12v Battery Question
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by mpotapa, Nov 24, 2017.
  1. mpotapa
    mpotapa Member
    510
    Mar 11, 2014
    I recently purchased a 2018 Rockwood Roo 233s. I finally took it to storage and covered it and brought the 12v battery home. I checked it with my multimeter and got a reading of 7.78 or something along those lines. I decided to hook my battery charger up to it and the charger made a strange humming noise. After 10-15 seconds I took the charger off. The wires and alligator clips were real warm. I checked the battery again and it gave a .02 reading. I assume it fried the battery. Do you guys think my battery charger is also bad? This battery was brand new. I’m not sure why it read 7.78 in the first place. Any advice would be helpful.
  2. SteveP
    SteveP Well-Known Member
    1,305
    311
    Take the battery back to the dealer and ask for a warranty replacement.
  3. mpotapa
    mpotapa Member
    510
    Mar 11, 2014
    The only thing that sucks is the dealer is 2 and a half hours away. Not sure it’s worth it with the time and gas I would pay.
  4. theseus
    theseus Centerville, OH
    2,796
    386
    Feb 6, 2007
    Centerville, OH
    Are you sure you didn't have the wrong clamp on the post? Camper positive wires are black. White is the negative.
  5. rabird
    6,544
    246
    TX
    what does brand new mean and how long has it been connected to the PU?
    battery voltage should rise when charged correctly.
    The co/propane detector will drain a battery in a week or 2, if ya don;t leave the PU plugged in one typically disconnects the battery to prevent discharge. A tiny bit of battery care is needed for a battery to last a long time
    http://www.trojanbattery.com/tech-support/battery-maintenance/
  6. mpotapa
    mpotapa Member
    510
    Mar 11, 2014
    I don’t believe I did but I can’t be 100% sure. I do know that the battery is most likely shot. I guess I’ll have to buy a new one in the spring.
  7. nhlakes
    nhlakes Well-Known Member
    643
    317
    Oct 15, 2011
    DE and NH
    If 2.5hrs is too far, then you may consider calling or emailing the dealer to ask what you should do to have the battery checked out on warranty. I emailed a dealer many hours away about a battery and they told me all their batteries come from a certain national chain and to simply return it to my local store. Can't hurt to ask.
  8. mpotapa
    mpotapa Member
    510
    Mar 11, 2014
  9. bearman512
    bearman512 Well-Known Member
    1,200
    68
    Apr 17, 2010
    Albuquerque NM
    theseus likes this.
  10. tombiasi
    5,067
    821
    bearman512,
    I have that charger and I am very happy with it.
  11. bearman512
    1,200
    68
    Apr 17, 2010
    Albuquerque NM
    Problem is you cannot continue to trickle charge a wet battery without causing a decrease in the life of the battery. In the initial post his battery was below 8 volts and the only way to possibly revive it is by charging at at least 10 amps to heat it up.
  12. tombiasi
    5,067
    821
    There are a few rejuvenating techniques but usually below 8 volts is a goner.
  13. bearman512
    1,200
    68
    Apr 17, 2010
    Albuquerque NM
    Very true!
  14. mpotapa
    mpotapa Member
    510
    Mar 11, 2014
    Yesterday I actually charged it with the current charger I have at 10amps for a few hours. Today the reading was 12.3 so I plugged it in again for another 5 hours and I’ll check what it’s at again tomorrow. I assume it should be close to fully charged.
  15. bearman512
    1,200
    68
    Apr 17, 2010
    Albuquerque NM
    Sounds great you may have not damaged it to much but consider you may need to replace it sooner.[:D]
  16. tombiasi
    5,067
    821
    Sometimes you can get a top charge reading that won't hold up under load.
  17. bearman512
    1,200
    68
    Apr 17, 2010
    Albuquerque NM
    Indeed! But they might get lucky like I did and got 2 good years from a newb mistake.
  18. tombiasi
    5,067
    821
    I hope so.
  19. tombiasi
    5,067
    821
    Just for clarity, when I said I have that charger I was talking about the one you listed not the one he linked.
  20. Dback2k4
    Dback2k4 Active Member
    365
    172
    Jul 16, 2017
    Iowa
    Almost any auto parts store can test it to validate your results, but generally if it's only reading 7 volts then it's shot and can't be fully charged.
