User Info
Quick Forum Search
Upcoming Rallies
Weekly Photo
Zoom Details 2
Inks Lake State Park in Texas
 Comments: 2
 Rating: 4.95
Posted by TX_F2
Feb 26, 2008
in This Week's Photo Winner
Checkout My Rig
IMG 0919
Posted by Davidcamper305
Jan 14, 2017
in Checkout My Rig
Recent Topics
Author Topic: Who wants hard walls for their inside shower?  (Read 15876 times)
Offline Rusty
  • Camper, 1st Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« on: August 25, 2013, 10:45:35 PM »
I did not like the shower curtain in my Starcraft 3608 and niether did my DW.  I made three panels that can be put up and taken down without tools that keeps the water in the shower and does not leave us sticking to a curtain.  I will post some pictures of the shower walls set up.  I got all the materials I needed from Menards ... any home improvment box store would probably have the same stuff.  There is still a curtain, but it is only on the entry side.
An added benifit is more privacy while using the cassette toilet.
No amount of planning will ever replace dumb luck.   Rusty and Susie
2007 Starcraft 3608,  2009 Ford Expedition
Offline Manper
  • Camper, 1st Class
    • CO [CO]
    • US [USA]
    • View Profile
Re: Who wants hard walls for their inside shower?
« Reply #1 on: August 25, 2013, 10:56:27 PM »
 [:D] LOVE IT!! Please tell me how you did it!!!!
2014 KZ Sportsman 242 Showstopper. Colorado natives!!
Offline Snow
  • Eagle Camper
  • Gender: Male
    • ON [ON]
    • CA [CAN]
    • View Profile
    • Pictures
« Reply #2 on: August 25, 2013, 11:49:21 PM »
If you have any drawing's, scribbles or photos of the build stages that would be helpful to others please feel free to post them...
[::)] DW, [8D] DS1, [8D] DS2, [}:)] [}:)] Da Dogs.
2005 Outback 21RS Pushing a 2012  Dodge Ram.  Ontario Rally 2014, 2015 & 2016
Offline colo-pr
  • Camper, 1st Class
  • Gender: Male
    • CO [CO]
    • US [USA]
    • View Profile
« Reply #3 on: August 26, 2013, 12:05:55 AM »
I WANT THAT!!!!! Subscribed to the thread now.
Please share the info, You made my day. I thought in something like this when bought my Rockwood 2280 but don't have an idea of how to start.
Please, please, pleaseeee share!!! ;-)
[PU] 2014 Rockwood 2280BH
[TV] 2010 Jeep Wrangler Unlimited Rubicon
"Hook-ups are chains that bind you to uninteresting places."
Offline COdreaming
  • Camper, 1st Class
  • Gender: Male
    • MO [MO]
    • US [USA]
    • View Profile
« Reply #4 on: August 26, 2013, 12:23:22 AM »
Nice! I'd like to know too!
2009 Jayco 1206
2015 Ram 2500 6.4L V8 4x4
My wonderful wife, two beautiful daughters...and me.
Offline jonkquil
  • Star Camper
  • Gender: Female
    • OR [OR]
    • US [USA]
    • View Profile
« Reply #5 on: August 26, 2013, 12:52:00 AM »
I want in!! Do tell?
Beaverton, OR - 2007 Westlake
Offline Rusty
  • Camper, 1st Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #6 on: August 26, 2013, 01:19:00 AM »
 :) I didnt think there would be this much intrest so fast.  I do not have photos by stages, but I can explain how I did it...
- Measure the dimensions of your shower/toilet combo.  Mainly the length of both sides and the length of the back, also measure up to see how high you can make the walls, higher means less splashing into the pup.
- I made the panels oversized with paneling that matched our interior and on the inside of the paneling I used spray glue (3M super high srtrength 99) to laminate a waterproof recycled plastic sheet (about 1/16" thick for the plastic + about 1/8" thick for the paneling).  I layed these down on the garage floor to dry.  I put them on an old blanket and pressed them together by putting plywood on the newly laminated panel and stepping on it gently.
- Cut the panels to the correct size, the side panels will be almost the same length of the sides of the combo unit, but the back panel will be a little shorter to allow to fit into a dado joint in the frame I will explain later.
- I wanted something waterproof for a frame so I used a composite white 2X2 stud (this material was near the regular lumber at Menards).  The composite material is straight and tools real nicely.   Try to find a straight wood 2X2 and you will see it is nearly impossible to use real wood even if you wanted to.
- I used stainless steal screws to attatch the panels to the 2X2's, there is a 2X2 stud on each long edge of the laminated shower side panels.  There are no 2X2 studs on the back panel.
 - The back panel fits into a dado groove that I cut in each of the 2X2 studs in the ajoining side panels, there are no frasteners holding the side panels to the back panel at this time.
 - You will see in the picture that there is a 2X2 stud screwed from the inside to the panels ... this is the same for all three sides, the weight of the panel (minimal) is supported by this stud resting on the top of the combo unit framework.  You will need to measure to see where this stud needs to be.
 - Once I set all three panels in place on the shower/toilet combo unit, I carefully push the back panel into the dado grooves I cut then I use a piece of 3/8" plexiglass I cut into a strip long enough to span from one side panel to the other and this gets placed over a screw head sticking out of the top of the 2X2 studs on each of the side panels.  The side panels are now locked into place .. no tools used.
