2016 Kia Soul pulling popup
Discussion in 'Tow Vehicles, Hitch & Towing' started by Stacy68, Jun 19, 2018.
  1. Stacy68
    Stacy68 New Member
    Jun 19, 2018
    I am looking at a 2000 Coleman Sedona. My Kia will pull 2000 lbs with a 200lb tongue weight max. I see so many different weights. Can someone help? Can I tow this?
  2. Snow
    9,418
    647
    What is the GVWR of the trailer ? Start with that. . and how many people in the tow vehicle?
  3. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
    The 2000 Sedona is 2200# gvwr with 165# tongue weight. The Base weight is 1534# Than add all the extras and you are at the max you can haul without any camping gear. So this is not really a good camper for you. You would be better off with a Taos of the same vintage Because they max out at 1500# & 135# on the tongue.
  4. Raycfe
    14,020
    956
    Your not going to pull or stop it with the Soul.
    WVhillbilly likes this.
  5. JiffyPopJunkie
    JiffyPopJunkie Active Member
    283
    74
    Jun 5, 2014
    LG Region NY
    Hi Stacy and welcome to the Portal! As others have said the Soul is just not the right fit to pull a Sedona. I mean, yeah you can hitch it up and hit the gas and youre going down the road but It would put a lot of stress on the car and the biggest factor would be road safety. Hopefully you can find something that can work for you and the Soul.
  6. seldomseen380
    seldomseen380 Active Member
    367
    107
    Jan 12, 2007
    Canton, Georgia
    +1 on the Taos...
    I pulled a Taos, loaded with gear, with a 4 cylinder SAAB with no problems.
    I did utilize the trailer brakes, that was a must.
  7. mattlreese
    mattlreese Active Member
    133
    32
    Sep 6, 2017
    There are 1300 lb small popup you can tow, but that's about it.
    2000 lbs is trailer and all cargo weight both in the trailer and the car.
