1988 Coleman Laramie
Discussion in 'FreeCycle' started by rich2, Feb 15, 2018.
  1. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    Getting ready to gut a 1988 Coleman Laramie in a few weeks, this camper is pretty much all there expect for the mattresses, cushions and the frame which I am using for an other project. I am located in the Allentown, PA area, if anyone needs any bits and pieces let me know.
  2. mrkrag
    mrkrag Active Member
    127
    37
    Dec 22, 2017
    Palm Harbor, FL
    SUPER interested in the caps for the water jugs. I have the jugs, but PO lost the small and the large caps for both water jugs. Nothing else I've tried fits under there as well without giving up capacity, and no other caps I've tried fit.
  3. DavefromSunbury
    DavefromSunbury New Member
    17
    Feb 28, 2018
    Do you still have the door?
  4. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    Yes...inside panel needs some work, but it is solid
  5. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    No.....you do, hope it all worked out. No one else seems interested so time to demo....
  6. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    Not sure what you mean by caps????
  7. mrkrag
    127
    37
    Dec 22, 2017
    Palm Harbor, FL
    lets see if these pics come through
    this is it in the parts manual. there are two 5 gallon white plastic jugs for the portable fresh water.
    this is the bigger opening
    and this is the vent
    2 edits so far..
  8. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    Do not believe that is any where onboard...where would it be located
  9. mrkrag
    127
    37
    Dec 22, 2017
    Palm Harbor, FL
    they are under the sink if yours had them.
  10. Mark1
    Mark1 New Member
    Apr 26, 2018
    I have a 1988 Laramie LTD and I was wondering if the front body panel is still in good shape on yours? Mine has been broken at the corners from the pervious owner. Also, do still have the faucet?
  11. rich2
    rich2 Active Member
    185
    69
    May 3, 2007
    Northampton, PA
    Front body panel is already gone, will check but I think the same guy got the faucet but will check in the morning as I am at work.
  12. Mark1
    Mark1 New Member
    Apr 26, 2018
    I appreciate it, but I was able to find a faucet on ebay. It is supposed to be new old stock. As for the panel, if I am not able to find one, I guess I will have to remove it and reinforce it with fiber and fill to holes with body puddy. Thanks any way.
  13. tzmartin
    tzmartin Well-Known Member
    876
    321
    Sep 9, 2015
    A guy was looking for a front plastic panel. Your panels might be compatible with his. He posted in the For Sale and Wanted section of the portal.
  14. DavefromSunbury
    17
    Feb 28, 2018
    Rich, finally got around to replacing the front and side panel. Thanks a million. The facelift did her good.
    Still have my "well used" canvas if anyone is interested.
  15. DavefromSunbury
    17
    Feb 28, 2018
  16. Mark1
    Mark1 New Member
    Apr 26, 2018
    The front panel is just what I am looking for, do you still have it and if so how much do you want for it?
  17. Jerry Bransford
    Jerry Bransford New Member
    Nov 28, 2018
    Looking for the water jug itself shown in the above photos, I don't need the caps. Please let me know if you still have it. My email address is jerrypb@cox.net
