A/C Shroud
Discussion in 'Heating / Cooling Systems' started by COL Tom, Aug 1, 2018.
  1. COL Tom
    COL Tom New Member
    Jul 30, 2018
    I bought a used Viking and the A/C shroud has a hole and crack in the cover. I figured no big deal, how much can a piece of plastic cost! After looking on-line, I found that piece of plastic costs about $200!!! WTH? Isn't there a PUP graveyard somewhere that sells pieces parts?
  2. Rik Peery
    Rik Peery Well-Known Member
    489
    375
    Jun 15, 2018
    Virginia
    Is it patchable temporarily? Duct tape(various colors)/Super glue/Great Stuff have been my little friends for years until I can obtain a more permanent fix; oft times I'll keep the patched product in reserve once the new part is installed...
  3. Sneezer
    1,420
    451
    I see them all the time on Craigslist. May have to keep looking to find one that matches your model .
  4. PopUpSteve
    PopUpSteve Administrator
    18,367
    1,268
    Dec 22, 2002
    Malvern, PA
    Popupparts.com may have what you need.
  5. Raycfe
    14,376
    1,069
    They do dry out and get brittle over time. They are on the most unprotected part of the camper.
  6. Sjm9911
    3,294
    1,537
    Glue , screw and patch what you have!
  7. nineoaks2004
    6,626
    2,581
    Graceville, Florida
    I always (even when new) put 2 flat straps on the top of mine, I match the holes that I drill to the holes on the shroud and replace the 4 nuts on the studs coming thru the top. I have also placed a piece of wide flashing under the straps (if needed) The shrouds have a habit of coming off while on the road. I once tried fiber-glassing the top but the Fiberglass did not hold.
  8. tcbrady
    tcbrady Member
    85
    24
    Apr 30, 2018
    Central Pennsylvania
    Yikes! What brand/model do you need the shroud for? I'll have an extra for a Dometic brisk air 2 in a week or two...
  9. Gfunk
    Gfunk New Member
    18
    Jul 14, 2018
    I got cracks on the front of our shroud also starting around the bolt holes. I put a fiberglass patch on inside on the cracks. Then bought a piece of aluminum bar stock from lowes that was about 2" wide and 1/16" thick, drilled holes in it bolted that on top of the shroud to help spread the pressure. Seems to have worked.
