild/overhaul. I have the repair manual from Starcraft, but it covers how to R&R, not diagnose and service.
Marty & Elizabeth
Proud owners of our vintage PUP, "Riff Raff"
To ALL who have, or are serving... Thank You and Welcome Home!
Greater love has no one than this, that he lay down his life for his friends.   John 15:13
Honored to "Stand the Line" for our Fallen.
Offline Retired Alex
  • Eagle Camper
  • Gender: Male
    • ON [ON]
    • CA [CAN]
    • View Profile
    • My Pictures
« Reply #5 on: September 14, 2008, 12:00:26 AM »
For a detailed description of how RV fridges work check this site. http://www.rvmobile.com/tech/Trouble/cooldoc.htm
For detailed testing procedures on various units go here http://www.gasrefrigeration.net/dometic_manuals.htm
The link goes to Dometic but there is a link at teh top to Norcold.
Alex & Mary Burnett
06 Trail Cruiser 26QBS, 2006 F-150 XLT
http://users.xplornet.com/~burnetta
Edited by - Retired Alex on September 14 2008  00:05:45
Alex & Mary Burnett
Hooch (Boxer)
2011 F150 Eco Boost towing a 2011 Onyx 25RB via an Equal-i-Zer 4PSC
Offline Fiveofun
  • Camper, 2nd Class
    • NV [NV]
    • US [USA]
    • View Profile
« Reply #6 on: March 17, 2009, 07:55:10 PM »
So from this post, I take it if the PUP is pluged into an outlet at home, the fridge will cool down? I just want to verify.
2005 Jeep Grand Cherokee
Looking for some kind of off road PUP
Offline tnchuck100
  • Star Camper
  • Gender: Male
    • US [USA]
    • View Profile
« Reply #7 on: March 17, 2009, 08:47:35 PM »
Yes. As long as the 110V switch on the refrigerator is turned on (the green one).
'02 Chevy Suburban Tow Vehicle '08 Flagstaff Micro Lite 18FBR
Offline Fiveofun
  • Camper, 2nd Class
    • NV [NV]
    • US [USA]
    • View Profile
« Reply #8 on: March 17, 2009, 09:31:17 PM »
Thanks for the reply. Sorry, can I clarify one more thing, this will work with the PUP closed, correct?
Offline tnchuck100
  • Star Camper
  • Gender: Male
    • US [USA]
    • View Profile
« Reply #9 on: March 17, 2009, 09:39:30 PM »
Yes. The refrigerator will operate while the PUP is open or closed. Just be sure it is pretty close to level.
Offline MovingRightAlong
  • Camper, 1st Class
  • Gender: Male
    • NH [NH]
    • US [USA]
    • View Profile
Re: 3-way refrigerator - How to use it
« Reply #10 on: June 05, 2009, 04:35:56 PM »
This may be a foolish question, but are you talking about the switch in the back that allows you to switch from DC/AC/Propane?
Is there another switch I should be looking for?
« Last Edit: June 30, 2009, 09:17:08 AM by pgordemer »
2005 Sienna/96 Coleman Cheyenne
Dave, Stacey, 2 Boys (6 and 3), 1 Dog
Offline LynnAllen02
  • Eagle Camper
  • Gender: Female
    • NY [NY]
    • US [USA]
    • View Profile
« Reply #11 on: June 06, 2009, 07:10:25 PM »
Nope that's the switch.
We pop up, close the frig door, plug into our house current the two nights before we leave, pop pup down.
Next night pop up, load frig with cold food, and frozen meals, forzen waters.  Pop down, keep connected to house current.
AM when we leave, disconnect from house current, turn off frig, do not forget to close frig vent (don't want to say why I know you should not forget this) drive 6-7 hours, we do not use battery power, I save battery for the campground.
Popup, turn on propane switch after leveling pup.  We monitor temp throughout he trip, day time when its hot it gets warm, need high, night time when it gets cool, need medium!  As my frozen stuff thaws and I use things up, I replace with things from cooler to keep it full, works better
Love my frig
Lynn
Offline NHDalton
  • Camper, 1st Class
  • Gender: Male
    • NH [NH]
    • US [USA]
    • View Profile
    • Jim's Photo Darkroom
« Reply #12 on: June 08, 2009, 08:34:12 PM »
Something crosses your mind and you come to the Pop Up Portal to find your answer.  Thank you Chuck.  Appreciate it.
I am going boondocking for 4 days coming up and have other such trips planned after that too.  This information helps.
1999 Coleman/Fleetwood Sun Valley [PUC][TV] 2008 Ford F-150
[CAM] Jim: 1963 [CP] DW: (1972) & Astro [DOG] (DP)
  • Camper, 1st Class
  • Gender: Male
    • NH [NH]
    • US [USA]
    • View Profile
« Reply #13 on: June 08, 2009, 09:51:06 PM »
Another dumb question, I had my fridge plugged in for two days.  The metal shelves were cold so it was definitely working, but it wasn't as cold as I expected, while it seemed to work better at the campground last summer.
I had it plugged in through a basic extension cord to my house, will it work better when I get a full 30V running?
Offline suprz
  • Eagle Camper
    • RI [RI]
    • US [USA]
    • View Profile
« Reply #14 on: June 09, 2009, 08:42:15 AM »
no, it wont make a difference if you were plugged into a 30 Amp service, it is still 120 volts.  these fridges are only good to around a 40 degree difference between the ambient outside temperature and the inside temp of the fridge, Also, something to remember is that the sun hitting the side of the PUP may also have a bearing on the temp and the cooling effeciency of the fridge. The venting on the fridges for these PUPs if poor to say the least.  that is why so many of us have put on baffles and cooling fans in the space where the vents are to promote good venting of the hot exhaust from the cooling fins behind the fridge.  you can do a search on this topic and find a lot of threads about them
proud father of a U.S. Marine
2006 Jayco Greyhawk 31SS. "Dreamcatcher"
2004 Jeep Grand Chreokee Special Edition 4X4
