User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
I'm a new member! by eoleson1
[Today at 03:02:06 PM]
Planning for '17 by kitphantom
[Today at 02:54:20 PM]
Need suggestions on an Georgia --> Grand Canyon North Rim, western US trip by kitphantom
[Today at 02:49:00 PM]
Opinions on items for NTU hybrid camper by Genie2010
[Today at 02:48:15 PM]
2017 Connecticut Rally by Debfmaine
[Today at 02:41:12 PM]
2017 - Wisconsin June Rally by golfnate07
[Today at 02:34:56 PM]
How much does it cost to tow a pop up? by love2travel
[Today at 02:30:13 PM]
So, what did you do for your camper, January 2017 by Firehawk068
[Today at 02:16:52 PM]
Generators by dracarys
[Today at 02:12:33 PM]
Maintenance suggestions on a NTU pop-up by MNTCamper
[Today at 01:58:22 PM]
Air Conditioning Mod? by tdiller
[Today at 01:53:56 PM]
Trailer audio. by MNTCamper
[Today at 01:53:34 PM]
Author Topic: 01 Coleman roof seal has gaps  (Read 2465 times)
Offline jthomas124169
  • Star Camper
  • Gender: Female
    • MI [MI]
    • US [USA]
    • View Profile
    • http://community.webshots.com/user/jthomas124169
« on: December 01, 2008, 11:00:57 AM »
My 01 Coleman roof seal is not sealing all the way around and I need to come up with a quick fix to last me through the winter as I keep the pup stored outside.
I was thinking of using some adhesive backed weather stripping that is used for the bottom of doors.
Julie(58) DD(81) 2 DGS(98)&(02) DF(42)
 I reject your reality and substitute it for my own.
Julie '58 Jeff '59
and if your looking for heaven, its north of da bridge
Offline Storm Trooper
  • Global Moderator
  • Eagle Camper
  • Gender: Male
    • CT [CT]
    • US [USA]
    • View Profile
« Reply #1 on: December 01, 2008, 11:30:23 AM »
Julie,
Is the seal still in one piece or has it separated? It isn't clear on your pics.
If it is still in one piece, I would try tightening the latches down a bit by turning the latch screw down and relatching until the seal is compressed.
If it has separated and you are the original owner, you maybe able to get your fleetwood/coleman dealer to replace it.
Lou
17 days booked 09, Camping49 nights camped in 08
07 Fleetwood Avalon (Great White)
03 Ford Expedition (Green Monstah) GO Red SOX!!!
Lou & Jan and Ewok K9 (Kyleigh Wyote) [put&hy]
2011 Keystone Passport 235EXP AKA "The Imperial Palace"
2010 Ford F150XLT Supercab AKA "Jade's Fire"
  • Star Camper
  • Gender: Female
    • MI [MI]
    • US [USA]
    • View Profile
« Reply #2 on: December 01, 2008, 01:05:19 PM »
The seal is all in one piece. It seals well along the sides, its the 2 ends (front and back) where it won't seal. The seal is attached to the roof of the pup and is not meeting the bottom of the pup on the 2 ends toward the middle.
Julie '58 Jeff '59
  • Global Moderator
  • Eagle Camper
  • Gender: Male
    • CT [CT]
    • US [USA]
    • View Profile
« Reply #3 on: December 01, 2008, 01:29:36 PM »
Julie,
Wow, I really thought it would be a separation of the seal.
Another thought, when the ABS roofs go bad, they usually push out to the sides and extend beyond the side of the trailer. Is the roof bowed at all in the middle of the trailer? IE, are the front end and rear end higher than the middle of the roof?
I don't think this is your problem, just checking.
Also, just asking to make sure nothing is on the inside of the trailer pushing up the roof in the middle? If this hasn't happened before, maybe your canvas is bunched up in the middle?
If none of the above is true. I would try unlatching the roof latches and screwing the latch in a one turn at a time and gently relatching to see if that brings it down.
Lou
  • Star Camper
  • Gender: Female
    • MI [MI]
    • US [USA]
    • View Profile
« Reply #4 on: December 01, 2008, 02:26:41 PM »
The roof is not bowed. I did just close it up for the year and had a hard time even getting it to latch, I think in part because the canvas was so stiff. I had to let it sit for a day for it to compress down before I could latch it. I was afraid to unlatch it and screw the latch in for fear it might break or damage something.
Julie '58 Jeff '59
  • Global Moderator
  • Eagle Camper
  • Gender: Male
    • CT [CT]
    • US [USA]
    • View Profile
« Reply #5 on: December 01, 2008, 02:52:29 PM »
Julie,
If the weather warms a bit, I would open it up and rearrange the canvas to make sure there isn't something else pressing up inside the roof. That seems to be the only thing that makes sense if it was latching correctly during the year. Or set it up and run your heater long enough to warm the canvas, then put it down quickly.
