User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
Towing 4 pin wiring by Rusty2192
[Today at 07:53:52 PM]
Outlet anchors ? by Rusty2192
[Today at 07:44:41 PM]
Do you cover your outside stored pup? by Kalinedrive
[Today at 07:24:52 PM]
Good by to Orville and those here by HiFiDave
[Today at 06:54:27 PM]
Porta- cabin no title? by vade11
[Today at 06:47:38 PM]
Roof question pre purchase - Dutchmen by tw12
[Today at 06:31:23 PM]
Considering purchasing 2010 Fleetwood Coleman E-3 by kitphantom
[Today at 06:18:01 PM]
How to upload a photo?? by kitphantom
[Today at 06:15:50 PM]
It begins, lets rebuild the roof..LOTS of pics by BigAdm
[Today at 06:02:53 PM]
GFCI Won't Reset by rccs
[Today at 06:01:55 PM]
replacing the aux shower hose by Snow
[Today at 05:56:01 PM]
PU tail lights and turn signals by arthuruscg
[Today at 05:35:51 PM]
Author Topic: interior lights/fan will not work on '02 Rockwood Freedom  (Read 5810 times)
Offline briamycon
  • Camper, 2nd Class
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« on: June 21, 2012, 12:35:09 PM »
i am baffled.  New camper to us, everything works except the roof interior lights and vent fan on our 2002 Rockwood Freedom PUP.  the air conditioner works but not the lights (i know they are on seperate power) but i cannot figure out why these won't work...nor does the previous owner
help
thanks
Brian
Offline mtnkube
  • Camper, 1st Class
  • Gender: Male
    • GA [GA]
    • US [USA]
    • View Profile
    • Pics
Re: interior lights/fan will not work on '02 Rockwood Freedom
« Reply #1 on: June 21, 2012, 12:38:37 PM »
Do you have the sink counter top flipped up in place and if you do check to see if you have a switch that triggers the lights to work when the sink is in the upright position.  My rockwood has that type switch to prevent the lights from staying on when you put the top in the down position and causing problems.
Offline Raycfe
  • Eagle Camper
  • Gender: Male
    • CT [CT]
    • US [USA]
    • View Profile
    • Coleman Cheyenne
« Reply #2 on: June 21, 2012, 12:41:09 PM »
Next in line to check is to follow where the wires go to the roof. Somewhere along the canvas or lift post must be some wiring.
Ray, Jin and Quincy,
2000 Coleman Cheyenne, [PU]
11 Subaru Forester, 00 GMC Jimmy
Offline Flyfisherman
  • Eagle Camper
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #3 on: June 21, 2012, 12:43:23 PM »
There is a safety cut off switch for the 12v so that in case you forgot to turn off the interior lights on closing .... all would not burn up ... or melt!
That switch could be either just above the lifting post (usually driver's side front), or it's located right where the flip over sink is located.  That switch can simply become stuck, with a little WD-40 doing the trick, or it might have to be replaced.
The A.C. - on the other hand - is a 110v item with a different connection.
Fly
'02 GMC Sierra  ...  Starcraft  (sold)
But still have the old 9' X 9' Coleman Dome Tent!
Offline NotSoRoughingIt
  • Camper, 2nd Class
  • Gender: Male
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #4 on: June 21, 2012, 12:50:44 PM »
My coleman had the same problem when we first purchased and it was because the switch located where the Galley swings up was stuck. I cleaned up the switch and presto lights working.Its a good thing to look at or it could be that when you swing up your galley its not fully engaging this switch.
20 nights camped so far 2012
Offline 01YZF6
  • Eagle Camper
  • Gender: Male
    • AL [AL]
    • US [USA]
    • View Profile
    • My Camper, Mods, & Trips
« Reply #5 on: June 21, 2012, 01:49:10 PM »
also check to make sure there is not a GFI or other breaker tripped on the converter too.  we have a separate depression switch on the converter too.
[HY] 00' Aero Cub C230
[TV] 08' Trailblazer
[PU] 87 Coleman Newport (sold)
Offline mercman
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • MA [MA]
    • US [USA]
    • View Profile
    • Our Camping Adventures
« Reply #6 on: June 21, 2012, 04:53:31 PM »
I have a '07 Rockwood. If your other 12v items work, water pump, furnace, outside porch light etc. then check your fuses. If not a fuse, then check the shut off switch under the gallery. See if it's going up & down. There will be a wire running up one of the lift posts that power the ceiling lights, near the top is a connector that some times gets loose.
Offline bigbluetraverse
  • Camper, 1st Class
  • Gender: Male
    • ON [ON]
    • CA [CAN]
    • View Profile
« Reply #7 on: June 22, 2012, 09:39:24 AM »
On mine the wire had simply fallen off the  switch.
Put it back on and walla lights.
Offline CoolDad
  • Star Camper
  • Gender: Male
    • LA [LA]
    • US [USA]
    • View Profile
« Reply #8 on: June 22, 2012, 11:40:23 AM »
You may also check your fuses.   Not just for a burned out fuse either.
I had an issue where the connector for the fuse had been open up where the fuse wasn't getting a good connection.
A little squeeze with some needle nosed pliers and the fuse was fitting snugly again.
[PU] - '08 Flagstaff BR28TSC Offroad
 [TV] - '07 Ford Expedition EL
 [8D] - Me-'67, DW-'74, DS-'97, DD-'01, DD-'04
Offline The Postman
  • Star Camper
  • Gender: Male
    • SK [SK]
    • CA [CAN]
    • View Profile
« Reply #9 on: June 22, 2012, 04:59:35 PM »
On our Palomino - which is also made by Forest River, there was actually a loose wire under the bench near the inverter.  I also caused our lights to stop working, but when you sat on the bench, they would work again.  Just check under there, and if all else fails, that might be the problem.  Good luck!!
Two hardy campers, and Cocoa the Trailer Dog
2009 Palamino Yearling
09 Jeep Liberty
Offline briamycon
  • Camper, 2nd Class
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #10 on: June 25, 2012, 02:23:58 PM »
Thank you all so much...this is still a mystery.
The shut off switch under the sink looks to be ok,
as do the fuses,
but the GFI outlet is not 'resetting or testing' so i fear that might be a problem.
I haven't looked into the wiring yet but will.
ugh
Online bigdad
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • KY [KY]
    • US [USA]
    • View Profile
« Reply #11 on: June 25, 2012, 02:51:54 PM »
My 2011 Rockwood had a problem on it was the fuse out at the battery pulled out and replug it back in and it work also check wire going up to the roof
camping is life.
2007 Dodge Ram 1500 4door 4x2
2012 Light House FB21
Offline mercman
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • MA [MA]
    • US [USA]
    • View Profile
« Reply #12 on: June 25, 2012, 03:09:54 PM »
as do the fuses,
ugh
The GFI outlets would not have anything to do with the 12v lights and fan on the ceiling. (The outlets are 120 volts AC, from an outside electrical source). The 12v items get there power from the convertor converting the 120v AC to 12v DC or the 12v camper battery (if equipped).  It's either the wire going to the lights along  one of the lifter posts. Mine is the street side front post, there's a connector on top that can work lose. Either that or it's a fuse, I believe it is one of the red ones on the convertor fuse panel. Replace with same amp fuse.
Offline briamycon
  • Camper, 2nd Class
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #13 on: August 06, 2012, 03:40:10 PM »
just an update - our battery had a dead cell.  seems to have fixed the problem of the interior lights (the side light by the door now works) but i haven't popped the whole thing up to confirm...but it's looking good
thank you all
