2001 Coleman Bayside Elite
Discussion in 'Camper Restoration Projects' started by kmbarreiros, Oct 6, 2017.
  1. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    Front frame prepped. Ready for the floor to go in.
    jnc likes this.
  2. Fless
    Fless Active Member
    930
    184
    Aug 14, 2012
    Colorado
    You can find a lot of good info here just searching for whiffletree maintenance or lubrication. I think you'll find that silicone is not a sufficiently robust lubricant and that in order to maintain ease of raising the roof, and to minimize wear and tear on the lift system, the whiffletree will have to be greased.
    _
  3. Thisday
    Thisday New Member
    Oct 29, 2017
    I also have a 2001 Bayside Elite. Luckily we haven't had to make the extensive repairs you have, but I've enjoyed your pictures. I like seeing how it's constructed underneath, thanks!
  4. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    Thanks fless, I should have stated I do plan to do that. I have the cover off right now because I am repainting it. When I put the cover on I will grease it up.
    I was just more impressed how much easier it turned just by cleaning it up a little bit.
  5. ryguyFam
    ryguyFam Member
    38
    Apr 17, 2018
    South Central New Hampshire
    Nice work! How are you repairing the cover? You're talking about the back plastic right? I have to fix mine after my accident lol.
  6. Zombieitch
    Zombieitch Member
    61
    Oct 18, 2014
    Wow...
    I have started the process on rebuilding the front box on my bayside, it's not quite as far gone as yours is. I should start my own thread for my project.... The progress will not be as quick as yours.
  7. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    I am referring to the metal cover underneath the frame. That is the part that I am repainting.
    ryguyFam likes this.
  8. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    Quick lol you may want to check the date of when this project started. I still have a long way to go and my next two weekends are tied up.
  9. Zombieitch
    Zombieitch Member
    61
    Oct 18, 2014
    I've had mine for 3 years so and I'm just getting to repairing the pvc areas. It appears the storage area I had it at flooded and I also have some rear curb side repairs to do.
  10. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    Nice I should have said that when I started posting is when I brought this thing home. So I have never camped in it.
    And yeah seems like all these early 2000 pop ups have similar issues.
  11. Sjm9911
    3,625
    1,763
    Man, hang in there, it will be nice when it's finished ! Just bought some thing similer , ill need your guys help! So , positive thinking! Worse comes to worse, we can combine all the 2000s and get one good pop up put of them
    kmbarreiros and ryguyFam like this.
  12. Stang65fst
    Stang65fst Member
    84
    33
    Dec 13, 2017
    Iron Station, NC
    Always an adventure, keep it up it pays off.
  13. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    Ok so the past couple of weeks have been kinda of a bust and the first weekend that I home it is going to rain.
    I did moved the popup into my driveway and have done the following:
    Removed the front bed some more of the inside walls, the fresh water tank and the hot water lines, all the AC wiring, the bump out, some of the propane lines and removed the top rubber seal.
    I also test fit the front floor I had already known that I cut the floor too short and plan to make a spacer for the gap.
    My brother in law may be coming by tomorrow (again depending on the rain) to spend hopefully the whole day on it.
    I have also decide I am going to basically rewire the pop up now that I have figured out the wiring.
    jnc and ryguyFam like this.
  14. ryguyFam
    ryguyFam Member
    38
    Apr 17, 2018
    Keep it up! You'll get there :)
  15. Sjm9911
    3,625
    1,763
    Wow! I look forward to seeing it done, and how you do it!
  16. whitelabrat
    whitelabrat New Member
    Feb 12, 2017
    I have the same camper and will need to do the same front-end work you're doing. Good luck and keep the posts comming!
  17. Scotty boy
    Scotty boy New Member
    Feb 12, 2019
    Race is on. We bought 2001 Utah, front storage is too cracked to repair, so it all needs to go. We are pulling everything out to redo floor, back driver side needs rebuild from water leak, and roof needs redone.
    For the front storage box I can’t decide whether to learn how to weld aluminum, or how to fiberglass. Either way I’m remaining optimistic I will be able to get a few late fall trips this year. We will start our thread soon.
    Has there been any progress on this project?
  18. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    Unfortunately nothing whatsoever, it currently sits on the side of my house waiting for my father in law to move his truck out of my driveway.
    Wife states can't have two projects in the driveway.
    As it sits right now.
  19. 4 Temps
    4 Temps New Member
    May 6, 2019
  20. kmbarreiros
    kmbarreiros Member
    68
    21
    Jun 17, 2014
    Fairhaven, MA
    Finally some progress.
    Removed the axle and tore it down, scraped and painted with Rustoleum primer.
    Will need to get a new bearing set. The drums, and drum brake mechanics seem fine.
    The axle does have a little bend to it but I won't sweat it.
    I am also planning on flipping the axle to put the springs on top.
