User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
I'm a new member! by eoleson1
[Today at 03:02:06 PM]
Planning for '17 by kitphantom
[Today at 02:54:20 PM]
Need suggestions on an Georgia --> Grand Canyon North Rim, western US trip by kitphantom
[Today at 02:49:00 PM]
Opinions on items for NTU hybrid camper by Genie2010
[Today at 02:48:15 PM]
2017 Connecticut Rally by Debfmaine
[Today at 02:41:12 PM]
2017 - Wisconsin June Rally by golfnate07
[Today at 02:34:56 PM]
How much does it cost to tow a pop up? by love2travel
[Today at 02:30:13 PM]
So, what did you do for your camper, January 2017 by Firehawk068
[Today at 02:16:52 PM]
Generators by dracarys
[Today at 02:12:33 PM]
Maintenance suggestions on a NTU pop-up by MNTCamper
[Today at 01:58:22 PM]
Air Conditioning Mod? by tdiller
[Today at 01:53:56 PM]
Trailer audio. by MNTCamper
[Today at 01:53:34 PM]
Author Topic: Flexible drain hose for pop-up  (Read 4642 times)
Offline mj2181
  • Tenderfoot
  • Gender: Female
    • GA [GA]
    • US [USA]
    • View Profile
« on: June 11, 2011, 11:43:25 AM »
We have a pop-up with the sink that folds down.  We need to replace the sink drain from the sink to outside, but the only flex drain hoses that I can find have a hose only 26 inches long.  I know that will not be long enough to go from the sink to the outside of the camper.
Do you know if any place I can go to get a sink drain system with a longer hose.  The contraption (I don't know what it is called) at the base of the sink drain has rusted off so that the swivel part of the drain system is gone.  We currently have a garden hose connected to the pipe coming directly from the drain, but when we close the camper, it pops off.
Do you have any suggestions?
Thanks
Michele
Offline cheyenne06
  • Star Camper
    • MO [MO]
    • US [USA]
    • View Profile
Re: Flexible drain hose for pop-up
« Reply #1 on: June 11, 2011, 02:49:31 PM »
You didn't say what kind of popup you have or dimensions of the hose. (And maybe a a picture of the "contraption" would help us give you some idea of what you have). You mention going from the sink to the outside of the camper. Usually there is flex hose from the sink to a 1.5" fitting on the camper outside wall, and from there you either use 1.5" fittings/hose or a little adapter that takes 1/5" to a garden host fitting, and then use a short garden hose down into your gray water bucket.
So I'm not sure I'm following, but to replace the hose inside, take some good measurements (what you really need is the inside diameter of the hose) and head to a big hardware store. In the plumbing section - probably up high with the stuff that is not bought a lot - there will be rolls of convoluted "sump pump hose" or "spa hose" or "dishwasher hose". You can probably get them to chop off and give you a couple inches to take home for size comparison if you don't want to take your current one apart and bring it in.
The sink drains in most PUPs are of a size known as a "bar sink" drain which is for a 2" opening in the sink itself, as opposed to 3.5" for a regular house sink drains. If you look enough in the sink drain section of a big box hardware store you'll find these bar sink drains, and perhaps you can replace the rusted part.
The final challenge is how do you connect the convoluted hose to the smooth surface fittings. Usually clean everything real well, use pure silicone caulk to take up the voids between the convoluted tubing inside and the fitting, then use some worm drive hose clamps on the outside to hold it together.
Hope that gives you some ideas. The above info is based on Fleetwood/Colemans.
Offline huizarr
  • Star Camper
  • Gender: Male
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #2 on: June 11, 2011, 06:52:03 PM »
Me, DW, and 3 DD's.
2014 Rockwood Roo 23IKSS
2004 Ford Expedition Eddie Bauer
Offline Unstable_Tripod
  • Eagle Camper
  • Gender: Male
    • WA [WA]
    • US [USA]
    • View Profile
« Reply #3 on: June 11, 2011, 07:39:59 PM »
Doesn't your sink drain have a hard plastic trap just like the ones under your sinks at home?
2011 RAM 1500 Laramie Quad Cab and 2009 TrailManor 2619
"Hook-ups are chains that bind you to uninteresting places."
