Ac blows air but not cold air
Discussion in 'Heating / Cooling Systems' started by SamanthaB, Aug 30, 2018.
  1. SamanthaB
    SamanthaB New Member
    Aug 30, 2018
    Just bought a 2006 Fleetwood pop up. Has roof ac that blows good but the air is not cold. Any one have any suggestions?
  2. xxxapache
    2,702
    727
    I would check the capacitor.
  3. WrkrBee
    WrkrBee Well-Known Member
    1,727
    628
    Welcome to the Portal from South Carolina. It may need the Freon checked, at its age.
  4. tenttrailer
    3,078
    252
    Jul 18, 2013
    Thornville, OH
    It can be several things. First it needs power from the thermostat (the dial). Next it checks that there is freon pressure (very low pressure it will not turn on) via a low pressure switch. If pressure is above some low threshold it sends power to the compressor and cap. Can you hear the compressor kicking on?
    The capacitors would be the first thing I would check.
    Can you hear the compressor kicking on?? If it kicking on an stays on its mostlikly low freon.
  5. xxxapache
    2,702
    727
    Most RV AC units do not have ports to check the refrigerant.
    Sjm9911 and Orchid like this.
  6. Orchid
    Orchid Sharp Shootin' Grandma
    4,959
    1,621
    May 8, 2011
    Florida by way of WV and MD
    Agree. Closed system.
  7. joet
    4,122
    710
    RV systems do now have charge ports. No way of knowing how much refrigerant is in the system. Ports can be added. Neither do they have low or high pressure cutoff's.
    Can you hear the compressor kicking on? or running? Might be worth having someone who does HAVAC look at it
