User Info
Quick Forum Search
Who's Online
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 20161211 222531
Posted by robenster
Dec 14, 2016
in Checkout My Rig
Recent Topics
Why Hybrids? by Kevin79
[Today at 05:29:17 AM]
Tip on spare keys by generok
[Today at 12:26:04 AM]
Tension shelf mod by 4xMeteor
[Yesterday at 11:56:29 PM]
Upgrade Plastic Manual Hand Pump? Replacing the broken original. by 4xMeteor
[Yesterday at 11:47:09 PM]
RV Show FW TX- have you ordered a popup from factory with mods? by Orchid
[Yesterday at 11:30:33 PM]
Carpeting the camper floor... by Snow
[Yesterday at 11:29:51 PM]
2017 - Wisconsin August Rally by wapwap
[Yesterday at 11:02:38 PM]
Pup obsevations while on the road by Orchid
[Yesterday at 11:00:04 PM]
Coleman Yuma 2002? by SHFL
[Yesterday at 10:29:57 PM]
Central Texas Spring Rally 2017 by shfd739
[Yesterday at 10:12:32 PM]
2017 Premier Family RV Show Lansing, MI by papa and gram
[Yesterday at 10:11:40 PM]
1990 coleman SF Bay area by spinningmom
[Yesterday at 09:58:07 PM]
Author Topic: Starcraft Wiring  (Read 6759 times)
Offline shoningram
  • Camper, 2nd Class
  • Gender: Male
    • TN [TN]
    • US [USA]
    • View Profile
    • RV Pictures
Starcraft Wiring
« on: May 12, 2009, 06:57:14 PM »
Can anyone tell me the wiring diagram for a 76 Starcraft?  There is a red, green, brown, and orange wire going to the outside fuse box. Also there is a white and green wire going into camper box but I dont know where they originated from. I tried to hook it up but nothing worked.
I have a manual for a starcraft (73?) but the colors are all wrong
Shon Ingram
1976 Starcraft Starflite 6 & 2004 Chevy Colorado Z71
Three Kids/3 Dogs
Offline cro1972
  • Camper, 2nd Class
  • Gender: Male
    • MA [MA]
    • US [USA]
    • View Profile
Re: Starcraft Wiring
« Reply #1 on: May 12, 2009, 08:04:22 PM »
I will check I believe I have the complete repair manual direct from Starcraft.  I had a 76 but I ended up lossing my storage  over the winter.  I will let you know tomorrow if I find it.
Chris "72", Marcy "70" and the little princess Catherine "07
New Pup 99 Starcraft Starmaster
Offline shoningram
  • Camper, 2nd Class
  • Gender: Male
    • TN [TN]
    • US [USA]
    • View Profile
    • RV Pictures
« Reply #2 on: May 12, 2009, 10:44:45 PM »
Thanks Chris!
Shon Ingram
Three Kids/3 Dogs
Offline shoningram
  • Camper, 2nd Class
  • Gender: Male
    • TN [TN]
    • US [USA]
    • View Profile
    • RV Pictures
« Reply #3 on: May 18, 2009, 01:19:14 PM »
Can anyone tell me the best way to check running lights? I am going to have to check each wire to see which one does what. Would a 6v battery work??? Please help guys
Shon Ingram
Three Kids/3 Dogs
Offline cruising usa
  • Star Camper
  • Gender: Male
    • NY [NY]
    • US [USA]
    • View Profile
    • cruising usa 2409
« Reply #4 on: May 18, 2009, 09:14:00 PM »
I would use a 12V battery and a 12V test light to ring out the running lights. Hook the neg to the camper frame. The one at a time hook the running light to the battery positive.  At the light clip the test light to the frame and probe the wires to find the one  with power
Good Luck
04 Ranger towing Cruising the
04 Starcraft 2409
Offline Goldpickerdave
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #5 on: May 24, 2009, 02:09:57 PM »
shoningram I have a 73 starcraft would you be willing to share what you haave with me. I am going to be redoing my trailer and could really use the information on wiring it. I can only offer this to help you which I saw on another post a guy name Bob works for Starcraft. (260) 593-2550 is their phone number. He is suppose to be very good and helpful with older starcraft. Might be a good idea to give him a call and see if he can help.
Offline Big_kid
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
    • My photobucket albums
« Reply #6 on: May 24, 2009, 09:04:09 PM »
http://www.tropictrailer.com/wiring-diagram.html
A Google search for "trailer tail light wiring" will bring up the standard trailer light wiring.
Good luck!
We have enough youth. How about a fountain of smart?
'97 Starlounge, '95 Astro, '11 Colorado, 1970something VW Dune Buggy
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #7 on: May 27, 2009, 11:58:12 AM »
Well I am veryinterested in the running lights for the trailer but was hoping for more on the invert and internal power wall plugs and such my 73 starcraft has the original inverter not sure if i trust it and some of the wiring looks warn and chewed
Offline dupreet
  • Eagle Camper
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #8 on: May 27, 2009, 12:11:39 PM »
Can't help with Starcraft-Specific wiring, but the converter (not inverter) and other wiring is fairly universal in popups.
First question - are your lights and other 12V stuff working when you are plugged into shore power?  If so, then you can used a 12V test probe to figure out which wires go where.  You should have a 115V  AC line that gets plugged into your househould power......don't probe this with the tester!!!!
With a rig as old as yours, the converter should have a switch that goes between Off, Battery, and Converter.  This switchs the 12V output of the converter to off, from an onboard battery if you have one, and getting power from the converter itself.
Using the probe, you should be able to identify the one or two 12V output lines that run to your lights, furnace, water pump.  There might be a pair of wires that run up to a battery on the tongue?
If you have wires that look old, chewed, or otherwise damaged, then replacing them is certainly a good idea.  You can do this by simply powering things down and replacing the damaged sections.  You can get an assortment pack of 12V wiring at an auto parts store to keep your colors.
Todd Dupree
Wilderness 24' TT
'93 Ford E-350 15-Pax Van
Offline sylter63
  • Tenderfoot
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #9 on: June 18, 2009, 09:32:37 PM »
Hi, I am a newbie to this site. I have  79 Starcraft Galaxy. My husband would like to know if anyone has the wiring schematics. I bought my pop up 2 years ago. 4 days before we went on our a 3300 mile road trip. It needed a lot of work then. We did it with the bear necessities.  We're going out again after the 4th of July. It would be nice to have a few more things working properly. Any help would greatly be appreciated.
Sylter63 [PU]
Offline Xolthrax
  • Moderator
  • Eagle Camper
  • Gender: Male
    • PA [PA]
    • US [USA]
    • View Profile
    • The Home Page for Evil
« Reply #10 on: June 18, 2009, 11:16:48 PM »
Which wires are you referring to?  There are brake & marker light wires, and interior lighting / furnace / fridge wires, etc.
Joe
[PU]'96 Rockwood Signature Series 1280 [TV]'07 Ford Explorer
Wherever you go, there you are.  Gilwell Troop 1 (Owl Patrol)
Offline jonno2k
  • Camper, 2nd Class
    • CA [CAN]
    • View Profile
« Reply #11 on: June 27, 2009, 01:42:12 AM »
I have a 1976 manual. Are you still looking for a wiring diagram? I'll scan and email if you like.
