User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Author Topic: sport rack a21020 on a jayco 1007  (Read 3532 times)
Offline gwncanuck
  • Camper, 2nd Class
    • MB [MB]
    • CA [CAN]
    • View Profile
« on: May 19, 2012, 11:36:47 PM »
Has anyone installed this rack onto the factory roof rails of a jayco tent trailer? I cannot seem to get the metal feet for the cross-bars to line up with the slot in the roof t-rail. There is a moulded plastic spacer provided that, when inserted between the metal feet and the t-rail, aligns the mounting holes properly but then none of the supplied bolts are of the proper length to fasten the feet to the t-rail. Help??
2011 Jayco 1007
2005 Ford Explorer Sport Trac
Offline gwncanuck
  • Camper, 2nd Class
    • MB [MB]
    • CA [CAN]
    • View Profile
Re: sport rack a21020 on a jayco 1007
« Reply #1 on: May 28, 2012, 12:22:34 PM »
I'm replying to my own message because I solved my problem with these racks. I did have to buy longer allan bolts to pass through the molded inserts and attach to the roof rail. Another thing that I had to do was drill holes through the inside sleeve of each cross-bar to allow the two chrome screws to seat properly into the bar and attach the two pieces of the bar to each other. Why these holes weren't pre-drilled at the factory I don't know. Once I did these two things the racks attached perfectly. I then attached the SportRack A882 elite upright to the base rack and had no problems. I used foam pads to protect the bike finish from getting scratched by the plastic clamps on the A882. The bikes seem to be solidly fastened down so I'm ready for the road test.
2011 Jayco 1007
Offline czar
  • Tenderfoot
  • Gender: Male
    • ON [ON]
    • CA [CAN]
    • View Profile
« Reply #2 on: July 08, 2012, 03:56:31 PM »
Hey Mr. Gwncanuck
Just purchased the same rack for my 10 starcraft (jayco)
Any chance you could pass along pics of what you had to do to mount it to the channel on top??
Did you still have to drill through the roof??
Any help would be VERY welcome. (leaving from TO to DC on Fri.)
Thanks in advance
czar
Offline heathdavis
  • Star Camper
  • Gender: Female
    • FL [FL]
    • US [USA]
    • View Profile
« Reply #3 on: July 12, 2012, 02:31:38 PM »
I have that rack on my old Jayco 705.  It took me a bit to figure out how to put it together (the instruction diagrams are terrible!) but I did it without extra drilling thru the crossbars or anything.
(you DO have to drill into the roof- that is how it is designed.)
I don't exactly understand the problem you are describing but if you had pics maybe I could help.
1984 Jayco J-705
TV 1:  2011 Nissan Xterra
TV 2: 2005 Subaru Outback
Offline regis101
  • Camper, 1st Class
  • Gender: Male
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #4 on: July 12, 2012, 06:58:14 PM »
Yep.  You know the rulz.  We need pic's or it didn't happen.
'10 Palo Y-4100
'98 E150 Club Wagon
Wife, two kidz and a dog
Offline Klautt
  • Camper, 2nd Class
  • Gender: Male
    • AB [AB]
    • CA [CAN]
    • View Profile
« Reply #5 on: July 18, 2012, 11:45:14 PM »
Right o - so I need some help with this - How do you attach the arms to the lifts?
/worst instructions ever.
http://www.sportrack.com/uploads/576/A21020.pdf
2002 Flagstaff FST200ST(620ST) towed by Ford Flex Ecoboost
Offline heathdavis
  • Star Camper
  • Gender: Female
    • FL [FL]
    • US [USA]
    • View Profile
« Reply #6 on: July 19, 2012, 11:19:21 AM »
I'll try to get post some pics today, but basically those two pieces shaped like this:  [    ]   go on the the sides of the bar like this  [ o ]   with the bottom part of the   [    bracket tucked under the bracket that attaches to the roof.      They are held in place by screws.  It helps to get another person to hold everything in place while you're putting the screws in b/c otherwise it all falls apart.
If you have the original box with pictures on it, take a close look at the pictures.  That's how I figured it out.
1984 Jayco J-705
Offline Klautt
  • Camper, 2nd Class
  • Gender: Male
    • AB [AB]
    • CA [CAN]
    • View Profile
« Reply #7 on: July 19, 2012, 03:40:37 PM »
I have no screw holes, just like gwncanuk was implying :(
Offline heathdavis
  • Star Camper
  • Gender: Female
    • FL [FL]
    • US [USA]
    • View Profile
« Reply #8 on: July 20, 2012, 04:04:20 PM »
There aren't *holes*, the screw (bolt) goes through a slot in the   [  bracket.
Pics:
1984 Jayco J-705
Offline Klautt
  • Camper, 2nd Class
  • Gender: Male
    • AB [AB]
    • CA [CAN]
    • View Profile
« Reply #9 on: July 22, 2012, 12:49:47 AM »
Thanks! It looks obvious now. I was missing the plastic piece that the bolt goes though that fills the gap between the bar and the bracket, and I had the wrong bolts. I found it in parts for another project I have on the go, so somewhere I mixed that up. Everything is nice and tight now.
