1993 starcaft pop up camper
Discussion in 'Introduce Yourself' started by KrissyAW, Sep 7, 2018.
  1. KrissyAW
    KrissyAW New Member
    Sep 7, 2018
    Okay so my husband and I are very new to owning any type of camper, so we have a 93 Starcraft pop up camper it's in great shape the previous people barely ever used it they had bought it from a friend that had never used it and he had had it since it was brand new. Since buying it the weather is getting a little colder we've tried to turn on the heater and can't seem to figure it out I've read through all of its post on this forum trying to figure it out and we follow the manual and tried some of the ideas on this forum and I still have had no luck on the propane lines are definitely working you can smell the propane it just isn't lighting. Also our power works as long as we plug it in but we went out and bought a new battery for the camper (deep cycle) and cannot get the power to work with the battery weve blown three fuses when plugging them in. The camper store told us to use 30 amp fuses and it's still blowing them! So I guess I'm just looking for some guidance on troubleshooting since I literally know only one person that has a pop-up camper and has no idea how to help us out, I can't afford to take it into the camper store to have it looked at they charge $120 an hour so any help would be much appreciated thank you for your time.
  2. BikeNFish
    BikeNFish Well-Known Member
    1,778
    1,005
    Apr 24, 2017
    Maplewood, MN
    I have limited knowledge on your issues and, unfortunately, I cannot help you too much. Others will chime in on the furnace as well as the electrical as the day progresses. You have come to the right place for your questions.
  3. joet
    3,561
    515
    Welcome from the West Virginia mountains
  4. Raycfe
    13,887
    920
    Greetings from the eastern Connecticut shoreline.
  5. megcabra
    megcabra Well-Known Member
    Welcome and greetings from North Carolina to the exciting world of Pop-Up camping!
  6. Pnut
    Pnut Member
    52
    23
    Jul 8, 2018
    NE Georgia
    I can't help with the heater but when you hook up the battery the black wire is positive and the white is negative. Hopefully someone else will chime in and help you with your heater. Welcome from Georgia.
  7. nineoaks2004
    5,692
    2,011
    Graceville, Florida
    Welcome From N/W Fl Panhandle, congrats on the NTU PUP. If you can smell propane you probably have a leak somewhere, that can be very dangerous and need to be checked, there are ways to check I have found that a small jar of bubble soap (like the kids use to blow bubbles) is cheap, then a small brush, just brush it on and watch for the bubbles, when they show up you have found the problem. Also when turning the LP on, turn it really slow or the safety will kick in. It is usual to light the stove for a few minutes to get the air out of the lines and this may take a few minutes too. If you are blowing fuses, it is not a good idea to "overfuse" If there is a direct short to ground it can cause a fire.
    Good Luck and Happy Camping
  8. DJS12354
    DJS12354 Well-Known Member
    Greetings from NEPA!
  9. kcsa75
    kcsa75 Well-Known Member
    1,817
    694
    Sep 9, 2013
    Kansas City
    Congratulations on the NTU Pup and Welcome to the forum from Midway USA. [:)C]
  10. Shaman1
    Shaman1 Well-Known Member
    1,334
    164
    May 13, 2011
    Oklahoma City, Oklahoma
    Welcome from Oklahoma. When you say you've blown 3 fuses, do you mean 3 fuses to one circuit or 3 different circuits? Definitely don't over fuse. Do these fuses blow when on shore power?
