User Info
Quick Forum Search
Who's Online
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
Another battery charging question. by Boatnman
[Today at 03:48:36 AM]
A question on batteries and electronics by Boatnman
[Today at 02:10:29 AM]
Somerset Campers by gardenbliss
[Today at 01:46:16 AM]
UK Trailer by Tukee44
[Today at 01:39:50 AM]
2017 Arizona Spring Rally by Hoomi
[Today at 12:49:25 AM]
Outlet anchors ? by 94-D2
[Today at 12:44:52 AM]
Towing 4 pin wiring by 94-D2
[Today at 12:38:20 AM]
Haggling on a new pop-up by Dudman5703
[Today at 12:33:33 AM]
Tent camping at Yosemite, but have the wrong site by campfreak
[Yesterday at 11:54:54 PM]
Roof damage by world traveler
[Yesterday at 11:52:18 PM]
North Florida Rally - Stephen Foster S.P. - 2/24/17-2/26/17 by Orchid
[Yesterday at 11:12:12 PM]
Replacing vent - heng's vs. ventline? by xxxapache
[Yesterday at 10:37:09 PM]
Author Topic: ABS repair with sheet ABS & MEK (or some other glue)?  (Read 3392 times)
Offline NH-popper
  • Wagon Master
  • Eagle Camper
    • NH [NH]
    • US [USA]
    • View Profile
« on: October 06, 2010, 01:58:24 PM »
I was idly looking into a Coleman PUP with an ABS roof that has some cracks in it. I can get 4' x 8' sheets of 1/16 or 1/8 inch thick white ABS from a website - What do you think of the idea of trimming around the cracks to flatten them, then applying a patch of ABS sheet over the crack using either MEK or some kind of ABS glue?  Maybe it wouldn't look as nice as using the MEK-ABS goo and then sanding,  but given it's an old PUP and I'd be painting the roof afterward, I'm less concerned with looks than whether it would repair the roof. I'd still have to deal with some delamination spots but that's really a separate issue and I can use the "gorilla glue" method to deal with them...
What are your thoughts?
DW, DS & I - 2000 Coleman Niagara
2009 Chevy Silverado 1500 LT Extended Cab
45 nights camped in 2011, 40 days camped in 2012
Offline ballard
  • Life Camper
  • Gender: Male
    • NH [NH]
    • US [USA]
    • View Profile
Re: ABS repair with sheet ABS & MEK (or some other glue)?
« Reply #1 on: October 09, 2010, 12:01:18 PM »
I don't see why it wouldn't work. Probably not as good looking as a bored out crack that has been filled in though.
When I first started reading, I though you were about to suggest going over the entire roof with abs sheet.......Is that at all possible?
Offline NH-popper
  • Wagon Master
  • Eagle Camper
    • NH [NH]
    • US [USA]
    • View Profile
« Reply #2 on: October 09, 2010, 03:00:03 PM »
That's a good question, and one I wondered myself.  It comes in 4 foot by 8 foot sheets.  You'd have to use multiple sheets.  Could you quickly apply MEK with a roller and put it on the roof before it evaporates without leaving bubbles?  Might be a challenge.
Offline RhinoDave
  • Eagle Camper
  • Gender: Male
    • MI [MI]
    • US [USA]
    • View Profile
    • Photobucket
« Reply #3 on: October 09, 2010, 11:00:29 PM »
Sounds like a whole lot of extra work to me. I would just use MEK to soften the cracks and use a thin mixture of MEK/ABS to fill all the cracks. This really a sovent weld of the cracks. After they are all filled, I would use a liquid coating like Grizzly grip or Snow seal to coat the whole roof. At least that's what I would have done if I hadn't had my roof replaced. My  [2C]
Built for comfort ... not speed.
1994 Sunny Brook Classic 26FK
1997 Coleman Niagara - Gone but not forgotten
Offline ballard
  • Life Camper
  • Gender: Male
    • NH [NH]
    • US [USA]
    • View Profile
« Reply #4 on: October 10, 2010, 09:04:37 AM »
You are probably right rhino. The real challenge is not with the adhesive open working time. I probably wouldnt use the mek/abs filler to bond the sheet, I would use an alternative adhesive for abs and maybe just bond the edge perimeter then fill the seams. But the real challenge is getting it to lay down over the contours. There are pvc roofing materials that can be thermo formed to match contours. This is not an abs roof but it's the same concept. I'm not sure that it looks very good though. tpo plastic
The reason it looks wavey is probably due to uneven heating of the plastic. When molding large plastic sheets in a factory, a large oven would be used to heat the sheet evenly and then the pliable sheet would be used over the object. Typically vacuum formed or drape formed. This can be done with abs sheet but heating the sheet evenly to get a good product is probably next to impossible. Abs plastic has a very small window of workability temperature so it's easy to screw it up. UV stable pvc sheet and acrylic are heat pliable in the same way. A liquid membrane over the repaired surface seems like the easiest and best looking but I'm not sure how it holds up if the roof continues to crack and delaminate under the membrane. I would definitely consider the process most used at portal which is opening up the cracks with a dremel cutting wheel, filling with mek/abs.
Covering the repair with a membrane of elastomeric paint or grizzly grip would look pretty good.
