2006 Viking 2308ST - HELP!!!
Discussion in 'Lift Systems' started by MLC, May 18, 2019.
Tags:
  1. MLC
    MLC New Member
    May 17, 2019
    We just bought a 2006 Viking 2308ST pop up. This is our first camper. The crank is in the back and the rear left corner does not lift when cranked - the other 3 go up great, but we can push up that corner. Problem is that it gets up a couple feet and then the crank can’t be turned anymore. It was VERY hard to turn too. It goes down with no issues. Any idea how to fix either of these issues?
  2. PopUpSteve
    PopUpSteve Administrator
    18,552
    1,399
    Dec 22, 2002
    Malvern, PA
    Where did you purchase the camper and has the lift system ever worked for you?
  3. MLC
    MLC New Member
    May 17, 2019
    We just bought it super cheap from a friend of a friend. The lift system used to work perfectly- just not for us. It was like that when we bought it.
