User Info
Quick Forum Search
Who's Online
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 20161211 222531
Posted by robenster
Dec 14, 2016
in Checkout My Rig
Recent Topics
Why Hybrids? by Kevin79
[Today at 05:29:17 AM]
Tip on spare keys by generok
[Today at 12:26:04 AM]
Tension shelf mod by 4xMeteor
[Yesterday at 11:56:29 PM]
Upgrade Plastic Manual Hand Pump? Replacing the broken original. by 4xMeteor
[Yesterday at 11:47:09 PM]
RV Show FW TX- have you ordered a popup from factory with mods? by Orchid
[Yesterday at 11:30:33 PM]
Carpeting the camper floor... by Snow
[Yesterday at 11:29:51 PM]
2017 - Wisconsin August Rally by wapwap
[Yesterday at 11:02:38 PM]
Pup obsevations while on the road by Orchid
[Yesterday at 11:00:04 PM]
Coleman Yuma 2002? by SHFL
[Yesterday at 10:29:57 PM]
Central Texas Spring Rally 2017 by shfd739
[Yesterday at 10:12:32 PM]
2017 Premier Family RV Show Lansing, MI by papa and gram
[Yesterday at 10:11:40 PM]
1990 coleman SF Bay area by spinningmom
[Yesterday at 09:58:07 PM]
Author Topic: I am replacing the ceiling inside my pop up.. what..  (Read 12200 times)
Offline campingtwins
  • Camper, 2nd Class
  • Gender: Female
    • US [USA]
    • View Profile
« on: May 10, 2010, 08:36:19 PM »
Hello, and thanks everyone for your help..
We are redoing a pop up... 82 coleman
My husband bought some luan to put up in place of the old roof... now my question is what is behind a ceiling .. what do we use to put up the luan .. to keep it in place... [RTM]
Thanks Kim
Kim & Jerry..Kylie & Joshua  Upstate NY
2006 Springdale
2010 Toyota Tundra
Offline craigbaker
  • Camper, 1st Class
  • Gender: Male
    • WA [WA]
    • US [USA]
    • View Profile
Re: I am replacing the ceiling inside my pop up.. what..
« Reply #1 on: May 10, 2010, 10:34:19 PM »
Most of these seem to be a foam glued to the roof skin with some wood to frame things like vent, screendoor hardware, etc.
Are you planning on replacing just the luan or replacing all the material inside the ceiling too?  You should be able to just glue the new luan up after removing the old one, assuming you aren't replacing the foam or anything else behind the existing.  I have heard people talk about Gorilla Glue working, but you will want to verify whatever you use is foam safe.
Offline ballard
  • Life Camper
  • Gender: Male
    • NH [NH]
    • US [USA]
    • View Profile
« Reply #2 on: May 12, 2010, 07:26:34 AM »
I may be difficult to try and remove the old ceiling without destroying the foam core. Foam core construction gets it's strength from the fact that the foam is glued to the outer skins which sandwich it (in this case the aluminum roof and the ceiling). Best to go right over the old ceiling. I have no idea of the "best" way.....but one way would be to use a 3m 5200 marine adhesive. I will warn you that this is a permanent adhesive if you wish something which could possibly be removed their are other marine caulking/adhesives that will remain a bit flexible.
Checkout jamestown distributors or westmarine and look under caulking and sealants. In the boat world adhesives, caulkings, and sealants all share similar qualities of adhesion with the difference being that some are more permanent than others, some are flexible, some are rigid.
To do this you will need place the adhesive on the luan, press it to the ceiling and then hold it in place with batons (lengths of wood running across the ceiling to serve as temporary bracing). These batons could be held in place by vertical 2x4 lumber which is wedged inbetween the floor and the wood bracing.
Another option would be pop rivets....predrill holes about 1/4 of inch (dont go throught the roof then use aluminum pop rivets (easy diy). In this case however the ceiling is only being suspended by the old ceiling at the point of each pop rivet where as the glue transfers the stress across the entire ceiling and the glue is also not visible where as a pop rivet will show.
I don't think you will find much to screw into under the ceiling but a stud finder may be helpful.
