User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
I'm a new member! by eoleson1
[Today at 03:02:06 PM]
Planning for '17 by kitphantom
[Today at 02:54:20 PM]
Need suggestions on an Georgia --> Grand Canyon North Rim, western US trip by kitphantom
[Today at 02:49:00 PM]
Opinions on items for NTU hybrid camper by Genie2010
[Today at 02:48:15 PM]
2017 Connecticut Rally by Debfmaine
[Today at 02:41:12 PM]
2017 - Wisconsin June Rally by golfnate07
[Today at 02:34:56 PM]
How much does it cost to tow a pop up? by love2travel
[Today at 02:30:13 PM]
So, what did you do for your camper, January 2017 by Firehawk068
[Today at 02:16:52 PM]
Generators by dracarys
[Today at 02:12:33 PM]
Maintenance suggestions on a NTU pop-up by MNTCamper
[Today at 01:58:22 PM]
Air Conditioning Mod? by tdiller
[Today at 01:53:56 PM]
Trailer audio. by MNTCamper
[Today at 01:53:34 PM]
Author Topic: Lubricating Lift System  (Read 10208 times)
Offline banjerboy
  • Camper, 2nd Class
  • Gender: Male
    • GA [GA]
    • US [USA]
    • View Profile
« on: May 17, 2010, 11:20:58 AM »
I have read some of the posts that suggest using a silicone based lubricant to lube the lift system.  My only concern is how and where and what do I lube and  also how do I access these areas.  I have a 1995 Coleman Destiny Royale and the *.* tree seems to be enclosed.  Any suggestions, within reason  [:D], will be appreciated.
95 Coachman Destiny, 99 Jeep Wrangler
Offline eve104
  • Camper, 1st Class
  • Gender: Female
    • FL [FL]
    • US [USA]
    • View Profile
Re: Lubricating Lift System
« Reply #1 on: May 17, 2010, 11:33:43 AM »
I used a silicone base spray on the lift poles.  I out card board between the lift poles and the canvas to protect it.  Then I sprayed the lift poles and each insertion point.  I let it dray for about an hour and then popped it down.  Important to not get the spray on hte canvas. We have a vinal outside canvas.  THe spray I used said it was safe for it but I protected it anyway.
Offline Twisty
  • Eagle Camper
  • Gender: Male
    • OR [OR]
    • US [USA]
    • View Profile
    • Photobucket
« Reply #2 on: May 17, 2010, 11:40:02 AM »
With the roof down and the cables slack, I removed the cover of the whiffle tree and wiped the parts clean with paper towels. I greased 'em up good. Replaced cover. Raised the roof and used the spray like eve104. I also sprayed all the pulleys in the lift posts and under the Pup.
Twisty should be used for entertainment purposes only.
For Sale 2014 F350
2012 SV264
Offline Dusty82
  • Eagle Camper
  • Gender: Male
    • NV [NV]
    • US [USA]
    • View Profile
« Reply #3 on: May 17, 2010, 01:08:15 PM »
Download the Coleman Lift System Manual here:
http://www.popupportal.com/manuals/Misc/Coleman_Lift_Systems.pdf
In the manual you'll find a description of the things to lube and what to use on them. Silicone Lubricant spray can be found in the automotive section at Wally World for just a few dollars a can.
Also in the manual you'll find some additional instructions regarding the removal of the whiffletree cover. The cover is a structural panel in some models, and some additional bracing between the frame crossmembers is needed before you remove it. That's all in the manual. From there it's just as Twisty said: clean it up and grease it. I used a high-temp axle grease.
Offline awsandlin
  • Eagle Camper
  • Gender: Male
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #4 on: May 17, 2010, 01:20:07 PM »
I believe a 95 year model is a model that will require you to brace before removing the cover.  However, I believe if the roof is down and the cables are slack, you can remove without bracing as long as you do not attempt to raise the roof with the cover removed.
Also, you are talking about two different areas of maintenance, lubricating the lift post and cables, and lubricating the whiffletree.  You will want to use some grease on the whiffletree.  I would use some to the Red and Tacky grease as it tends to stay where you put it.  I dont think you want to use any type of spray lubricant on the whiffletree.
