2003 Ford F150
Discussion in 'Tow Vehicles, Hitch & Towing' started by jumpoff, May 9, 2017.
  1. jumpoff
    jumpoff I'm in a camping state of mind
    1,552
    181
    Nov 3, 2015
    North East Florida
    I just recently purchased a 2003 Ford 150 Super Crew with a 4.6 and a 3.55 rear end. Does anyone have this setup ? I'm thinking about selling my Sierra and just going with this as my tow vehicle. I have a Coleman Utah which loaded weighs around 3000 lbs.
  2. theseus
    theseus Centerville, OH
    2,579
    276
    Feb 6, 2007
    Centerville, OH
    I have the 4.6 engine in my 04 Expedition. It tows great. I'm sure you won't have any problems with towing 3000 lbs. with it. My Bayside is well over 3000 and I have no problems.
  3. JPBar
    JPBar Well-Known Member
    1,855
    558
    Sep 22, 2016
    Texas
    I have a 2006 same set up. I just turn off the overdrive when pulling my camper, no issues.
  4. silvermickey2002
    4,316
    206
    Sep 11, 2008
    Morris County, NJ
    I had a 2002 F150 with the 4.6 and it towed great. Had to keep looking in the mirrors to see if it was still back there [;)][;)]. When towing in flat areas on the open highway I left the overdrive on. But when I got to hilly areas I shut it off.
  5. bols2Dawall
    bols2Dawall S.W. Ontario
    1,362
    100
    May 19, 2010
    Lasalle Ontario
    You could easily tow 2 of those Pups [8D]
  6. jacrabbitt
    jacrabbitt Active Member
    231
    50
    Mar 27, 2015
    Michigan
    What Micky said. With 355 gears you won't even know it's back there.
  7. jumpoff
    1,552
    181
    Nov 3, 2015
    North East Florida
    Thank you all. I feel more confident now. I think it has a factory installed tow package. The overdrive suggestion was good too. It's flat in North East Florida but my favorite camping is in the mountains in Western North Carolina. I bought the truck with 149k on the odometer. If there is anything mechanically I should be aware of please let me know.
  8. silvermickey2002
    4,316
    206
    Sep 11, 2008
    Morris County, NJ
    Keep an eye on the exhaust manifolds I know the 2002 4.6 had issue with them. They rusted out on mine real bad! There were dime sized holes. I wanted to replace them myself but was warned about the bolts being rusted and they would break in the head. Just be aware. Not sure if they corrected the issue on the 2003 models. Also keep an eye on the radiator support frame. I ended up replacing mine. If it does rot out and breaks you will have an issue. Inspect the rear spring shackles for rust. One of mine broke and luckily when it broke it got caught on the frame. They are an expensive item since we could only find them from Ford.
    I also had the trans rebuilt at 123K because 1st gear started to slip.
    Overall I loved that truck!! I miss driving it!!
  9. jumpoff
    1,552
    181
    Nov 3, 2015
    North East Florida
    Thanks Gary... I'm going to check those components out that you mentioned.
  10. Halford
    Halford Well-Known Member
    3,449
    444
    Sep 28, 2011
    Santa Clarita, California
    It may not be that important that you bought F150 with 3.55 gear, your Utah max GWVR is 3500 lbs. My 2013 Explorer with 3.5 V6 easily tow my 2002 Niagara (3500 Lbs) so your F150 can easily do it.
  11. jumpoff
    1,552
    181
    Nov 3, 2015
    North East Florida
    I was wondering about the power though as the 4.6L I think only has 220HP. But since you guys have assured me that it tows great I'm going to forget about the low HP rating.
  12. silvermickey2002
    4,316
    206
    Sep 11, 2008
    Morris County, NJ
    I had the F150 XLT Supercab with long bed and 4WD. The 4.6 had plenty of power!!!
  13. jumpoff
    1,552
    181
    Nov 3, 2015
    North East Florida
    Thanks again Gary for all your input. I went to Ford's info page from 2003 and it's rated for 6500lbs. I just wanted to hear from people that actually towed with one though because I know you guys on the portal would talk straight and speak through your own experience.
  14. WrkrBee
    WrkrBee Well-Known Member
    924
    334
    I'll jump off this thread again. I tow a 2018 Aliner Scout (1,600+ lbs) with a 1997 F150 4.6L 2wd with no tow package, 130K miles. I can tell it is behind me, but not in a bad way. I stay at 65mph on the interstate, but prefer to take back roads, if we can. We are retired, so time is flexible.
    Two weeks ago, I took it took it to a transmission shop for a wellness check (after a week camping trip in Florida). Filter and fluid was changed. I had them add an fluid cooler for extra insurance. He said said it was clean inside and he would drive the truck any where. I asked about overdrive use, which I did some in Florida on flat terrain. He said as long as it is not searching, overdrive is fine.
  15. jnc
    I have a 05 explorer with the 4.6 and it has 200000 on it. I love using it to tow the pup when I am not taking the 4wheeler with us.
  16. nineoaks2004
    5,710
    2,016
    Graceville, Florida
    I have a 2004 F 150 with tow package except I have the V8, you will have no problem pulling with the set up you have.. Good Luck and Happy Camping
