User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
 Rating: 0.12
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
Towing 4 pin wiring by Rusty2192
[Today at 07:53:52 PM]
Outlet anchors ? by Rusty2192
[Today at 07:44:41 PM]
Do you cover your outside stored pup? by Kalinedrive
[Today at 07:24:52 PM]
Good by to Orville and those here by HiFiDave
[Today at 06:54:27 PM]
Porta- cabin no title? by vade11
[Today at 06:47:38 PM]
Roof question pre purchase - Dutchmen by tw12
[Today at 06:31:23 PM]
Considering purchasing 2010 Fleetwood Coleman E-3 by kitphantom
[Today at 06:18:01 PM]
How to upload a photo?? by kitphantom
[Today at 06:15:50 PM]
It begins, lets rebuild the roof..LOTS of pics by BigAdm
[Today at 06:02:53 PM]
GFCI Won't Reset by rccs
[Today at 06:01:55 PM]
replacing the aux shower hose by Snow
[Today at 05:56:01 PM]
PU tail lights and turn signals by arthuruscg
[Today at 05:35:51 PM]
Author Topic: Transfer water from 5 gallon container to fresh water tank on the trailer  (Read 3123 times)
Offline progolfer_20
  • Camper, 2nd Class
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
I'm tired of lifting 40 pounds multiple times to pour in the water. I know this has been addressed before - I want a powered pump. Is there something that is 110v that I could plug into my generator, or 12v with clips that I can hook to my battery (either the trailer or my tow vehicle)? I'd like to keep it under $50.
I have seen a drill powered pump but not sure if I want to go that route, have you guys used that one?
2010 Toyota FJ
2006 Starcraft 14 RT
Offline 94-D2
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • CA [CA]
    • US [USA]
    • View Profile
    • My PICS
Take a look at my water transfer mod.  It may be what your looking for.
http://www.popupportal.com/index.php?topic=73280.0
Pm me if I can help
J
2011 Coleman Avalon W/Custom Features, 2008 Toyota FJC
SeaEagle Explorer 420/330, 2009 Specialized Hard Rock
Nights camped in 2016, 20 2,900 miles.
  • Camper, 2nd Class
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
Can I just take a hose and drop into my 5 gallon container and hook it upto the pump? I want to keep it simple and not want to modify the trailer.
I found this on amazon:
http://www.amazon.com/Wayne-PC2-115-Volt-Portable-Water/dp/B000CPZTEK/ref=sr_1_15?ie=UTF8&qid=1373260347&sr=8-15&keywords=12v+water+pump
I could plug it in directly to the generator.
2010 Toyota FJ
Offline 94-D2
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • CA [CA]
    • US [USA]
    • View Profile
    • My PICS
Don't see why you can't.  I'd go 12v so you don't have to start and run a generator.  You can use your 7 pin trailer plug.  It has a 12v aux ties to your pups battery.  But our choice.  Just buy a short potable hose with the bib connector on it for both ends of the pump and the draw in the can, the out in the fill tube.  Check harbor freight for the same pump but cheaper.
Good luck.
Offline FJGuy
  • Camper, 1st Class
  • Gender: Male
    • AZ [AZ]
    • US [USA]
    • View Profile
Travis, that should work fine for what you are wanting to do with it.  I think pumps such as that don't even need to be primed to get them going.  You will however need to stick close to it, because at 390 GPH it will empty an 5 gallon jug in roughly a minute.  At least I am assuming they are 5 gallons going by the 40lb reference you made.  I say go for it.
[TV] 2010 FJ Crusier
[PU] 1999 Coachman Hunter
Me '70, DW'73, DS1 '94, DD1 '96, DS2 '04, DD2 '06, DD3 '09, DS3 '11, and our Aussie Blue Healer "Piper"
Offline 94-D2
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • CA [CA]
    • US [USA]
    • View Profile
    • My PICS
Here is the harbor freight with the clips if you like.
http://www.harborfreight.com/12-volt-marine-utility-water-pump-94639.html
Offline PDieter
  • Star Camper
  • Gender: Male
    • WA [WA]
    • US [USA]
    • View Profile
    • Pup Gallery
Just siphon?
