1979 Venture Camelot
Discussion in 'Checkout My Rig !' started by 79venture, Jul 28, 2018.
  1. 79venture
    79venture Member
    61
    27
    Jun 24, 2018
    Detroit, Michigan
    Camp Driveway with my wife, two dogs, and Summer School is underway. System testing has commenced.
    1. Full setup (1st time).
    2. Boiled water on stove burner.
    3. Pilot light and fan working on furnace.
    4. Cleaned from top to bottom.
    5. Getting ready to make beds and a campfire.
    8A2147B1-9CF5-48F7-AA2B-27FFEBE31FEF.jpeg 77F77D68-3379-49F3-A998-0FFE9A39476F.jpeg 844F36C4-5218-43ED-9E90-97298E68A228.jpeg 0D73BE15-CD1C-4EA2-98AE-DC07F619753C.jpeg 18A438DB-BD4F-4EBA-B7CD-F98818CB1887.jpeg
    Rik Peery, hq308, jnc and 1 other person like this.
  2. Raycfe
    14,240
    1,017
    Is that 2 dogs or a puppy and a toy?
  3. 79venture
    79venture Member
    61
    27
    Jun 24, 2018
    Detroit, Michigan
    That’s two. Emilia is on the left and Phoebe on the right.
  4. sceri
    sceri Active Member
    113
    58
    Jun 1, 2018
    Washington State
    That camper is AWESOME! It's in very fine shape....
    Happy camping....
    79venture likes this.
  5. jmkay1
    4,172
    1,079
    Can you get a close up to that swing out? When I saw it in the brosure I wanted to see it up close. The camper looks to be in great shape considering the age. Color scheme is not as "loud" as expected either.
  6. emoney
    emoney Well-Known Member
    880
    443
    Jul 7, 2018
    That Swing Out is awesome and they were obviously way ahead of their time. Kudos for the find!
  7. neighbormike
    1,757
    973
    Oct 6, 2012
    WI
    Great camper! Thanks for sharing the pics!!
  8. 79venture
    79venture Member
    61
    27
    Jun 24, 2018
    Detroit, Michigan
    I’m amazed at the condition of this almost 40 year old pup.
  9. sceri
    sceri Active Member
    113
    58
    Jun 1, 2018
    Washington State
    Sorry, but I (I'm sure "we") would love to see photos all around that camper. The shape it's in and the uniqueness of it is really cool to see....
  10. 79venture
    79venture Member
    61
    27
    Jun 24, 2018
    Detroit, Michigan
    Sceri, no need to be sorry. What would you like to see?
    First thing I used the stove for was a full 9 cups of coffee. The firewall was warm, but heat didn’t transfer to the canvas area of the window. Very happy about that.
  11. jnc
    3,904
    1,145
    Oct 1, 2014
    South Central New Hampshire
    How do you raise the galley?
  12. jmkay1
    4,172
    1,079
    I got to say the slide out kitchen is awesome. They should do something like that in today's campers. I agree with the above comment, way beyond it's time.
  13. 79venture
    79venture Member
    61
    27
    Jun 24, 2018
    Detroit, Michigan
    There are a couple of eye bolts with retainer hooks near the bottom of the pedastal, and a slide bolt on the top pedastal located by the door frame (green mark). Once unlatched simply lift up by a handle behind the stove top.
    jnc likes this.
  14. 79venture
    79venture Member
    61
    27
    Jun 24, 2018
    Detroit, Michigan
    JNC - I have a question about stabilizers. For the life of me I cannot get them to be taught to the pad. My father, and another member suggested lowering the rear stabs first and get them taught, then lower the wheel jack to get the front ones taught. Would doing his put unwanted stress on the frame?
    Or, am I doing it right by having this gap allowing the pup to sway when stepping into it?
  15. jnc
    3,904
    1,145
    Oct 1, 2014
    I dont have any experience with that type of Stab. You do need to make contact with the ground to stop the wiggle. My only thought is to use shims to take up the slack. Or replace them with the Scissor jack type. What ever you do dont put weight on them. Hopefully someone that has those Stabs will chime in with more info.
  16. 79venture
    79venture Member
    61
    27
    Jun 24, 2018
    Detroit, Michigan
    Good to know that there needs to be contact. I’ll try the rear contact then lower front method. Most definitely don’t want them to take weight. Thank you!!!
  17. sceri
    sceri Active Member
    113
    58
    Jun 1, 2018
    Washington State
    The front, rear, sides, inside. Love vintage campers and yours is one of the coolest I've seen....[Guitar]
  18. Sjm9911
    2,980
    1,259
    I would add another board to the ground easier!
  19. Sjm9911
    2,980
    1,259
    Unless it just clicks down, then shim it. Cut 4 boards to take on your trips!
  20. jmkay1
    4,172
    1,079
    The stabilizers on my old Jayco was kind of similar but different as well. Once I brought the leg down I had to pull the foot down until it hit the ground and then I used a rod in a hole and I believed pulled upward to essentially cinch it up to lock in place. When I was ready to go I had to step on a lever in the front of the stabalizer and it released. It's kind of hard to tell if yours is similar to that process. It kind of looks though that your stabilizer still has more to go down, could it be stuck or does it look like it's as far as it goes.
