2018 "Not a Rally" - Schodack Island State Park
Discussion in 'Rallies Being Planned' started by stefie19, Oct 1, 2017.
Which weekend works for you?
Poll closed Dec 1, 2017.
  1. April 27-29
    3 vote(s)
    60.0%
  2. May 11-13 (Mother's Day weekend)
    2 vote(s)
    40.0%
  3. June 1-3
    1 vote(s)
    20.0%
Multiple votes are allowed.
  1. Strawhouse
    Strawhouse Well-Known Member
    1,179
    337
    Oct 4, 2015
    Muskoka, Ontario
    Thanks for the heads up! I’ll look it up in the instructions and let you know if I’ve been successful.
  2. shelmily
    shelmily Well-Known Member
    3,252
    237
    Jun 7, 2012
    Northeast Pennsylvania
    We got home around 1:00 pm no hassles other than it rained and was pretty windy most of the way home, which made for some exciting driving at times. Despite the weather though, we had a good time. We always do with this gang. It was nice to meet some new people too. I hope Richnyo and Junkyburittos weren't too scared of us, and will join us again some time.
    Jimmy, I think you did a little more than straighten up some wires! I just wish I could have helped more than holding wires for you.
    Pat, I'm glad you had a safe trip, by why on earth did you take 88 to 81, you added a good 2 hours to your trip. I should have left you know 84 and 81 were both open and flowing free when we went through.
    I will see everyone at the NEPA rally in a few weeks, lets hope for some better weather!
  3. Strawhouse
    1,179
    337
    Oct 4, 2015
    Muskoka, Ontario
    So...
    If you have incontinence problems, you should prepare yourself before reading on.
    For those of you who were not at Steph’s Not A Rally, you need to know that Dave and Deb shared their experiences from their visit to Uranus, Missouri. Many references—and laughter—were made over the weekend.
    I was going to bring some to the NEPA Rally as a surprise; however, it’s only available from Nov-Jan. Produced by Sawmill City Brewery, Gravenhurst ON (30 min from my place):
    https://www.sawdustcitybrewing.com/our-beer/long-dark-voyage-to-uranus-uranal-imperial-stout/
  4. Strawhouse
    1,179
    337
    Oct 4, 2015
    Muskoka, Ontario
    It’s only 21 min longer according to Google Maps.
  5. JimmyM
    JimmyM Well-Known Member
    2,206
    444
    Jun 5, 2014
    Franklin, MA
    Having you guys there was a lot of fun. Some times I get so into my plan I forget to look at other things in different ways. I would have mounted that box on the tongue frame for the shunt after you brought up battery water checking, but didn't bring PVC cement. CURSES! I agree, it would have been the more "complete" install, but as it is I think it will function well. I do want to bring some bigger heat shrink or wire loom to protect the shunt though.
    I did some math on the longer solar charge wires you mentioned.
    At full current (20A), 2ft wires drop .08V while 12ft ones drop .48V
    As the voltage rises and current tapers, that will drop to only .048V at 2A
    But a good thought nonetheless.
    Can't wait 'til the NEPA rally.
  6. shelmily
    3,252
    237
    Jun 7, 2012
    Ok, Pat I stand corrected. I sure thought that would have taken a lot longer to go that way. I just checked, and google is telling me about 35 minutes longer with traffic. One thing I didn't think of is how I have to loop around to get on 87 when leaving the park, you just shoot straight up and get on 90. But still not that much of a difference.
    By the way I will be needing some of that beer, some how, some way. [:)O]:D
  7. shelmily
    3,252
    237
    Jun 7, 2012
    And realistically she is never going to see 20A, especially in Vermont. I am lucky if I see 4 to 5 amps when I use mine up there and that is peak, not constant.
  8. JimmyM
    2,206
    444
    Jun 5, 2014
    Franklin, MA
    I peaked at 8-9A in VT with a 160W while I was chasing the sun just to see what I could get.
    I want to try it with my solar suitcase.
  9. stefie19
    stefie19 Active Member
    905
    180
    Aug 21, 2014
    Connecticut
    Renogy 100w Portable Panel w/Controller
    Is this what I should be looking to get if we were to get one? What else would I need in addition to this and the cable that you gave us Jimmy? Any kind of adapter to make it compatible to our pre-wire ZAMP outlet?
