User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Author Topic: Atwood Furnace makes horrible noise, unpredictably.  (Read 2964 times)
Offline Tonimus
  • Camper, 1st Class
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
« on: April 09, 2013, 04:40:09 PM »
I've got a '94 Coleman with an Atwood furnace in it.  Sometimes when it's firing up and or running, it sounds like a weed whacker with a bad bearing.  I've never been into a furnace before and I don't know what could be causing the sound.  I'd guess the blower wheel is intermittently making contact with the housing, creating the noise, but I'm not sure how to track down the noise...  Does anyone have any suggestions?
-USMC Corporal Hess Sherrod 6/6/84-4/6/2009 I miss you, my brother.
1994 Coleman Rio Grande [PU][PUT]  1984 Chevy C30 Camper Special 454ci/TH400
Offline RockyRoo
  • Eagle Camper
  • Gender: Male
    • OH [OH]
    • US [USA]
    • View Profile
Re: Atwood Furnace makes horrible noise, unpredictably.
« Reply #1 on: April 09, 2013, 04:42:53 PM »
That would be my guess.   Take it out and start digging in till you get to the blower.
Jay, Michelle (Mrs. Rocky Roo), King, Buddy & Duke
Isuzu
2017 Grand Design Reflection 337RLS
Offline Tonimus
  • Camper, 1st Class
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
« Reply #2 on: April 09, 2013, 04:46:55 PM »
I need to fire up the furnace without propane and see if it'll make the noise without heating up.
Offline Tom Biasi
  • Eagle Camper
  • Gender: Male
    • NJ [NJ]
    • US [USA]
    • View Profile
« Reply #3 on: April 09, 2013, 04:49:39 PM »
It may be a bad bearing but check to see that the fan is tightly attached to the shaft. It should have a set screw or two and if the shaft is not flatted the fan could be vibrating. This is speculation since you didn't say the model.
Tom
1998 Viking 1906 ST
2009 Trailblazer 4.2L L6
Sent from my Bendix G-15 computer.
Offline Tonimus
  • Camper, 1st Class
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
« Reply #4 on: April 09, 2013, 05:38:48 PM »
It's an Atwood Everest 8012
Offline nomoretent
  • Star Camper
  • Gender: Female
    • VA [VA]
    • US [USA]
    • View Profile
« Reply #5 on: April 09, 2013, 06:05:30 PM »
I'm not expert, but ours did that after we ran it without propane.  We banged on it a little, cranked up the heat and let it run with propane for a while.  Works now!  You might want to check through the vent outside for bug nests.
1994 Jayco Eagle 10
Shawn & Carrie
2013 nights camped - 6
Offline daveo1289
  • Life Camper
  • Gender: Male
    • NY [NY]
    • US [USA]
    • View Profile
« Reply #6 on: April 10, 2013, 11:15:42 AM »
It could be that the fan is hitting the edge of the shroud when it heats up and the metal expands a bit. Your going to have get in to it and see if the fan is real close to the shroud. Good luck.
Offline bupkis
  • Eagle Camper
    • TX [TX]
    • US [USA]
    • View Profile
« Reply #7 on: April 12, 2013, 03:00:23 PM »
There is a 'fan' on each end of the motor, one to force air out and one to supply air to the burner.
The 8012 is an energy mizer, less than 2 amp compared to the 7900 series at 3.4 A  [A]
Several docs @ bryantrv.com
Epsolar VS1024BN programmable charge controller
'07 Chevy Colorado 3.7L I5
gone but not forgotten '96 Coachmen Sport 086
Offline Snow
  • Eagle Camper
  • Gender: Male
    • ON [ON]
    • CA [CAN]
    • View Profile
    • Pictures
« Reply #8 on: April 13, 2013, 12:13:04 AM »
I would say you either have a bad bearing or the "birdcage" fan is actually starting to separate from itself..
[::)] DW, [8D] DS1, [8D] DS2, [}:)] [}:)] Da Dogs.
2005 Outback 21RS Pushing a 2012  Dodge Ram.  Ontario Rally 2014, 2015 & 2016
Offline turborich
  • Eagle Camper
  • Gender: Male
    • NV [NV]
    • US [USA]
    • View Profile
« Reply #9 on: April 13, 2013, 02:37:04 AM »
Those furnace motors are very cheaply built and don't use bearings, They use bushings and they need to be oiled from time to time. You'll have to pull the furnace out and dissemble a few things to get at the motor. If you're mechanically inclined then you'll be OK. If it is the motor bushings then you can try to use some light oil to lube both of the bushings. This may or may not work as it depends how worn they are. I have done it several times with great success. If it's shot then you'll need a new motor.  [2C]
2000 Jayco Eagle 12 UDST
2000 Ford Expedition XLT
~MOLON LABE~
Offline rd3
  • Camper, 2nd Class
  • Gender: Male
    • KY [KY]
    • US [USA]
    • View Profile
« Reply #10 on: April 13, 2013, 06:38:38 AM »
I've never heard of one that didn't make noise like that. I've had two and they both did and read a lot of stories about the same problem. If you figure out how to make it stop I would love to know about it. I use a Mr. Heater buddy because its quite and doesn't use any battery power.
RD3
"I don't think you understand, these boys killed my dog."
Offline turborich
  • Eagle Camper
  • Gender: Male
    • NV [NV]
    • US [USA]
    • View Profile
« Reply #11 on: April 13, 2013, 03:54:51 PM »
They make noise because the bushings are dry.
~MOLON LABE~
Offline generok
  • Eagle Camper
  • Gender: Male
    • AK [AK]
    • US [USA]
    • View Profile
« Reply #12 on: April 16, 2013, 05:14:32 PM »
Our Atwood 7900 ran two nights straight and it just sounded like a car fan running, no vibrations.  When ours runs low on LP, it begins to clunk as the regulator gets low on pressure, but that's all.
1996 Jayco Eagle 8
2002 Ford F-350 7.3L Diesel
2013 Polaris Ranger 800 EPS