Allen Sandlin
2004 Fleetwood Utah
Offline bupkis
  • Eagle Camper
    • TX [TX]
    • US [USA]
    • View Profile
Epsolar VS1024BN programmable charge controller
'07 Chevy Colorado 3.7L I5
gone but not forgotten '96 Coachmen Sport 086
Offline banjerboy
  • Camper, 2nd Class
  • Gender: Male
    • GA [GA]
    • US [USA]
    • View Profile
« Reply #6 on: May 17, 2010, 03:50:37 PM »
Thanks to all for your responce.  The videos from rabird were exceptionally helpful.  I am going camping later this week and will see if I can fit underneath my pup to try everythingout. [:D]
Offline darrenandmelissa
  • Camper, 1st Class
    • MB [MB]
    • CA [CAN]
    • View Profile
« Reply #7 on: May 17, 2010, 04:26:57 PM »
Stupid question but obviously when you grease up the lift system you would want the camper in the down position, this is where common sense has gotten me but my common sense is not always right.
2003 Shamrock 23 [HY][TV]  1997 GMC Jimmy
Offline banjerboy
  • Camper, 2nd Class
  • Gender: Male
    • GA [GA]
    • US [USA]
    • View Profile
« Reply #8 on: May 17, 2010, 05:36:17 PM »
Thanks and I did know that the roof should be in the down position.  This brings up  :) another question.  In my owners manual, it states that the roof should be raised before the pup is leveled and the jacks down.  There seems to be thru the portal that most of you level the pup before raising the roof therefore I seem to be in a quandary?   Any thoughts on the subject?
  • Camper, 1st Class
    • MB [MB]
    • CA [CAN]
    • View Profile
« Reply #9 on: May 17, 2010, 06:24:19 PM »
i have no clue how you would level your camper after the roof is up, especially side to side.
I beleive it is common practice to level(side to side and front to back), raise the roof, then stabalize.  If your owners manuel says something other then go with that.  You should never use the stabalizers to level the popup.
Offline mercman
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • MA [MA]
    • US [USA]
    • View Profile
    • Our Camping Adventures
« Reply #10 on: May 17, 2010, 11:25:20 PM »
The roof/stabilizers order depends on the MFG.  Colemans say roof up then stabilizers but on my Rockwood it says stabs down first then crank the roof. Always go by what the manual says. As for leveling, I can't see how you could level side to side once the roof is up. how could you get a block underneath the wheel? Maybe they mean front to back?  All the trailers I've known always call for leveling first.
-Chris
Offline Dusty82
  • Eagle Camper
  • Gender: Male
    • NV [NV]
    • US [USA]
    • View Profile
« Reply #11 on: May 17, 2010, 11:52:55 PM »
I really don't know about the 1995 manuals, but my old 1975 Coleman manual said to level the pup with the stabilizer jacks, after the top was lifted. In later manuals, they warn NOT to level the pup with the stabilizer jacks, but to put the top up before deploying the stabilizer jacks. I know - it's a quandary. Who do you believe?
Simply put, level the pup from side to side with a BAL type leveler or blocks under the wheels. This means pulling it onto those blocks and checking for level. Disconnect the TV, then level from front to rear with the tongue jack. Then lift the roof, then deploy the stabilizers.
Offline Xolthrax
  • Eagle Camper
  • Gender: Male
    • PA [PA]
    • US [USA]
    • View Profile
    • The Home Page for Evil
« Reply #12 on: May 17, 2010, 11:54:33 PM »
How in the hoo ha are you supposed to level after your roof is up?  They must have written your manual late on a Friday.  As Mercman said, the rest varies by camper.  I also have a Rockwood, and it says to raise the roof before I put my stabs down.  Go figure.
Joe
[PU]'96 Rockwood Signature Series 1280 [TV]'07 Ford Explorer
Wherever you go, there you are.  Gilwell Troop 1 (Owl Patrol)
Offline mercman
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • MA [MA]
    • US [USA]
    • View Profile
« Reply #13 on: May 18, 2010, 12:07:30 AM »
Quote
How in the hoo ha ...
Now that's a funny saying, I'll use that this weekend. :)
-Chris
Offline Hacksaw
  • Eagle Camper
  • Gender: Male
    • MN [MN]
    • US [USA]
    • View Profile
    • Fountain Lake Sportsmens Club
« Reply #14 on: May 18, 2010, 01:14:39 AM »
Up Down Up Down. Roof up -stabs down stabs up - roof down. The stabs have nothing to do with leveling.Level with the tires for side to side and the tongue jack for front to back.
One Fish, Two Fish. I fish. You Fish ?
1998 Coleman/Fleetwood Sun Ridge - Papa's Ark
2000 Ford F150 crew cab -F/V Shoreline II
