2005 Jayco Jay Series heater won't work
Discussion in 'Heating / Cooling Systems' started by AKPup, Jun 23, 2011.
  1. AKPup
    AKPup New Member
    Jun 23, 2011
    We have a new to us 2005 Jayco Jay series pop up. We cannot get the heater to work. It has an autopilot, and when we take the cover off the heater we can see it trying to light, the blower comes on, it tries for about 30 seconds, won't light and shuts itself down. The propane is on and working, the stove works great. The owners manual is no help, any ideas??
    Thanks!
  2. Unstable_Tripod
    14,279
    24
    May 20, 2008
    Seattle, Washington
    When my Yuma's furnace had that set of symptoms the problem was a faulty igniter.
    BTW: autopilot???
  3. AKPup
    AKPup New Member
    Jun 23, 2011
    Guess I should have said "auto ignition" [:D]
    Thanks for the reply!
  4. Silverstone
    Silverstone New Member
    47
    May 2, 2010
    Do you remember the make of the furnace? ie: Atwood or Suburban?
  5. AKPup
    AKPup New Member
    Jun 23, 2011
    It's an Atwood hydro flame.
  6. Silverstone
    47
    May 2, 2010
    Okay, So you're saying that it shuts off after unsuccessfully trying to ignite. When that happens there should be a small led on the circuit board right behind the front cover that flashes a code. either one flash every three seconds, two flashes or three flashes. Take a look and see. that will narrow down the problem.
  7. hvac1877
    hvac1877 Old Dominion Iron Chefs Highland Springs, Va
    2,885
    45
    Mar 10, 2008
    Highland Springs Va
    if it shuts downafter it doest fire could have a pluged pilot tube, a weak spark iganitor,weak or bad ground, bad gas valve
  8. AKPup
    AKPup New Member
    Jun 23, 2011
    We could see the light on the circuit board flashing 3 times every 3 seconds, after if failed to light. On the heater it says that code means "ignition lockout fault". Any ideas what that means?
  9. Silverstone
    47
    May 2, 2010
    Ignition lockout basicaly means that the heater has sensed a problem with the ignition. a few things could cause this, even things as simple as a spider web or build up of dust. What I would do first is take the heater out and give it a good clean. failing that I agree with HVAC1877.
  10. rabird
    6,537
    244
    TX
    See Page 30 for trouble shooting
    http://bryantrv.com/docs2/docs/hflamefurn04.pdf
    "If the flame is not
    sensed after approximately six seconds, the board
    will lock out (three try for ignition, one hour lockout
    and then three retry), shutting off power to the
    valve."
    "A HARD lockout requires reset of
    the thermostat or turning the power switch off then back on."
  11. AKPup
    AKPup New Member
    Jun 23, 2011
    Thanks for the replies!
