93 Coleman fleetwood axle flip
Discussion in 'Tires / Brakes / Bearings / Axles' started by Mojeb, Aug 27, 2018.
  1. Mojeb
    Mojeb New Member
    18
    Aug 14, 2018
    93 Coleman fleetwood grandview. It’s a long shot but does anyone own one of these ?
    I’m looking to do an axle flip and wondering what size tire I can go up go. Would be nice to hear from someone that has already done it. Currently has 20.5x8x10
  2. joet
    3,561
    515
    You should be able to go to a 13 inch tire
  3. Mojeb
    Mojeb New Member
    18
    Aug 14, 2018
    Also, I realized my axle is the 1 7/8 but it doesn’t seem to be a straight axle . Looks like it curves slightly up.
    All the kits I see are for 2 3/4 or bigger . Hmmm
  4. joet
    3,561
    515
    The axle is arched upward in order to maintain proper tire camber. When moving the axle make sure the arch is still facing up. Tractor supply has 1 7/8inch spring saddle's. You will have to measure your u bolts. If the pup has brakes, the saddles will have to be welded as the axle will rotate when brakes are applied
    Matt Benoit likes this.
  5. Matt Benoit
    Matt Benoit Active Member
    302
    162
    Jul 30, 2017
    Warren, MI
    Joet said it perfectly. Wait until after you do the lift, then measure for tires. I agree, 13in wheels will probably fit.
  6. ezakoske
    ezakoske Active Member
    462
    46
    Nov 30, 2014
    Escondido, CA
    Since you mentioned the axle arch, it's important to reiterate that axle "flip" is not an accurate description...it's better described as a spring over axle conversion.
  7. Mojeb
    Mojeb New Member
    18
    Aug 14, 2018
    Yup correct , I guess for straight axle a flip would work .
