A/C unit
Discussion in 'General Camping Discussion Forum' started by JHOP, Jun 14, 2018.
  1. JHOP
    JHOP Active Member
    148
    96
    Oct 6, 2017
    This is our first long trip in the pup and 2 days into the trip, an electrical cable fell from the ceiling. It looked like it had been taped up. We followed it and turns out it's to the a/c unit. So, looks like that was aftermarket. No problem but, what's the best/most appropriate way to reattach the electrical cable to the pup?
  2. nineoaks2004
    5,710
    2,016
    Graceville, Florida
    Whatever you do it must collapse when letting the top down. A fabric cover is some times used. I had one that had the wire on the ceiling and a plug installed on the roof, I hooked a cord to that and ran it to the pedestal 20 amp service.
  3. soft 17
    soft 17 Active Member
    237
    101
    Mar 14, 2017
    San Luis Obispo
  4. chambo
    chambo Active Member
    352
    106
    Apr 27, 2015
    Southern California
    The cord hanging down doesn't necessarily mean it's an aftermarket unit. A lot of the OEM ACs have a cord that is not wired into the PUP. This is so you can run the AC off it's own 20a breaker at the power pole and isolate it from the rest of the electrical systems.
    As far as reattaching it goes- glue? sticky squares/zip ties?
  5. Sjm9911
    1,996
    796
    Mine has a strip like that that terminates at the side by the door, the cord is run through it. It is then bunched up for storage and attached to the roof . To plug it in you have to unwind the cord , and plug it into the 20 amp outlet by the table in the camper. It was installed like this from the factory .
  6. Orchid
    Orchid Sharp Shootin' Grandma
    It's supposed to be like that. Not aftermarket. Attach to the roof with cable clips. They are where the coaxial cable is in Walmart.
    Sjm9911 and JHOP like this.
  7. jmkay1
    3,725
    805
    Mine is exactly like that. When Im done using the AC I roll up the cord and just behind the valance is some velcro. Keeps everything neat when not using it. Although my cord really is not long enough to go outside to the power box so I'm stuck plugging it in inside. I just have to remember to use a different circuit for everything else.
  8. JHOP
    JHOP Active Member
    148
    96
    Oct 6, 2017
    @jmkay1 we have to plug inside too, so we turn it off when running the hair dryer (family of all women and 1 man)
    I'll look into the cable clips. For the time being, duct tape is holding it up on the wall.
  9. Sjm9911
    1,996
    796
    Jmkay1, I made a heavy duty extention cord so I could use it in my driveway while working on it. Could be an option.
