AC kicked out
Discussion in 'Heating / Cooling Systems' started by bduck40, Jun 21, 2019.
  1. bduck40
    bduck40 Member
    71
    Aug 4, 2012
    Just set up camp this evening. Turn AC on and working fine. Wife plugged hair dryer into same outlet as AC and breaker blew. Thought ok, just reset breaker and everything will be ok. Did that but still no power to the outlet. Any suggestions? Is breaker bad.
  2. xxxapache
    2,740
    759
    Did the breaker at the post trip also and you are running lights on the battery and haven't realized it?
  3. Blackripley
    Blackripley Member
    99
    63
    Jul 21, 2018
    Goleta Ca
    Is the outlet a GFI or is it on a GFI chain check the other outlets? Do you have power in the other 120v outlets? If not check the main breaker.
  4. bduck40
    bduck40 Member
    71
    Aug 4, 2012
    Outlet is not GFI. Other outlet are GFI and are working.
  5. tzmartin
    tzmartin Well-Known Member
    874
    321
    Sep 9, 2015
    Strange. I have two circuits. One 20amp outlet that the AC plugs into and 1 15 amp circuit that power three other outlets. Is the breaker switch staying in the on position? It could be that the breaker needs to be flipped all the way off then flipped back on. If that doesn't fix it then my guess is the breaker is bad.
    Orchid likes this.
  6. bduck40
    bduck40 Member
    71
    Aug 4, 2012
    Yes mine is the same way on breaker that is 15 which 2 plug in and fridge is on, the othe a 20 that the Ac plugs into. It tripped when it went out, tried to reset many times but still nothing. Breaker does act loose some as if it does not reset. So don’t know if it has always been like that or something new
  7. Orchid
    Orchid Sharp Shootin' Grandma
    5,124
    1,791
    May 8, 2011
    Florida by way of WV and MD
    Same as mine. It would be impossible to plug anything into the same outlet with the a/c.
    @bduck40 , are we talking about a roof mount a/c or a portable unit? Really just curious because of the way you described the plug as being a double. Also, I use my blow dryer every day of every trip, for a long time, with the a/c going full blast and never had anything blow. The only combination that doesn't work out in our camper is the toaster oven and microwave at the same time. That throws the breaker every time.
  8. tfischer
    tfischer Well-Known Member
    3,318
    843
    May 21, 2014
    Haha a blow dryer is something we've never brought camping, even when we do have shore power (which isn't typical).
    Blackripley likes this.
  9. SteveP
    SteveP Well-Known Member
    1,308
    311
    Did you flip the breaker off before resetting?
    bheff and theseus like this.
  10. Orchid
    5,124
    1,791
    May 8, 2011
    It's mandatory for me, wherever I go. My hair will frizz if left to it's own devices. I wish my hair knew I was camping and would cut me a break.
  11. tfischer
    3,318
    843
    May 21, 2014
    We turn into the mountain family when camping lol. Appearances go out the window, and we're OK with that :)
    Orchid and xxxapache like this.
  12. xxxapache
    2,740
    759
    Exactly^
    A hat, visor, scarf, doo rag, head band or whatever is all you need camping.
  13. Orchid
    5,124
    1,791
    May 8, 2011
    Y'all have clearly never seen my natural hair, after being washed. [LOL]
    Even so, when my kids were growing up, we never camped with any hook ups. Actually, there were not many campgrounds that had them at that time, at least not state parks. I made do then by keeping my hair in a tight braid. Now that I have all the modern comforts, I take full advantage of them. :smiley:
    Back to @bduck40 's a/c outlet. I would really love to see a picture, or at least know what type of unit it is.
  14. Sneezer
    1,438
    469
    What kind of camper? Year/make/model?
    On mine I have a dedicated outlet for the A/C. It happens to be in a cabinet and the cord goes through the counter, but there is a double plug in there, set to the 20 amp breaker. I plug my PS4 and TV into it when we camp, no issues, but I wouldn’t do a hair dryer in the same outlet.
    I have a couple breakers in the box. If you don’t have a strong spring resistance when popping it back in place to reset the breaker may be bad.
    Since this happened on Friday - did you get ti figured out?
