70's model Atwood brake rebuild
Discussion in 'Tires / Brakes / Bearings / Axles' started by desert_indian, Jul 20, 2018.
  1. desert_indian
    desert_indian New Member
    Jun 22, 2018
    Good afternoon. I need to look into rebuilding my 70's era Atwood surge brakes.
    My question is weather or not rebuild kits are available for the master cylinder. You can see in the pics that it was pretty much a mess when I got the cap off. The rubber plunger is basically melted. I'm open to just replacing it, if a direct replacement is available.
    Ill probably need new wheel cylinders also, but the lines are in good solid shape.
    Looking for advice on how to handle it if I can't rebuild/replace.
  2. SteveP
    SteveP Well-Known Member
    1,176
    248
    There should be a part number cast or etched into the side of that master cylinder. Contact etrailer.com to find a replacement. You may need to provide measurements, length, distance between bolt centers, etc.
    From the looks of that master I would go ahead and replace the wheel cylinders. Rust in the fluid will cause leaks.
    desert_indian likes this.
  3. desert_indian
    Jun 22, 2018
    Thank you Steve. I will replace the wheel cylinders as well. I hope eTrailer has what I need. I was going to check with Napa also.
  4. desert_indian
    Jun 22, 2018
  5. Raycfe
    14,240
    1,017
    Boy that sure looks like early 60's Ford master cylinder.
  6. joet
    3,992
    671
    I would also check Eastern Marine. They cater to the boat trailer folks and a lot of boat trailers use hyd. brakes.
