2001 Palomino Pony Heater won't go on
Discussion in 'Heating / Cooling Systems' started by bones64, Oct 5, 2010.
  1. bones64
    bones64 New Member
    Oct 5, 2010
    Hello Everyone,
    I am new to this site and to PUP. I bought a used 2001 Palomino Pony pop up. It is in my driveway plugged in and I also have a brand new propane tank on it. I am able to light the stove so I am getting propane through the lines. I am unable to get the furnace to work though. Does anyone have any experience with this on a Palomino? I would greatly appreciate any and all ideas.
    Thanks in advance!!!
    Jeff
  2. EastBeast
    EastBeast NO soup for you!
    183
    Jul 20, 2010
    Hello and welcome from Maine! Congrats on the pup. :)
    I don't have much to offer regarding the furnace. I'm sure the answer is here.
  3. pony280
    pony280 Pony 280
    118
    Apr 15, 2010
    What happens when you try to turn on the furnace? Does the fan come on with no heat, or is there nothing at all? If there's no fan, check the fuses that run the furnace fan to make sure one isn't blown.
    My Pony is newer, so I'm not sure what procedure you use to turn on your furnace -- do you just slide the thermostat to a warmer setting or do you have a pilot light?
  4. yogi
    yogi New Member
    708
    Aug 13, 2008
    Portland, Oregon
    Welcome to the Portal from Portland, Oregon! [:)C]
  5. bones64
    bones64 New Member
    Oct 5, 2010
    I spoke to a service shop and they had me take off the thermostat and directly connect the wires to see if it would work. It did, so it looks like I need a new thermostat. It is one that turns on directly when you turn up the heat. No pilot light.
  6. pony280
    pony280 Pony 280
    118
    Apr 15, 2010
    Sounds like you got your answer! Should be an easy fix. Happy camping.
