User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Author Topic: camper sink drain  (Read 3444 times)
Offline sonoma camper
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
camper sink drain
« on: June 30, 2010, 01:09:07 PM »
I have researched this on the site, but wondering if this would work for me? As you know sink drains very slowly. My pup has the drain underneath the camper. Has a hose bib type connection so you can attach a garden hose for gray water. Why can't I just put in a tee fitting under the sink with a hose (same size as the sink drain) and take this up to above the level of the sink. Attach it to the counter top just like your home kitchen sink? All it needs is an air relief for it to drain quickly.
Your thoughts?
1995 Coleman-Fleetwood "Sequoia"
2005 Tundra 4x4, Crew Cab, Limited Edition,  camping, fishing, kayaking
Offline andleton
  • Camper, 1st Class
  • Gender: Male
    • US [USA]
    • View Profile
Re: camper sink drain
« Reply #1 on: June 30, 2010, 10:08:35 PM »
I have the same problem with my 1995 coleman rio grande.Your idea should work but I will probably just live with the slow drain.We only use our sink for brushing teeth at nite so we will just live with it.happy camping,greg
Greg, Angie, Stephanie, and can't forget Duke (Our dog that loves to go camping..) & now PJ (the cat)
'95 Coleman Rio Grande,'09 Toyota Tacoma 4x4
Offline dupreet
  • Eagle Camper
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #2 on: June 30, 2010, 10:56:04 PM »
There are two main issues with slow drains in PUPs.
The first is the 'lay' of the drain hose under the sink.  It needs to be a continuous downhill run to the drain on the wall.  Many times, it gets kinked up and ends up with a 'high' spot where gravity starts messing with you and slowing things down.
The second issue is the lack of a 'vent'.  An easy mod is to build a vent stack that goes on the outside of the camper.  This will speed up the draining substantially.  Here is the one I built a few years back:
...out of these parts:
Todd Dupree
Wilderness 24' TT
'93 Ford E-350 15-Pax Van
Offline barb_dave
  • Eagle Camper
  • Gender: Male
    • WI [WI]
    • US [USA]
    • View Profile
« Reply #3 on: June 30, 2010, 11:11:53 PM »
Our Coleman Mesa's drain is also under the camper (drains through the floor)and we've never had a problem with a slow drain.  The only time it had drained slow was when I forgot to remove the vent screw from the gray water jug.
I would check the routing of the drain pipe to make sure there aren't any kinks.  If it's a new to you camper I would also consider the possibility that there may be a clog from the previous owner.
[PU]-1998 Coleman Mesa  [TV]- 2003 Dodge Grand Caravan
[CP] 2015 = 0
  • Camper, 2nd Class
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #4 on: July 01, 2010, 10:51:44 AM »
I saw this when I searched, but mine is npt this type. it drains through the floor to a hose connection underneath as I stated before. There are no kinks in the line and is not plugged. needs an air gap. thanks
