User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 20161211 222531
Posted by robenster
Dec 14, 2016
in Checkout My Rig
Recent Topics
What did you do to your TV this month by adrianpglover
[Today at 07:48:55 AM]
Hello by tzmartin
[Today at 07:34:26 AM]
Welding a Bulk head fitting to water tank by Customer
[Today at 07:32:54 AM]
On to my next project, the Fleetwood scorpion by tzmartin
[Today at 07:32:00 AM]
The Music Game by Kalinedrive
[Today at 07:00:59 AM]
introduction by eoleson1
[Today at 06:25:14 AM]
April Fools Rally @ The Sewer by yetavon
[Today at 05:53:25 AM]
Ross Prairie Florida? by Orchid
[Today at 01:43:01 AM]
Album: Checkout My Rig by Davidcamper305
[Today at 12:58:09 AM]
Replacing Mattresses by Peter (a crazy Canuck)
[Yesterday at 11:41:52 PM]
2017 Washington Summer Outing by Heartman_wa
[Yesterday at 11:34:26 PM]
Potential new PUP owner...need advice on towing package! by Snow
[Yesterday at 11:31:38 PM]
Author Topic: Furnace blower works, but no heat  (Read 3421 times)
Offline rt749
  • Camper, 2nd Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« on: September 28, 2012, 01:50:08 PM »
1997 Coleman Fleetwood Bayport.  Owned it for a year.  Slowly working on getting all of the parts and pieces to work right.
I need some more help!  Since I installed my new converter and new battery I can get the furnace blower to work, but no heat.  There is a pilot that I assumed was for the refrigerator.  I can light it, but don't see anything that resembles a furnace burner.
We are planning to try winter camping, but I think the furnace will be a real necessity.
Thanks for any help you can give me.
2012 Buick Enclave
Offline Unstable_Tripod
  • Eagle Camper
  • Gender: Male
    • WA [WA]
    • US [USA]
    • View Profile
Re: Furnace blower works, but no heat
« Reply #1 on: September 28, 2012, 02:07:33 PM »
Neither the furnace nor the fridge have pilot lights.  You are probably lighting a pilot light for the water heater.  Or, you may be lighting the propane flame for the fridge.  That isn't a pilot light because it does not ignite a bigger flame.  It is the entire heat source for the fridge when on the propane option.
The furnace has an electronic igniter.  First, be sure the propane is on and that the lines have been bled of air by running the stove for a few minutes.  Second, be sure the On/Off switch on the thermostat (different lever than the temerpature setting lever) is set to On.  Third, check under the metal furnace grille to see if there is a reset switch and if so, be sure it is set to On.  If all of these things are OK and it still won't light, check the sail switch.
2011 RAM 1500 Laramie Quad Cab and 2009 TrailManor 2619
"Hook-ups are chains that bind you to uninteresting places."
Offline Team cmk
  • Camper, 2nd Class
  • Gender: Male
    • WI [WI]
    • US [USA]
    • View Profile
« Reply #2 on: September 28, 2012, 02:10:23 PM »
UT - I'm curious, where is/what is a sail switch.
Thanks
2010 Ford Explorer
2002 Coleman Cottonwood
Me; DD-'01; DS-'04; DS-'06
  • Eagle Camper
  • Gender: Male
    • WA [WA]
    • US [USA]
    • View Profile
« Reply #3 on: September 28, 2012, 02:38:15 PM »
Inside the furnace housing.  The air from the fan moves it to make an electrical contact.  Without this contact the gas valve will not open.  It is a safety system.
HERE is an example of one on ebay.
Offline mnebinger
  • Eagle Camper
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #4 on: September 28, 2012, 02:39:27 PM »
A sail switch is used to turn the propane on inside the furnace.
Here's how it works:
1. Thermostat calls for heat.
2. Blower fan comes on.
3. Once the sail switch is "blown" by the air flow of the blower fan, the electronic igniter starts clicking and the gas valve opens. Then you here a whoosh as the burner lights.
