1966 Westholt Camper
Discussion in 'Camper Restoration Projects' started by Westholt Wonder, Apr 17, 2018.
  1. Westholt Wonder
    Westholt Wonder Member
    36
    30
    Apr 17, 2018
    Well, I've wanted to get a little camper. Something small I can tow. Low-tech so there isn't much maintenance to keep up with. Came across this 1966 Westholt camper. It just looked like it had good bones! So now the overhaul/restoration begins!
    23632008_1579724125409187_5709861955375088595_o.jpg 23632263_1579723918742541_151939756254474780_o.jpg 23674950_1579724035409196_7827014746816126097_o.jpg 23674998_1579723915409208_304450584935907577_o.jpg
    23593646_1579723802075886_4859029571344122363_o.jpg 23622261_1579723655409234_8413964742529288861_n.jpg 23632687_1579723868742546_654548345351978726_o.jpg 23674952_1579723385409261_819060593909478450_o.jpg
    Tmackcj5 likes this.
  2. Westholt Wonder
    36
    30
    Apr 17, 2018
    Gutted!
    23593674_1579723925409207_4436376712345675401_o.jpg 23632034_1579724022075864_4239888444041312086_o.jpg 23632800_1579723995409200_5198367831710202096_o.jpg 23668877_1579723675409232_2950984370636580368_o.jpg 23755809_1579724138742519_4897719364128704041_n.jpg
    gail58 and gladecreekwy like this.
  3. Westholt Wonder
    36
    30
    Apr 17, 2018
    Sanding and prepping for paint. There is a lot of rust on this thing, so I decided to give the whole interior a coat of the Rustoleum rust reformer, which is the black. No it will not be black! :p I also removed the canvas to get it out of the way.
    28471916_1689586924422906_2792734892897658331_n.jpg 28576312_1689586937756238_4792681617019822559_n.jpg 29025733_1697855920262673_5582673082037829632_o.jpg 29027163_1697855716929360_3928950857344745472_o.jpg 29356447_1707187039329561_5659856174082686976_o.jpg 29425359_1707186979329567_201747979831345152_n.jpg
    omahadlr likes this.
  4. Westholt Wonder
    36
    30
    Apr 17, 2018
    Before I can really paint the inside, there were some holes that needed to be patched. I found a product called Quicksteel that is an epoxy putty that has worked pretty well in plugging the holes. After using that, a little bit of Bondo body filler over the top gives it a nice finish! I also removed the rock guard on the front and patched those holes as well. I have plans to put a diamond plate rock guard back on the front.
    29472725_1709671299081135_408845805286326272_o.jpg 29496061_1709671419081123_3740394500195876864_n.jpg 28827636_1711683678879897_399239837554462856_o.jpg 29060548_1711683675546564_5216813532586497017_o.jpg 26220829_1711683618879903_7801200121230878883_o.jpg 28954161_1713739485340983_4568405650447625223_o.jpg 29060489_1713739272007671_5360821697423759363_o.jpg 28954500_1713739558674309_618024859363404030_o.jpg
  5. Westholt Wonder
    36
    30
    Apr 17, 2018
    The exterior paint is very bad. I am taking it down to the metal. Spraying a lot of the areas with the rust reformer again and getting a quick coat of primer on it so it will be protected from further rusting. My main objective is to get the interior done first so I can start having my adventures! So I am just trying to get the exterior to a protected finish right now. Nothing fancy. I also uncovered the original logos which I was pretty excited about! I plan on having new decals made to put back on.
    24254795_1713739535340978_8404424683337970558_o.jpg 28953915_1711681365546795_5723588498166708165_o.jpg 29497856_1711681342213464_9028755646410171701_n.jpg
  6. Westholt Wonder
    36
    30
    Apr 17, 2018
    Got a looooovely surprise when I took the spare tire off. Ick! This called for some Bondo where rust had pitted out the metal.
    29352367_1720100831371515_3859584043866814561_o.jpg 29351826_1720100808038184_799226244353848238_o.jpg 29352049_1720100681371530_8244852091877604752_o.jpg 29872940_1720100621371536_5168538679172575961_o.jpg 29664775_1720100641371534_373529701574165712_o.jpg
  7. Westholt Wonder
    36
    30
    Apr 17, 2018
    Found another logo! Cleaned them up a bit so I can take them into a sign shop to have them done.
    30442700_1729641840417414_8883116683191910400_n.jpg 30441330_1729641723750759_8316512567300194304_n.jpg 30411690_1729641683750763_5313140390742720512_o.jpg
  8. Westholt Wonder
    36
    30
    Apr 17, 2018
    At one point new canvas was made. They moved the location of the twist snaps/fasteners and filled the old holes with a rivet. I have opted to removed those and patch the holes. It also appears that when you buy your camper from a hunter, that when they lose a spacer they use a bullet instead! :) I am getting all new shiny hardware for this thing, don't worry!
    30724727_1737010419680556_2860317849698697216_o.jpg 30724106_1737010453013886_4656223777019920384_o.jpg 30706456_1737008756347389_3793292842126802944_n.jpg
  9. Sneezer
    1,352
    389
    Very cool. Love seeing the older campers getting a new lease on life! Keep it up!
    Westholt Wonder likes this.
  10. myride
    myride Well-Known Member
    771
    345
    May 14, 2015
    Edmonton, AB
    Fabulous work! Will definitely be a topic of conversation once she's done. ....Let me get this straight.....young lady doing her own complete resto on her trailer....marry me?
    kcsa75 and Westholt Wonder like this.
  11. BikeNFish
    BikeNFish Well-Known Member
    2,220
    1,267
    Apr 24, 2017
    Maplewood, MN
    Very cool. [8D]
  12. jnc
    3,900
    1,142
    Oct 1, 2014
    South Central New Hampshire
    I cant wait to see the finished camper!
  13. DJS12354
    DJS12354 Well-Known Member
    1,533
    459
    Sep 21, 2017
    Love it!
  14. JPBar
    JPBar Well-Known Member
    1,863
    563
    Sep 22, 2016
    Texas
    Looking Great!
  15. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    Love the vintage campers...working on a 65’ Cox Campsquire myself, almost done
  16. omahadlr
    omahadlr Member
    97
    Jan 19, 2018
    Fairview Heights, IL.
    Great job! You go girl!
  17. neighbormike
    1,710
    898
    Oct 6, 2012
    WI
    What a great project!! Keep up the good work!
  18. Westholt Wonder
    36
    30
    Apr 17, 2018
    Thank you!
  19. Westholt Wonder
    36
    30
    Apr 17, 2018
    I can’t wait either!!!
  20. Westholt Wonder
    36
    30
    Apr 17, 2018
    You’ll have to show me your finished camper!
