Adhesive for vinyl/plastic to plywood?
Discussion in 'Roof/Floor Repair & Maintenance' started by mprowland, Apr 20, 2017.
  1. mprowland
    mprowland New Member
    Apr 17, 2017
    I currently have a 2009 Palomino Yearling with a rotten (roof)end and side board. I'm replacing the rotten OSB with plywood. I'm going to use the existing covering which is a thin vinyl or plastic type material. The existing glue seems to work great as it's very hard to scrape all of the rotten OSB off of it. I just have no idea what they used. What type of adhesive or glue would be best for mating these two surfaces together? Thanks for any input...Mark
  2. giadiep
    giadiep Active Member
    212
    68
    Sep 5, 2015
    Syracuse, NY
    It may be contact cement such as the stuff they use to stick laminate to plywood to make countertops. I'm not entirely sure, but it should work.
  3. mprowland
    Apr 17, 2017
    Ahhhh, makes perfect sense. I'll probably go with this unless I hear otherwise. Thanks for responding!
  4. inthedirt
    inthedirt Active Member
    840
    66
    Aug 28, 2012
    SW Montana
    3M 4200 if you ever want to separate the two pieces again. 3M 5200 if you want to make the repair permanent.
    spygirl likes this.
  5. mprowland
    Apr 17, 2017
    Wow that's expensive! I imagine I'll need at least a few tubes if I'm going to do half the perimeter of a 12' box. Thanks!
  6. inthedirt
    840
    66
    Aug 28, 2012
    SW Montana
    I use it exclusively on my boat to make permanent repairs while installing new fishing and electronic equipment. Last thing I need is a leak in my boat.
  7. Halford
    Halford Well-Known Member
    2,609
    140
    Sep 28, 2011
    Santa Clarita, California
    Yes, a friend of mine who is a cabinet maker, he uses 3M to spray under laminated piece and also on plywood. When both are dry to touch, attach the laminate piece on the plywood quickly... you may not have 2nd chance to adjust the piece. do it right at first application.
