2019 SW-PA Spring Rally Ohiopyle SP 5/3-5/5
Discussion in 'Rallies Being Planned' started by phager76, Nov 4, 2018.
  1. RockyRoo
    6,492
    82
    Jun 8, 2012
    Check the gas cap. Might neither not be on right or the seal might be bad
    WVhillbilly likes this.
  2. Dusty road
    Dusty road Active Member
    775
    87
    Feb 28, 2016
    Conneaut, Ohio
    John, when I have a picture or a file that's too big send, I screenshot it and send the screenshot. Works most times.
  3. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    Have the camper packed except the fridge.
    John that evp check engine light does nothen if it lights up. No downgrade of the engine controller, justs lets you know it does not meet the EPA requirements. Most of the time the manufacture does a test every so often. My toyota sienna it check it when the gas gauge hits about 1/2 tank. there are two valves, it closes and opens. It expects and increase in RPM and the gas fumes get sucked into the intake manifold or no increase in RPM. there are 2 valves one at the manifold and one at the charcoal canister that opens up to let fresh air pass through the system sucking out the gas fumes. So it could be a gas cap, hole in a line, gas tank, etc...
  4. phager76
    phager76 Active Member
    487
    77
    Dec 1, 2013
    Monongahela, PA
    This^ I never worry about EVAP codes unless it's time for inspection.
    I was going to close up the pop up today but a downpour rolled through an hour before I got off work. Hopefully tomorrow will be a little better and I can close it then. Otherwise we'll close it up, wet or dry, before I pull out on Thursday.
    I did take the Excursion to add air to the tires, out some gas in it, and run by the self serve car wash to clean off a year's worth of grime. Took $10 in quarters just to rinse that behemoth, didn't even get to the soap phase. Meh, still looks a lot better than it did.
  5. crosbys2008
    crosbys2008 Active Member
    776
    108
    Sep 2, 2013
    Erie, PA
    John, the evap tests usually occur ever x number of cold starts. I.e the 10th time you start the truck up from it being cold it runs the test. Every manufacturer is different, but the computer is not constantly running the evap test. Usually nothing to worry about unless the light is flashing, then you need to worry.
    Rob
  6. crosbys2008
    776
    108
    Sep 2, 2013
    Erie, PA
    So what’s everyone bringing for the potluck? We will be doing cheesy potatoes in the Dutch oven.
    Allergy reminder, Sarah is allergic to nuts so if you’re bring something with nuts just let us know.
    See everyone one Friday.
    Rob
  7. phager76
    487
    77
    Dec 1, 2013
    Monongahela, PA
    Meatballs and chili (two dishes, not mixed...eww) here.
    Trailer is all hooked up and ready to go, just need a cooler s couple of kids and a dog and we're good to go. Planning on leaving here around 1pm should be there by 2-2:30
    crosbys2008 likes this.
  8. vagov
    vagov Well-Known Member
    4,046
    259
    Aug 13, 2012
    Pittsburgh, Pa
    found the problem with the truck, replaced the purge valve, but it was still leaking, (junk advance auto parts) . replaced with OM GM purge valve from dealership, and the pesky little yellow light is OUT. also installed a tonnue cover, figured it,s best since I am going to PAT,S rally. (HEHE) I am working tomorrow until 2pm. so expecting to roll in somewhere around 5ish. who knows I may even beat Sally and Andy there?
  9. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    Joyce said she will bring a cake, mac n cheese and biscuits.
    Getting the camper ready so we just head out tomorrow morning.
  10. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    GPS address of campground:
    Just check out ohiopyle web site for an address for the campground. There was no campground address, just the HQ address in town. Did a little searching and found an address that get you on the campground road.
    400 Kentuck Rd., Ohiopyle, PA. The brown signs should work from there.
  11. vagov
    4,046
    259
    Aug 13, 2012
    Pittsburgh, Pa
    if you pass the white water kayak rental in the middle of the town just come up the road alittle and climb the BIG hill to your right, at the top of the hill you can make a left into the campground.
  12. phager76
    487
    77
    Dec 1, 2013
    Monongahela, PA
    We made it here safe and sound. Someone is in your spot Rob, I'll sic the dog on 'em if they ain't gone by sunup :D
    Rhi and Gwen have probably asked me a hundred times when James and Samantha are going to get here. Beautiful evening, I hope the weather cooperates the rest of the weekend, although there will probably be a little rain throughout. I think I'm going to start blaming Crystal, since it's great today, but some storms tomorrow last I looked. And she gets here tomorrow, clearly the rain follows her and not me!
    Can't wait to see you all tomorrow!
    crosbys2008 and WVhillbilly like this.
  13. WVhillbilly
    WVhillbilly Well-Known Member
    525
    357
    Jun 6, 2018
    WV
    Hope you guys have great weather and a fun weekend.
    phager76 likes this.
  14. Salandrew
    Salandrew Active Member
    115
    58
    Apr 27, 2016
    Bolivar, PA
    John, we made it Thursday evening! Granted it was dark, but we are here. And of course 11:25 and the rain starts. Hopefully it will be done by morning.
    We are making potato soup for the pot luck. Andy and Adam have to go deliver mulch all day Saturday, so I wanted something easy.
    See everyone tomorrow!!!
    phager76 and crosbys2008 like this.
  15. crosbys2008
    776
    108
    Sep 2, 2013
    Erie, PA
    Working a 1/2 day today (which will probably feel like a whole day, usually does) and hope to be on the road no later than 2 which will get us there around 5:30 - 6. Hopefully the rain will be nice to us.
    Pat, it’s not very nice to try to push the rain Blame onto Crystal. Just saying. ;)
    Sally and Andy, if when you arrive during day light hours we really do suspect you are not who you say you are. :)
    See everyone this evening.
  16. vagov
    4,046
    259
    Aug 13, 2012
    Pittsburgh, Pa
    working half day myself, (hopefully) got absolutelty nothing done yet at home, but kath is off today , told her to go the grocery store, basically throwing a cooler, some clothes , and alittle pile of firewood in the truck . and maybe the bicycles. that's it, what I DONT HAVE, I DONT NEED!
  17. phager76
    487
    77
    Dec 1, 2013
    Monongahela, PA
    I thought that was a powerstroke I heard rolling in around 9! Sorry I didn't get a chance to seeing by, the kids (and me) we're beat and turned in early.
    Yeah Rob, I guess it was out of line, especially since it started raining off and on all night. Guess it is me :D
  18. vagov
    4,046
    259
    Aug 13, 2012
    Pittsburgh, Pa
    just finishing up work now, been feeling sick as a dog all day , if I can mustard up some energy when I get home to pack the truck I will still be coming up tonight, otherwise I may get a good nights rest and be up early in the am. either way I'm still coming.
  19. phager76
    487
    77
    Dec 1, 2013
    Monongahela, PA
    Feel better, John!
  20. phager76
    487
    77
    Dec 1, 2013
    Monongahela, PA
    Crystal just got here, and sure enough it started raining! My theory is holding up @crosbys2008 [:D]
