Another Weight Distribution Question
Discussion in 'Tow Vehicles, Hitch & Towing' started by chartle, Jul 24, 2018.
  1. chartle
    chartle New Member
    26
    Apr 18, 2018
    Pgh, PA
    OK so I've pulled my 3,500 lb TT on 2 trips and besides having to stop for gas every 2 hours [:(!] it accelerates, stops and pulls fine with just the sway bar.
    But here is my issue, the rear end of our Jeep squats a bit. We are just at all the limits for needing one. My Jeep Manual says I need one over 3,500 lbs. and my front is just about at 1" higher than the back.
    Every time I think I have one picked out I would see an issue but figured them all out except one.
    I've looked at the Husky Centerline and the CAMCO ReCurve R3 both with the proper ball size* and built in sway control and the Husky Lightweight Pin Trunnion Bar where I have to install my own ball and reuse my sway control.
    Ok here is my issue my TT is really low, the frame is about 11" off the ground. Now my Jeep is not lifted at all and I use a draw bar with a 2" drop and I think it should probably be one or 2 inches lower.
    All the WD hitches have hardly any drop at all. The ones I've looked at are like 6" rise and 1" drop. Am I just missing something?
  2. xxxapache
    2,545
    610
    You need an adjustable shank.
    Something similar to this:
  3. chartle
    chartle New Member
    26
    Apr 18, 2018
    Pgh, PA
    Yea I looked one up for the Camco and it was another 100 bucks.
    Are the "dropier " draw bars universal?
  4. xxxapache
    2,545
    610
    Yes, the hitch heads bolt on the adjustable shanks.
    I have an old school trunnion style WD hitch, an adjustable shank and a 50 buck Curt sway bar. It does a fine job with my 6500 lb TT and 40 year old low tech TV.
  5. generok
    generok Well-Known Member
    2,235
    393
    Feb 7, 2013
    Anchorage, AK
    So, depending on the head/ball mount for your model WDH, you should be able to flip the shank over to get drop or rise. But there's a range there. You will need to adjust the angle of the head (usually a process of adding washers to a bolt in the head) and then tighten the heck out of the head to the shank. (I use a breaker bar with a 5' length of Unistrut).
    Like you said, with only 1" of rise in the front, you're on the ragged edge. I get 1" of difference with my WDH (but without it I get 2.75"). I can eliminate that with some load bearing springs in the back, which MAY be a cheaper option for you to reduce the squat.
    https://www.etrailer.com/susp-2014_Jeep_Grand+Cherokee.htm
    Best of luck.
