2004 coleman niagara elite water pump
Discussion in 'First Time & New Camper Owners' started by Chris Leasure, Feb 12, 2019.
Tags:
  1. Chris Leasure
    Chris Leasure New Member
    Feb 12, 2019
    I just bought a 2004 coleman niagara elite last week Everything worked perfectly when I bought it. Checking everything out just now and the water pump won't come on at all Tried 120 and 12 volt, switch is on, sink/stove are in the upright position and the tank is full. Checked all 4 fuses on the converter, but all are good Am I missing something??
  2. BikeNFish
    BikeNFish Well-Known Member
    1,920
    1,072
    Apr 24, 2017
    Maplewood, MN
    Check to see if it has a filter screen or filter and make sure it is not clogged. Maybe filling the water flushed something through the lines.
  3. Chris Leasure
    Feb 12, 2019
    Checked, but no dice. Thanks though
  4. PopUpSteve
    PopUpSteve Administrator
    17,732
    867
    Dec 22, 2002
    Malvern, PA
    Water in the tank?
  5. Chris Leasure
    Feb 12, 2019
    Yeah, completely full
  6. GreyFox
    GreyFox Active Member
    303
    112
    Oct 10, 2018
    S Ontario
    In any Fleetwood camper I've owned that had a water pump there was a 7.5 amp inline fuse in the + near the pump. Pump won't run if it's not seeing +/- 12 vdc so time to break out the voltmeter and see if it is.
  7. Chris Leasure
    Feb 12, 2019
    Thanks, I'll give that a shot
  8. jmkay1
    3,807
    846
    Could the switch have gotten gummed up. Sometimes you have to play around with the switch a few times to get the full connection. When you crawl in the slide out where the pump is located do all the appropriate wires and hoses appear attached?
  9. Chris Leasure
    Feb 12, 2019
    The switch seems fine (not sticky and toggles off and on fine). Right now my issue is that I can't seem to find the actual pump. I've crawled under, traced all the water lines, pulled the drawers out from under the sink, etc. Can anyone tell me the location?
  10. jmkay1
    3,807
    846
    . The pump is actually hiding inside the step to the slide out. There are about 5 screws you need to undo on the kickplate and the pump is behind that.
    Chris Leasure likes this.
  11. Chris Leasure
    Feb 12, 2019
    Thank you so much! I was starting to wonder if I was going crazy.