I wish I could be of more help.
And btw, I noticed all the leaves in the area between the body and the front storage compartment. You might want to keep that area clean, my prior coleman (99 Niagara) had the same setup and whenever leaves collected there, I seemed to get a leak around the cover when there was ice and snow mixed in with the leaves. When it was kept clean, it never leaked.
Good luck and keep us posted.
Lou
Offline Twisty
  • Eagle Camper
  • Gender: Male
    • OR [OR]
    • US [USA]
    • View Profile
    • Photobucket
« Reply #6 on: December 02, 2008, 01:07:16 AM »
Cover it IMMEDIATELY with SOMETHING!  Water will seep in and once a damp area begins it will continue to weep in due to capilary action (migration). You will have trouble with mold and probably rot. Follow Storm Trooper's advice. Invest in an ADCO cover - for long term.
2004 Fleetwood Utah w/slide
2006 Ford Ranger 4x4 Ext. Cab
www.CWhatIC.net
Twisty should be used for entertainment purposes only.
For Sale 2014 F350
2012 SV264
Offline pianewman
  • Star Camper
  • Gender: Male
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #7 on: December 02, 2008, 08:10:40 AM »
Curiously, my front seal does the same thing (and has for 3 years).  I've ignored it, and thankfully have had no water intrusion...that I know of, at least!
I think, with age, the seal must shrink and, for some reason, gets pushed up farther on the roof.  At some point, I will replace the seal, at which point I will satisfy my curiosity and see if the edge of the roof has a bit of a bow to it.
FYI, I have no signs of ABS roof sag, and yours seems to be nicely domed.
I assume Twisty means to cover the area where the seal isn't tight.  I don't think covering the entire ABS roof is a good idea, per Coleman/Fleetwoods instructions.
pianewman
2002 Fleetwood Santa Fe
2005 Toyota Tundra Double Cab Limited, 4.7 liter,  Reese 400 WDH, A.R.E. bed cap
Scangauge II
2002 Fleetwood/Coleman Santa Fe CP
2005 Toyota Tundra Limited 4WD, Reese WDH400
  • Star Camper
  • Gender: Female
    • MI [MI]
    • US [USA]
    • View Profile
« Reply #8 on: December 02, 2008, 08:21:35 AM »
I think for now I'm just going to use the weather stripping. The temps here have not been above freezing in awhile. In the spring I'll work on the permanent fix.
Julie '58 Jeff '59
Offline pianewman
  • Star Camper
  • Gender: Male
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #9 on: December 02, 2008, 03:51:53 PM »
I just looked closely at my seal.  It appears, because of shrinkage (shortening), that the seal at the corners gets pulled inward, making the seal at the corner out of position.  Instead of the seal being under and slightly outside the roof edge when compressed, it is pulled under the roof, at the corner, and is therefore thicker at those points.
Hope this makes sense.  I'll try to take a photo later.
pianewman
Scangauge II
Offline RhinoDave
  • Eagle Camper
  • Gender: Male
    • MI [MI]
    • US [USA]
    • View Profile
    • Photobucket
« Reply #10 on: December 02, 2008, 07:30:19 PM »
One easy way to verify if your roof has any sag is to make sure the camper is level and then pour a little water in the drain channels on each side of the roof. I'm willing to bet you will have at least a little water collect in the center and not drain off. My roof had the gaps in the front and back until I stopped leaving the bunkend canvas wrapped around the mattress ends when I folded the camper down. I started pulling the bunkends into the center completely to place most of pressure on the roof in the center. It helped to reduce the sag and the roof now seals completely across the front and back. I have been holding off on replacing the roof because I only had a couple of small cracks this past summer until around Sept when I found several large cracks under the awning bag. I really don't want to replace the roof because I don't like the way the replacement looks and after it's replaced there is only a five year warrenty. Funny how a lifetime warrenty changes over the years. I'm not in a big hurry since it is stored in a friends polebarn out of the weather. My seal also shrank and pulled away from the corners. I pulled it off completely and reinstalled it which created a 2" gap at the back of the trailer where I created a nice new section of molding with high priced silver tape. More commonly known as "Duct Tape".
Built for comfort...not speed.
97 Coleman Niagra
87 Coleman Sun Valley (project)
08 Chevy Trailblazer
Built for comfort ... not speed.
1994 Sunny Brook Classic 26FK
1997 Coleman Niagara - Gone but not forgotten
Offline Twisty
  • Eagle Camper
  • Gender: Male
    • OR [OR]
    • US [USA]
    • View Profile
    • Photobucket
« Reply #11 on: December 02, 2008, 08:23:53 PM »
My point is to cover it until it can be repacked in warmer weather, or as Storm Trooper suggests, repacked after trying to heat it up. I would cover it with anything handy to try and avoid water damage. That's just me.
www.CWhatIC.net
For Sale 2014 F350
2012 SV264