  10. JimmyM
    2,206
    444
    Jun 5, 2014
    Franklin, MA
    That's the one. It looks like it might use an Anderson PowerPole connector per the questions. That's not waterproof nor is it the accepted connector for solar products. However, you're going to need extension wires too. You can buy them pre-built. But they're not quite as good as "rolling you own". Good copper wire, that's flexible is sort of expensive. But good Ancor Marine wire is still pretty flexible.
    Pre-built: 10ga, 20ft - Extension wire Mike described these as China Gauge wire. I tend to agree. That's pretty cheap for 40ft of 10ga wire with connectors. But they should be servicable for 40ft at 100W
    Roll your own: Significantly more expensive, but will probably not be noticeably better on just a 100W panel.
    Connectors: MC4 connectors
    MC4 wrench: MC4 Wrenches
    Wire: Ancor marine wire. Buy as much as you want, but for 10awg, I'd stick to 40ft MAX. That's 80ft total wire.
    What sort of flexibility do you want? How far do you want to put this from your camper chasing the sun?
  11. JimmyM
    2,206
    444
    Jun 5, 2014
    Franklin, MA
    Also, that wire I gave you IS the adapter that will plug into your Zamp connector.
  12. JunkyBurrittos
    JunkyBurrittos Active Member
    278
    53
    Mar 18, 2017
    Central MA
    It was so nice meeting everyone this weekend. Thank you Steph for organizing such a great not-a-rally! Thank you also to Dave and Chris for offering set-up help and to Mike for the generous sharing of a lighter (Really, who camps without a lighter?). Finally, thank you to everyone for abstaining from rating my unbelievable back-up skills (Yes, that's the word I'm choosing to use). You were all gathered with a front row seat to the atrocity and I know I looked like I was out craft beer tasting all day rather than merely driving to the campground. Really I'm a towing shark and I'm just going for "most improved" at a later rally. :cool:[put&pu]
    Looking forward to seeing you all in Maine!
  13. JimmyM
    2,206
    444
    Jun 5, 2014
    Franklin, MA
    You missed the travesty that was my attempt to back in. I stopped counting after 4. And got myself so screwed up that I took a hot lap of the campground to get things straightened out.
    JunkyBurrittos and jnc like this.
  14. stefie19
    905
    180
    Aug 21, 2014
    Connecticut
    Right now, the only time we camp without power is the VT Rally but in the future, I hope that changes. Especially if we do a trip west someday. But since this is our first foray into solar, I'm ok with not buying the top of the line stuff and will upgrade should the time come when we'll become more dependent on it and will want higher quality.
    So the solar panel that I linked and the extension wire that you linked should get us up and running when we see you all in PA?
  15. JimmyM
    2,206
    444
    Jun 5, 2014
    Franklin, MA
    Yup!
    stefie19 likes this.
  16. Debfmaine
    Debfmaine Member
    30
    Jan 18, 2017
    Raymond Maine
    We got home around 3:30. We hit wind and rain, and at one point going over the Berkshires we had snowy rain or is it rainy snow? Thanks Steffie for hosting the not a rally Rally. It was so fun being with our camping family. Jimmy, thanks for the use of the flash light so I could find my way back to the camper. Can't wait for the PA rally. The weather wasn't the greatest but a rainy day camping beats a good day at work any time. It's a good thing I love you guys, you should of seen the pile of work I found on my desk this morning. But it's always worthwhile to be with you all.
    I hope we didn't scare off the new comers. Hey guess what Dave is doing .....that's right watching a hockey game. Gunner and I are upstairs.
  17. JimmyM
    2,206
    444
    Jun 5, 2014
    Franklin, MA
    We drive through that same slushy mess. Ugh.
  18. JunkyBurrittos
    278
    53
    Mar 18, 2017
    Central MA
    Go Bruins!
    jnc likes this.
  19. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    Any New Englander worth his salt is glued to the Bruins. Right now I'm watching them on the TV & computer while I'm play here.
    BigTap likes this.
  20. JunkyBurrittos
    278
    53
    Mar 18, 2017
    Central MA
    Thank you Jimmy. I feel better knowing I’m in such good company. :) I just felt like it was a pretty straightforward set up and I should have gotten it with one try... nope!
