1997 Coleman Westlake Body Panel and Roof Repair
Discussion in 'Roof/Floor Repair & Maintenance' started by Austin JC, May 22, 2019.
  1. Austin JC
    Austin JC New Member
    May 21, 2019
    My family has owned this camper for many years. I recently tried fixing the cracking ABS roof with the MEK and ABS method, but the cracks continue to appear after a few weeks of being filled in. I believe the next step would be to rip off the ABS layer and use grizzly grip or truck bed liner paint. Any suggestions on this would be much appreciated.
    Another inquiry I had was about fixing the front body panel. My father had hit part of the camper with the lawn mower a week ago, leaving a large dent in the metal side panel, and a hole/crack in the front piece. For this, I am thinking about buying a fiberglass repair kit and patching the hole. I was hoping for advice on this as well. I attached an image of it. POPUP CAMPER #2.jpg
  2. tzmartin
    tzmartin Well-Known Member
    849
    297
    Sep 9, 2015
    Geeze! Thanks a lot, Dad. Colemanpopupparts.com had a few whole body parts that may work. if you don't want to shell out the money...a hammer and MEK repair will be your best shot.
  3. Shaman1
    Shaman1 Well-Known Member
    1,935
    396
    May 13, 2011
    Oklahoma City, Oklahoma
    I would straighten the side and replace the front with diamond plate.
  4. mstrbill
    mstrbill Active Member
    674
    141
    Mar 17, 2013
    Austin , Texas
    That's the problem with using MEK/ABS goo, it's a weak bond. I would(and did) use a ABS rated epoxy like Plastic Welder or Fusion. The bonding strength IIRC is something like 3000-4000 PSI. I wouldn't remove the ABS if it is only slightly delaminated. if it has a lot of delamination, then that seems to be what people are doing. I would also check of the other ABS repair topics, other new coating products(don't remember names) have been found that may be better than GG.
  5. Sjm9911
    3,315
    1,548
    Second the motion for if it has lots of delamination to remove it. My abs fix held, unfortunately the areas around it broke. I liked the gg. I will probably get it again.
