A/C Smells Funny
Discussion in 'Heating / Cooling Systems' started by Handy, Feb 25, 2008.
  1. Handy
    Handy New Member
    Jan 9, 2008
    We have been camping a few times this winter... Running mainly the furnace as well as the heat strip in the A/C unit. However, on a couple of days, we needed to run the A/C during the middle of the day to cool off the camper. When doing so, the camper would always smell musty. I have cleaned everything on the inside of the A/C, but it still smells.
    Is there anything on the outside unit that needs to be cleaned?? Also, Is there any maintenance that needs to be done on the outside unit??
  2. Pete
    Pete Member
    171
    May 17, 2007
    Lubbock Texas
    Hello Handy. I had my inside cover out yesterday to install heat strip. I saw that the ducts inside are lined with some sort of insulation. If it got wet at some time it could have molded and cause a musty smell. Also if the evaporater which is on the inside has buildup on it and gets moist it may cause a musty smell when in use. Most of the time it happens if water can not run off properly.Hope this helps.
    2002 Dodge Caravan
    1997 1224 Starcraft Spacestar
  3. Handy
    Handy New Member
    Jan 9, 2008
    I was thinking of cleaning the inside and outside coils, much like you would do on your home unit, too see if that would help.
  4. Pete
    Pete Member
    171
    May 17, 2007
    Lubbock Texas
    It might not hurt to clean outside but i would concentrate on the inside.
    2002 Dodge Caravan
  5. Micksc
    Micksc New Member
    138
    Jan 5, 2008
    Aiken, SC
    Handy, it's possible that algea (sp?) have built up in your condensate drain under the Evap. coil. You can eliminate it with algeacide or bleach solution, but that may harm your canvas. If you can run some hot water thru the drain it should clear it up.
    Mick
    Me'42
    DW'42
    00 Coleman Cheyenne
    03 Iszusu Ascender
