User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
Towing 4 pin wiring by Rusty2192
[Today at 07:53:52 PM]
Outlet anchors ? by Rusty2192
[Today at 07:44:41 PM]
Do you cover your outside stored pup? by Kalinedrive
[Today at 07:24:52 PM]
Good by to Orville and those here by HiFiDave
[Today at 06:54:27 PM]
Porta- cabin no title? by vade11
[Today at 06:47:38 PM]
Roof question pre purchase - Dutchmen by tw12
[Today at 06:31:23 PM]
Considering purchasing 2010 Fleetwood Coleman E-3 by kitphantom
[Today at 06:18:01 PM]
How to upload a photo?? by kitphantom
[Today at 06:15:50 PM]
It begins, lets rebuild the roof..LOTS of pics by BigAdm
[Today at 06:02:53 PM]
GFCI Won't Reset by rccs
[Today at 06:01:55 PM]
replacing the aux shower hose by Snow
[Today at 05:56:01 PM]
PU tail lights and turn signals by arthuruscg
[Today at 05:35:51 PM]
Author Topic: how much does propane weigh per gallon?  (Read 14983 times)
Offline KJcachers
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
« on: April 04, 2011, 08:10:42 PM »
Finding the number around 4.24 pounds per gallon on the web but this creates a mystery for me. I just bought a new 20 pound talk at Costco with a gauge on it. Took it to have it filled and the pump showed it took 5.7 gallons? That comes out to 24 pounds in a 20 pound tank? To top it off the gauge on the tank isn't quite at full either. The guy at the store says a used tank being refilled normally holds 4.6-4.7 gallons which puts you at the 20 pound number so are brand new tanks really larger than 20 but there is always some left in the tank when "empty"???
[PUT] 2011 Dodge Ram 1500 ST Crew Cab Hemi
2013 Keystone Bullet 246RBS
Nights Camped 2012 - 14
Offline NJGuy
  • Eagle Camper
  • Gender: Male
    • DE [DE]
    • US [USA]
    • View Profile
Re: how much does propane weigh per gallon?
« Reply #1 on: April 04, 2011, 08:24:11 PM »
Was the new tank purged first?  5.7 gallons does not sound correct.
« Last Edit: April 04, 2011, 08:40:00 PM by NJGuy »
2000 TrailManor 3023
TV 05 GMC Yukon Denali
If women do not find you handsome, they should at least find you handy.  Red Green
Offline bupkis
  • Eagle Camper
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #2 on: April 04, 2011, 08:32:36 PM »
That's too much propane in a 20 lb cylinder.
Weigh the full cylinder on a bathroom scale and subtract the TW (tare weight) stamped in the collar.
Also note the WC stamped on the collar. You should only fill to 42% of the WC (a WC of 47 lbs * .42 = 19.7 lbs propane).
Worthington Steel propane cylinder specs
4.24 lb/gal @ 60F
Epsolar VS1024BN programmable charge controller
'07 Chevy Colorado 3.7L I5
gone but not forgotten '96 Coachmen Sport 086
Offline Flyfisherman
  • Eagle Camper
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #3 on: April 04, 2011, 08:35:35 PM »
My old notes say 4.11 lbs per gal @ 60 degrees ... and I believe that's at sea level(?)
Fly
'02 GMC Sierra  ...  Starcraft  (sold)
But still have the old 9' X 9' Coleman Dome Tent!
Offline KJcachers
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
« Reply #4 on: April 04, 2011, 09:00:00 PM »
tank was new and prepurged and ready to be filled. going to weight it now. They had it on a scale at the fill station while they were filling it. I am thinking their gallon meter is off and I got overcharged.
« Last Edit: April 04, 2011, 09:15:59 PM by KJcachers »
Offline KJcachers
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
« Reply #5 on: April 04, 2011, 09:07:49 PM »
ok, weight on the digital scale showed 43.0   The TW is 19.8 and the WC is 47.60.
Doing the math it looks like I got 23.2 pounds in the tank and should have only got 19.999 based on the WC. So now what? burn off some gas?
  • Eagle Camper
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #6 on: April 04, 2011, 09:13:28 PM »
No.  That tank has an overfill safety valve inside and only so much propane can be added. The tank is good to go as is. But it sounds like you really did get overcharged and I'd be calling them for an explanation. Tomorrow.
Fly
Offline KJcachers
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
« Reply #7 on: April 04, 2011, 09:17:12 PM »
the weight shows 23 pounds though?  it was warm here today so would the temp have anything to do with it? it was mid 80's all day today in Northern Virginia!
BTW, we have more than 1 station in town for fills so the next time I need gas I know where NOT to go!
  • Eagle Camper
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #8 on: April 04, 2011, 09:34:14 PM »
I hear ya!  It is impossible to put that much propane into a 20# tank. Whoever filled the tank is pencil wipping you! Like I already posted, there's a safety valve inside that tank, it's called an "OPD" valve (overfill protection device) and that will allow only so much propane into the tank. In fact, before that OPD valve became standard, when you had the tank filled you actually got more propane!
Don't let that outfit get away with it. Call them, tell them you were over charged!
Fly
Offline bupkis
  • Eagle Camper
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #9 on: April 04, 2011, 10:10:40 PM »
The OPD is used as a secondary safety to stop filling not a primary.
OPDs fail. I suspect your's is bad!
Filling of 20 lb cylinders should be done by weight.
The WC is water capacity FULL
47.6 lbs/ 8.33 lbs/gal (water) = 5.7 gallons
5.7 * 4.11 lb/gallon (propane @ 25C) = 23 lbs.
If this FULL cylinder does not have any vapor space to compress if it warms above the 80F it was filled.
If it were me, I'd take it back to Costco and get a replacement properly filled.
Offline KJcachers
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
« Reply #10 on: April 04, 2011, 10:58:04 PM »
I bought the tank at Costco a few weeks ago but just got it filled tonight.  I do believe it was filled by weight as they had it on a scale while filling. so either their scale is off or their pump reading is off or they just put too much in the tank. I need to run the cook stove tomorrow and burn this thing down some and then reweigh it and see if things change.
Offline KJcachers
  • Eagle Camper
  • Gender: Male
    • VA [VA]
    • US [USA]
    • View Profile
« Reply #11 on: April 04, 2011, 11:02:44 PM »
Where is Hank Hill when you need him?  [LOL]
Offline bupkis
  • Eagle Camper
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #12 on: April 04, 2011, 11:08:04 PM »
Good luck.
I can't get U-haul to fill by weight, they set it on a scale thry never adjust, but go by gallons or until the OPD shuts off.
The ole time propane store does not have meter and must adjust the scale for each fill.
It's clear to me your OPD is bad.
