AC Placement
Discussion in 'Roof/Floor Repair & Maintenance' started by sawdusty, Mar 14, 2018.
  1. sawdusty
    sawdusty San Antonio
    863
    33
    Nov 9, 2014
    San Antonio
    I am finally going to start my new roof build next month and have begun drawing plans and getting the remainder of new parts which includes and AC. I need some help to determine the best placement of the AC. Bracing is not an issue since I am building from scratch, but thinking more about the placement that will insure good circulation. Any thoughts on this?
  2. BikeNFish
    BikeNFish Well-Known Member
    1,186
    683
    Apr 24, 2017
    Maplewood, MN
    I don't have A/C in mine, but if I did want to put in A/C , my main concern would be headroom clearance since I am 6' tall.
    sawdusty likes this.
  3. cabranch47
    cabranch47 Member
    38
    Nov 29, 2016
    One thing that I always wondered about is why do the manufacturers not raise the A/C mounting area up, even 1/2". This would eliminate potential leakage from just the foam gasket sealing to a surface as flat as the surrounding area. I think that if I built a roof for my PU I would make a frame around the opening, where the gasket seals and raise it up above the surrounding roof. Seems like it would be much harder for water to find it's way inside.
  4. theseus
    theseus Centerville, OH
    2,532
    264
    Feb 6, 2007
    Centerville, OH
    If I was building from scratch I would place the A/C in the dead center so it can blow evenly to both ends of the camper. I would also consider putting in an spot for a Fantastic fan or something similar near the kitchen.
    I think they don't due to the weight of the outside unit. Also while towing it would be more likely to put stress on the roof if it wobbled any on the raised area.
    Some A/C units have a thinner inside unit. For instance, my current doutherm's inside unit is at least a half inch shorter then the Coleman I had in the previous camper. If head space is a worry, this is something that could be considered.
  5. silvermickey2002
    4,191
    131
    Sep 11, 2008
    Morris County, NJ
    We have the Coleman Mach 8 low profile unit. On the ceiling the unit only comes down maybe 3 inches. It's also lighter than most units, only weighs 90 lbs.
    It is located dead center of the roof. There is a A/C brace on both sides of it.
  6. sawdusty
    863
    33
    Nov 9, 2014
    San Antonio
    I plan to make the roof with an arc so that dead center is higher than the ends. So do I place the AC dead center or offset to the street side?
  7. theseus
    2,532
    264
    Feb 6, 2007
    Centerville, OH
    I have seen them like that before. It would work.
  8. SteveP
    SteveP Active Member
    983
    181
    The roof on my Jayco is slightly domed, maybe 1 or 1.5 inches. The AC is offset to the street side so it's not directly over the aisle of the camper. I agree with theseus about adding a place for a separate roof vent, powered or not.
  9. sawdusty
    863
    33
    Nov 9, 2014
    San Antonio
    Sorry, but I have edited my question to make it grammatically correct. Dead center or offset toward the street side?
  10. xxxapache
    2,413
    536
    I would think that having the AC offset would make the lift arms on the closer side work harder and possible lean over time.
  11. theseus
    2,532
    264
    Feb 6, 2007
    Centerville, OH
    I think you are right.. that's why you don't see many like that. But there are some with the A/C offcenter.
  12. jnc
    I think weighing each side of the pup would be helpful. Than you could even out the weight with the placement of the AC. This will help keep it from wanting to sway.
  13. xxxapache
    2,413
    536
    You have to wonder if a AC unit shifted over to the side would act like a rudder at interstate speeds and cause the trailer to tow diffently.
  14. jnc
    xxxapache I personally dont see that happening. If it was true than all the lids, vents, AC's and so on that is on every other camper out there would do the it.
  15. xxxapache
    2,413
    536
    Yeah, but none of those lids and vents are as big as an AC.
  16. jnc
    I know I have seen many AC units not centered.
  17. xxxapache
    2,413
    536
    I don't recall seeing one other than a pic in here a while back.
  18. xvz12
    xvz12 Well-Known Member
    583
    263
    Apr 6, 2017
    New Plymouth, ID
    I'm a big fan of bilateral symmetry....if i were to mount one on our pup, I would put it dead center, & reinforce the roof accordingly.
    sawdusty and xxxapache like this.
