2010 Rockwood Freedom popup leaky water faucet
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by sledward, Oct 6, 2018.
  1. sledward
    sledward New Member
    Oct 6, 2018
    Inside the camper the water faucet will not stop the water from running. To replace the problem is it a big job or can a person do the job themself?
  2. Raycfe
    14,245
    1,017
    Greetings from the Connecticut shoreline. We are glad you stopped by. Many really helpful people here. How can you help get the right answers? Just tell us more. If you faucet is like a household faucet, it is very easy to replace. The factory ones are usually plastic junk which break easily. You can replace them with a better made one. Shut the water off, unscrew and mark the hoses, and remove the nuts holding the faucet down. You will have to measure the distance between the holes in the counter top, usually 4 inches like a bathroom faucet.
    Now if you have a hand pump faucet ..... shut the water off .... and carefully take it apart ..... there maybe a stuck or dirty valve inside.
    Replacement hand pump faucets usually cost more than they are worth.
    If you only use a "city water" (hose to outside of camper) I would replace it with a bathroom faucet. With that said adding a electric water pump would be super easy as well. The electric pump would go to the hot side the city water to the cold side. Just something to think about.
