12v at battery 2v at converter
Discussion in 'Wiring' started by E-Roy, Jun 18, 2019.
  1. E-Roy
    E-Roy New Member
    Jun 18, 2019
    Have issue with lights, water pump, working off AC but not DC. Troubleshooting led to replacing converter. Still no DC power. Battery tests good, wiring from battery tests good, but between the battery and converter voltage drops to 2v. Tested converter and it’s wiring and it seems to be proper. Any suggestions on figuring out where my issue is?
    2006 Fleetwood Cheyenne
  2. theseus
    theseus Centerville, OH
    2,796
    387
    Feb 6, 2007
    Centerville, OH
    What type of converter is it?
  3. MileHigh
    MileHigh Active Member
    429
    39
    Jul 18, 2012
    Denver
    Bad ground?
  4. E-Roy
    E-Roy New Member
    Jun 18, 2019
    WFCO 8725.
    Visually inspected ground and it looked OK. My brother has more knowledge on using meter and how to check, I’m the one with more familiarity of pop up. How would I meter check ground?
  5. MileHigh
    429
    39
    Jul 18, 2012
    Denver
    On the front panel of the 8725, are any of the blown fuse lights showing (or the reverse polarity fuse light)? Are you sure the battery is hooked up with the correct polarity? The negative cable should go to a chassis ground which should have a clean connection. I would also check all of the connections made between the 8725 and the individual 12 volt circuits.
  6. tombiasi
    5,068
    824
    If there is an inline fuse near the battery check the terminal connections for corrosion. If there is a resettable breaker check both sides to ground.
  7. rabird
    6,544
    246
    TX
    That means red probe to one side of breaker with black probe on trailer frame metal (not paint) meter set to DC volts 0-20v range. Do the same on the 'other' breaker nut/screw/terminal, should be same as battery voltage.
    you can do the same on the back of the converter, coleman uses a white connector, probe the red batt + and the white frame common -, you should also have full battery voltage on both sides of this connector. If you disconnect the white plug you may find the the red wire connects to black on the battery side of the connector.