 - I put a conventional shower curtain/rod (I had to cut it shorter with a hack saw) across the front of the stall.  If you look close at the pictures you will see there is a plexiglass strip across the front of the shower stall as well to keep the assembly together.
 - Note in the pictures that there is a wood dowl sticking out of the weight bearing 2X2 stud, I drilled a hole through the stud into the frame of the shower/toilet unit once I have the stall set up where I want it.  There is another dowel on the opposite side panel.  Once the stall is set up, I just push the dowels into the holes to keep the unit in place
 - To keep everything looking tidy I used vinyl siding edge trim on all the edges ... before I completely tightened the laminated panels to the 2X2 studs.
 - I built the panels so they rest inside of the original shower/toilet unit and they overhang on the inside by about 1 1/2", this way water runs right into the unit where it belongs.
We have used this set up on a two week trip, and a weekend trip and have no problems or leaks.  Our kids get dirty and this is very convenient.  My DW loves to be able to user this set up better than the previous curtain set up.  No more waiting in lines for all the other ladies to pretty themselves up at the CG facilities.  We have a highwall camper and when I take the shower panels down I lay them on their sides and close up the camper, I would say it takes < 10 minutes to set up.
I hope this wasnt too wordy, let me know if you have questions.  Thanks for the intrest.
Offline smallcamper
  • Camper, 2nd Class
  • Gender: Male
    • NC [NC]
    • US [USA]
    • View Profile
« Reply #7 on: August 26, 2013, 06:13:25 AM »
Looks great, Rusty!
Could you post a few pictures showing some close-up  details of the attachment etc?
You've got me interested and now I need to go out and measure to see if the walls will stow in my non-highwall camper.  It looks like that vinyl siding edge trim adds quite a bit of thickness to the panel?  Just wondering about possibly stowing them on the bunks.
2014 Starcraft Comet 1221 [PU] [TV] 2012 Toyota FJ Cruiser
Offline Rusty
  • Camper, 1st Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #8 on: August 26, 2013, 06:26:40 AM »
I will have to get the pup out to take any more pictures.  I will do so when I have time, but this may take a while.  The vinyl edge trim adds very little to the thickness of the panels, it is the 2X2 stud/frame that stiffens it that give a little bulk.  I am able to reverse nest these when broken down, you can probably find a way to fit them in your pup.  There may be a better way to connect the whole unit together instead of the plexiglass, but it is what I had in my garage so I used it.
I have some materials left over, I can easily take pictures and post them with something for scale/size reference.
Offline colo-pr
  • Camper, 1st Class
  • Gender: Male
    • CO [CO]
    • US [USA]
    • View Profile
« Reply #9 on: August 26, 2013, 11:53:39 AM »
Thanks Rusty,
A couple of close pictures should be a lot helpful. I don't understand yet how to attach the panels to the shower? In the bottom by screws? Velcro? And to the roof?
Thanks a lot
Offline Rusty
  • Camper, 1st Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #10 on: August 26, 2013, 03:08:15 PM »
There is no fasteners or attachments of any kind to the ceiling. The assembly just sits inside shower combo unit and the weight of the shower wall unit keeps it in place. Think of how Legos fit together, only upside down and not so snug. The two wood dowels through the studs and into the combo unit are the only things needed to hold the assembled panels in place on the bottom.
Offline Twin Mom
  • Camper, 2nd Class
  • Gender: Female
    • CA [CA]
    • US [USA]
    • View Profile
« Reply #11 on: August 26, 2013, 04:52:44 PM »
LOVE IT!
Ford F150
2004 Fleetwood Timberlake
2 kids and 2 dogs
Offline dmullen
  • Camper, 2nd Class
  • Gender: Male
    • MS [MS]
    • US [USA]
    • View Profile
« Reply #12 on: August 27, 2013, 01:30:05 PM »
I have got to have this!  Looks great!  I would appreciate more pictures as well when you get a chance as some of this is over my head.  For example, what is a dado groove?
[PUT] 2014 RAM 1500 Quad Cab 3.92 8-spd HEMI
 [PUC] 2014 Rockwood 2560G
Offline Rusty
  • Camper, 1st Class
  • Gender: Male
    • IL [IL]
    • US [USA]
    • View Profile
« Reply #13 on: August 27, 2013, 04:45:13 PM »
I am off work tomorrow so I plan on posting some close ups of the materials I used. It is brutal hot right now and I may not pull out the pup,but the materials shots should help. A dado groove is simply a notch/channel cut the length of the stud that another piece will slide into. A table saw or very steady hand with a circular saw is used to make one or more passes (depending on how wide of a groove you need) for another piece to fit into ... in my case, the back panel. If you have a router and table, that would work very well. I will try to clarify more tomorrow (Wednesday).
Offline colo-pr
  • Camper, 1st Class
  • Gender: Male
    • CO [CO]
    • US [USA]
    • View Profile
« Reply #14 on: August 28, 2013, 12:28:52 AM »
This thread and the 3 way fridge are my favorites from all forum! ;-)
Love it, and more love it when I done it :-)
