Advantage of heavier axle and bigger wheels and tires?
Discussion in 'Camper Pre-Purchase Questions' started by epcotisbest, Apr 30, 2019.
  1. epcotisbest
    epcotisbest Active Member
    103
    59
    Feb 12, 2019
    So besides a little bit more ground clearance and a bit more cargo capacity, are there other advantages to getting a camper with a 3000lbs (vs. 2500) axle and 14" (vs 13") wheels and tires?
    I am considering a new Aliner and their off-road package is available for a reasonable price. It just includes the axle and wheel/tire upgrade.
    Do bigger tires help the camper tow any better or track straighter or improve the ride in any way? I like the idea of the heavier axle and bigger wheels/tires, but will probably never go off-road, so the extra ground clearance does not really matter.
    Will the same model camper with the addition of the off-road package make any difference in regular use?
  2. Shaman1
    Shaman1 Well-Known Member
    1,996
    412
    May 13, 2011
    Oklahoma City, Oklahoma
    I prefer the ability to be off road, but for usual road & campground camping it probably won't matter.
    epcotisbest likes this.
  3. Dingit
    Dingit Well-Known Member
    741
    317
    Mar 8, 2017
    I had to flip the axle on my Fleetwood just to get it up the driveway. We mostly go to NFS campgrounds and they usually aren't paved so the few inches we added help there as well.
    I suspect Aliners are a lot more nimble than a 14' tent trailer but a little clearance is always good. Fuel economy will be slightly less I suppose, and tires might be a few bucks more, but it'll be worth it. Do it!
    Extra cargo capacity can be a big deal. My popup's axle is close to capacity with nothing on board. It concerns me slightly. :(
  4. BillyMc
    BillyMc Well-Known Member
    674
    272
    Mar 25, 2018
    Larger diameter tires are better for highway speeds. If you ever have to work under it you will like the extra room.
  5. WrkrBee
    WrkrBee Well-Known Member
    1,898
    703
    I would hope that the frame is stiffer for the 3000lb axle. Should be less flex that causes screws loosening, door alignment issues, etc. I don't understand Aliner offering the two axles that are rated so close together. They should just put the 3000 axle under everything.
  6. Yacoma99
    Yacoma99 Member
    36
    23
    Mar 25, 2019
    I currently have an Aliner Ranger 12 with the off road package. I previously had a Coleman Utah and Sante Fe, neither of which had an off road option. Both of my other pups occasionally bottomed out on rough roads. I know that is not comparing apples to apples but I like having the extra ground clearance. I have towed my Aliner over some ugly stuff (that our government call an interstate) and have not had any worries.
  7. mandinga
    mandinga Member
    148
    Mar 4, 2014
    Ottawa, ontario
    I have an off road pop up with cargo platform. It has a 4550lb axle giving me 2200lbs of cargo capacity. I never have to worry about over loading it. I boondock often, and some of the very small ditches I crossed caused my previous non off road popup to bottom out. Last year, my buddy came to join us, he tore off a stabilizer and his step on a rock that I had cleared no problem.
    Having the extra room under the camper is also great for working on things underneath without needing to jack it up. I can slid things underneath at the campsite when it rains.
  8. epcotisbest
    103
    59
    Feb 12, 2019
    Maybe they view it as a marketing thing. It has kinda worked for me, thinking the upgrade will probably be worth the money, when in reality it probably would not have increased overall retail price a lot by going ahead and making the 3000lbs axle standard instead of optional.
    Now, in looking around, I am not finding any of the model I am interested in stock within reasonable driving distance with the off-road package option. Several available with standard axle and 13" wheels and tires.
    No real time frame on when one could be special ordered, and the few dealers I have talked to are not real interested in spending much time with us small camper buyers when they have customers waiting to spend $50 to $100 thousand or more on a big fifth wheel, Airstream or motorhome.
    What to do, what to do? Buy standard now or hold out till next season to special order the one I think I really want?
  9. epcotisbest
    103
    59
    Feb 12, 2019
    Good to hear from someone who has made the choice I am contemplating. I am looking at a Scout Lite because we like how compact and simple it is. Something that small and light might benefit from the off-road package.
  10. epcotisbest
    103
    59
    Feb 12, 2019
    Both good points. Thank you.
  11. epcotisbest
    103
    59
    Feb 12, 2019
    Had not thought about extra space underneath to store stuff. Good idea. Coolers, supplies etc... could get out of the rain.
  12. Dingit
    741
    317
    Mar 8, 2017
    Oh...see if it'll make a difference for where you store it. Without the rooftop AC, you're probably fine, but with some popups, it's possible to get too tall for the garage.
  13. PopUpSteve
    PopUpSteve Administrator
    18,544
    1,392
    Dec 22, 2002
    Malvern, PA
    You know, I have a Someset E2 with 15 inch tires, it's an Off Road model. Whenever I get behind another PUp like a Coleman Columbia (which was my first camper) I think "My God, look at those tires, they look so skinny". [LOL]
    I love my [PU] [put&pu] !
  14. msbrown253
    msbrown253 Mike in CT
    251
    Jul 12, 2013
    Any trailer benefits from larger tires. It reduces friction and heat, thereby increasing their durability and lifespan. They also typically have a higher weight capacity per tire. Even if the ground clearance doesn't matter, and you only tow it on smooth pavement, I would personally opt for the largest tire option available. I needed to replace my axle, springs, hubs, everything on my boat trailer last summer. I went from a 14" to a 15" for just this reason. (Then got a blowout the first time I towed it, damned Murphy's Law! Tire shop agreed it probably had a defect in it and replaced without question). It did raise my trailer a bit, which affected launching and recovering the boat, but it wasn't a big deal. Just had to back in a little further.
  15. Ken Lane
    Ken Lane Active Member
    127
    74
    Apr 16, 2019
    Knoxville TN
    I have an off road model from Flagstaff. I noticed that I have to raise the ball on the TV to try and get the trailer level for towing. I think if you have a raised vehicle like a Tacoma TRD the receiver height would be perfect. With my ball on the TV at 18" I am still not close to level. That was with a 2" rise, I am going to try an 6" rise next.