1992 Coleman Williamsburg
-any missing photos in my posts can be found in my album link-
Offline Dubbya
  • Eagle Camper
  • Gender: Male
    • MB [MB]
    • CA [CAN]
    • View Profile
    • Dubbya's Popup Camper Mods Page
Just siphon?
Definitely the least expensive and least complicated option bar none! [;)]
We use a 12v Flojet 03526-14A pump (2.9 gpm at 50 PSI) pump plugged into a booster pack to transfer water from a 6 gallon Hydroller to the fresh water tank. It's mounted to a two step ladder under the Eccotemp water heater. We just bypass the heater and run the hose directly into the Fresh Water tank. The pump costs about $58 plus shipping at www.energystead.com.
It also pumps water through the Eccotemp L5 to provide on-demand hot water for our portable field sinks. If you don't have a water heater in the camper, this is a pretty slick way around it.
Field sink mod thread is here
1996 Viking 2060ST | 1997 Ford F-150
Offline generok
  • Eagle Camper
  • Gender: Male
    • AK [AK]
    • US [USA]
    • View Profile
Dubbya -
Do you work for NASA?  Yikes that rig looks hi speed, low drag!
1996 Jayco Eagle 8
2002 Ford F-350 7.3L Diesel
2013 Polaris Ranger 800 EPS
Offline MarkoPolo
  • Camper, 2nd Class
  • Gender: Male
    • CO [CO]
    • US [USA]
    • View Profile
I tried the electric drill route using the highest rated one from Amazon. Worked great the first time, second time, smoke started coming out and then a loud pop--it's toast. I was running my drill at highest speed off my generator. No where did the instructions say to go a lower speed. Love the idea, maybe mine was just a defective unit.
Lance 1995 Travel Trailer
2013 Ford F-150 Super Crew Eco-boost
Mark  Greeley, Colorado
Offline Dubbya
  • Eagle Camper
  • Gender: Male
    • MB [MB]
    • CA [CAN]
    • View Profile
Nope, I don't work for NASA, not YET anyway!  [:D]
That's just the product of a long winter with too much time spent reading the boards here at the portal. [;)]
Gotta credit (blame?) Xolthrax for the Eccotemp L5 idea. He plumbed his to an extra city water inlet so he had hot/cold running water inside and an external hose bib coming out on the other side his old pup. Totally sweet mod.
Offline ricknpeg1
  • Star Camper
  • Gender: Male
    • FL [FL]
    • US [USA]
    • View Profile
I don't understand the problem of just pouring it into a funnel. Is it too heavy or too slow... what? I'm a hefty 250 LBS. so I really never thought about 40 Lbs as being heavy. Maybe it just plain takes too long.
Rick 05 Fleetwood Niagra,07 Chevy Tahoe
Offline Dubbya
  • Eagle Camper
  • Gender: Male
    • MB [MB]
    • CA [CAN]
    • View Profile
Rick, I'm rockin' 250 as well. It's not too big a deal for the average healthy Joe but the DW can't tuck a 5 gallon water jug under one arm and hold a funnel with the other for the two minutes it takes to empty the jug (at least not without getting soaked in the process). It seems there are lots of folks around here in the same boat.
Offline RockyRoo
  • Eagle Camper
  • Gender: Male
    • OH [OH]
    • US [USA]
    • View Profile
At 240 pounds and post 2 lower back surgeries, it would be incredibly difficult for me to repeatedly empty 5 gallon jugs into my fresh tank to refill.  Just sayin, it's a lot of weight for many people.
Jay, Michelle (Mrs. Rocky Roo), King, Buddy & Duke
Isuzu
2017 Grand Design Reflection 337RLS
Offline 94-D2
  • Wagon Master
  • Eagle Camper
  • Gender: Male
    • CA [CA]
    • US [USA]
    • View Profile
    • My PICS
I'm 200 lbs healthy with no disabilities.  I'm just like to work smarter not harder.  Adds to my camping enjoyment.  Plus its fun to tinker.  PITA to hold the container up and balance a plastic spout with 50+ pounds above it for 3-4 min while it dumps into the tank.  So, I searched my forums and came up with a mod that suits me.
Posted In case someone else wanted to do the same type of thing.
Happy Campin'
