86 coleman savannah rear panel
Discussion in 'Miscellaneous Repairs & Maintenance' started by htgls2000, Mar 13, 2018.
  1. htgls2000
    htgls2000 New Member
    19
    May 29, 2013
    Has anyone even remove to rear panel? Having problems with the camper popping up and want to inspect the workings in the back but not sure how to get panel off. Looks like so rivets to drill out and tail lights but after that I'm not sure. Thanks
  2. jnc
    I would Start underneath there is a sheet metal plate covering the whiffletree. I have seem many of these full of mouse debris and yes you will need to drill out the rivets to get the body panel off. I think you dont have to mess with the taillights just disconnect wires in the back of panel once you can get back there.
  3. htgls2000
    19
    May 29, 2013
    thanks for the info, I did check the whiffletree and it's ok, I will try removing the panel when this weather warms up a little.
