Adding electronic brakes to a 1998 Coleman mesa camper
Discussion in 'Tires / Brakes / Bearings / Axles' started by Filip K, Apr 17, 2019.
  1. Filip K
    Filip K New Member
    26
    Jul 10, 2018
    Has anyone converted the 1998 Coleman mesa camper to electronic brakes? Past few trips in the Poconos I feel like our van is taking a heavy strain on the brakes and would like to add electronic brakes to the trailer before towing it again for safety. Just wondering if anyone successful converted their trailer successfuly. I am concerned that add a drum might push the tire out to far which would cause rubbing around the exterior body that the tire sits behind.
  2. Muller 5
    Muller 5 Active Member
    299
    116
    Jan 6, 2019
    STL
    I'm having my mechanic look at adding brakes to my 99 Palomino. He says it might need a new axle, but he also said I have no suspension at all.
  3. Filip K
    Filip K New Member
    26
    Jul 10, 2018
    My axle is attached to leaf springs but i am worried about that the hubs might push the wheels out to far and hit exterior skin of trailer. Etrailer has for like 400 bucks axle and brakes that you can slap on yourself but i dont have any time for more DIY
  4. Raycfe
    14,407
    1,072
    The position of the wheel/rim is usually same with just hubs or drums. I installed 7 inch brakes on a trailer and it exactly the same.
  5. Filip K
    Filip K New Member
    26
    Jul 10, 2018
    Is there a way to tell what size drums you need to install for example 7" vs 10" or is all that based on trailer weight?
  6. Raycfe
    14,407
    1,072
    12 inch wheels or less will use 7 inch brakes. 13 to 15 inch. will use 10 inch brakes. (3500lb. axle)
  7. Rusty2192
    Rusty2192 Well-Known Member
    791
    278
    Jul 30, 2014
    Kentucky
    I added brakes to my small Dutchmen. First thing to check is if your axle has the backing plates to mount the brakes. If it does adding the brakes is an easy job that can done with basic hand tools. If it doesn’t, you’ll have to either have a trailer shop weld plates on or replace the axle with one that has them.