DH '70, DW '67, DS1 '98, DS2 '02
'14 Jayco x18d HTT, '07 Toyota 4Runner
2016 Fall C U @ the Sewer Rally - http://www.popupportal.com/index.php?topic=100731.0
Offline rt749
  • Camper, 2nd Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #5 on: September 28, 2012, 03:27:07 PM »
Thanks Unstable!  It must be the pilot for the refrig, because I don't have a water heater.
I seem to be on the right track and will try the other things you suggested.  Still not really sure where the sail switch is, but I think I have seen all of the other things you mentioned. I can't find a word in my owner's manual about the furnace.
2012 Buick Enclave
Offline freenaz
  • Life Camper
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
    • Pix
« Reply #6 on: September 28, 2012, 04:03:09 PM »
The furnace probable has its own manual and won't be in the owners manual.
Make sure the thermostat is on and set high enough to start the furnace.
[PU] 1997 Santa Fe [TV] 2007 GMC Yukon [8D]
2011 nights camped -  30
2012 nights camped -  25
Offline smit1088
  • Eagle Camper
  • Gender: Male
    • MN [MN]
    • US [USA]
    • View Profile
    • CamperSolutions
« Reply #7 on: October 01, 2012, 10:24:56 AM »
Make sure your polarity to the furnace (and the rest of the camper) is correct.  If the battery is hooked up backwards (Black is positive and white is negative on Coleman factory harness) the fan will run backwards and never let the sail switch turn the gas on.
I know this from a cold evening.
Good luck.
2000 Coleman Cheyenne
2004 Toyota Sienna
www.CamperSolutions.com
Offline rt749
  • Camper, 2nd Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #8 on: October 01, 2012, 12:33:01 PM »
Thank you for all of your suggestions!  I hope I am closing in on this.
Furnace switch is ON.
Thermostat turned all the way up
Propane on and lines bled by running stove
Furnace blower comes on and blows strongly, but no heat
I hear a sound which I think may be the burner trying to light, but nothing happens.
Battery is disconnected in an attempt to make the low voltage alarm quit beeping, but no luck there.
Sail Switch?  There is also a 5 amp fuse in there?
2012 Buick Enclave
Offline bupkis
  • Eagle Camper
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #9 on: October 01, 2012, 12:54:18 PM »
Lots of possible causes.
see page 28, then 22-28
http://bryantrv.com/docs2/docs/hflameservice.pdf
I believe I'd check for voltage at the gas valve while it is attempting to light.
Don't believe it is recommended but have read that folks give their furnace a whack from time to time!!!
Epsolar VS1024BN programmable charge controller
'07 Chevy Colorado 3.7L I5
gone but not forgotten '96 Coachmen Sport 086
Offline rt749
  • Camper, 2nd Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #10 on: October 01, 2012, 04:12:21 PM »
Thank you so much for the link to the manual.  I am not there yet but feeling more positive that I can get to a warm place!
2012 Buick Enclave
Offline freenaz
  • Life Camper
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
    • Pix
« Reply #11 on: October 03, 2012, 09:47:45 AM »
"Battery is disconnected in an attempt to make the low voltage alarm quit beeping, but no luck there."
Are you referring to the LP detector as the low voltage alarm? If so then the furnace will not light because it is detecting LP. The LP detector could have a bad or dirty sensor.
Offline rt749
  • Camper, 2nd Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #12 on: October 03, 2012, 07:59:20 PM »
Reasonably certain now (finally) that the lp detector was bad.  I have removed it and will replace.  I could not smell any LP, but that may be the only logical solution.  Removing it resolved the beeping!  I have not yet tried the furnace.
Thanks for your suggestions.  I will let you all know when (if?) I get it resolved.
2012 Buick Enclave
Offline ChocoChock01
  • Wagon Master
  • Eagle Camper
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #13 on: January 22, 2013, 12:21:12 PM »
Is there a test for either the Sail Switch or the Igniter to narrow down the defective item?
Offline bupkis
  • Eagle Camper
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #14 on: January 22, 2013, 12:46:34 PM »
I'll suggest a volt meter to probe the gas vale at the appropriate time. If the gas vale is getting power then the relay, sail and limit switch 'passed'. The gas valve's solenoid coils resistance can be measured.
Various service manuals
http://bryantrv.com/docs.html#furnace
