A/c
Discussion in 'Heating / Cooling Systems' started by Rodney Bozzell, May 27, 2019.
  1. Rodney Bozzell
    Rodney Bozzell New Member
    May 27, 2019
    I bought a 2003 Rockwood Freedom 1940 Ltd pup camper plug in my 30amp plug recepticals work but a/c doesn’t there is an additional plug outside beside my 30amp plug but is a female end could this be for the a/c
  2. BikeNFish
    BikeNFish Well-Known Member
    2,558
    1,520
    Apr 24, 2017
    Maplewood, MN
    My pup does not have AC, but it is AC ready. Mine has a plugin for an AC under one of the bench seats. Check to see if your AC is plugged in and check to see if the GFI has been tripped.
    I hope this helps. Be patient. Others are sure to chime in soon.
  3. WrkrBee
    WrkrBee Well-Known Member
    1,907
    710
    Welcome to the Portal from South Carolina. Pictures and punctuation would help us.
  4. GreyFox
    GreyFox Well-Known Member
    966
    436
    Oct 10, 2018
    S Ontario
    A/C isn't installed by the trailer manufacturer but after the fact by a dealer, owner, tradesman, etc, so the A/C could be wired any which way, correctly or not. Without pics, who knows how yours was done?
