Anyone add a lift kit to their Aliner?
Discussion in 'A-Frame PopUps' started by razcob, May 12, 2018.
  1. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    I am considering adding a lift kit to my 2012 Ranger 12, because I plan to take this on moderate off road trails. The kit lifts the frame a nearly 3 inches, but am not sure if it is worth the effort. The additional height may be beneficial, but I was wondering if anyone has lifted theirs and developed any handling issues.
    Also, if anyone has a Ranger with an 'offroad' package, did they add a lift or is it a different axle from the factory?
    https://www.etrailer.com/Accessories-and-Parts/Dexter-Axle/K71-723-01.html
  2. rcaldwel
    rcaldwel New Member
    17
    Jan 21, 2014
    Lifted Aliner with Dexter 3" kit and new 3500 Lb. dexter axle with 24 Degree angle
  3. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    rcaldwel,
    I have a 2000 lbs, AL-KO axle, and this company was bought out by Dexter. Did you replace your AL-KO with a Dexter?
  4. Chloe
    Chloe Active Member
    131
    27
    Jun 16, 2017
    Massachusetts
    We have a Ranger 12 off-road and I believe it’s a different axle because it’s rated for 3000 lbs (vs. 2500 lbs on the standard). The wheels are 14” (vs. 13”). Tires seem pretty rugged, too.
    Look here: http://aliner.com/wp-content/uploads/2016/06/Aliner-Comparison-Grid.pdf
    Rik Peery likes this.
  5. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    I understand the axle is 3000 lbs, but does it have a 'c' channel piece of steel lifting it?
    A picture of one side of the axle would be greatly appreciated.
  6. Chloe
    Chloe Active Member
    131
    27
    Jun 16, 2017
    Massachusetts
    Does this help?
  7. rcaldwel
    rcaldwel New Member
    17
    Jan 21, 2014
    Yes. It is a Dexter axle 3500 lb. with a 24 degree down angle
    bob
  8. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    Thanks Bob and Chloe for the pic and the information on the degree angle!!
    That is the axle I want.
    You have been helpful, but do you know the part number for that axle?
  9. Chloe
    Chloe Active Member
    131
    27
    Jun 16, 2017
    Massachusetts
    Here’s the sticker on it:
  10. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    Chloe, thanks for the picture, but the serial number is at the bottom of the sticker, which isn't visible.
    On all Dexter OEM trailer axles produced after April 2001 there is a nine digit number which can be found near the center on the rear side of the axle beam. Look for the words 'DEXTER AXLE' and the serial number (lot #) will be located directly under the name.
  11. Chloe
    Chloe Active Member
    131
    27
    Jun 16, 2017
    Massachusetts
    Oh, of course... lol.
    They put the sticker on upside down and wrapped to the top, making it super hard to photograph.
  12. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    Thank you!!!
  13. rcaldwel
    rcaldwel New Member
    17
    Jan 21, 2014
    For the 3500 lb. dexter axle I oordered from
    theoempartsstore.com
    and the order was:
    10TF35-545E-EZ 3500 Lb #10 Torflex Axle 5 on 4.5" Electric w.EZ Lube
    Bob
  14. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    Thanks, great information. The listing says it comes with brakes, but not springs and hardware.
    What parts did you need to make it complete?
  15. rcaldwel
    rcaldwel New Member
    17
    Jan 21, 2014
    It is complete, these are torsion axles and bolt right into existing holes. It did come complete with 10" brakes and drums. Just bolt in and wire up to existing brake wiring.their website and customer service walks you through the measuring and ordering process.
    razcob likes this.
  16. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    Thanks, you saved me many phone calls.
    Did you add bigger tires?
  17. rcaldwel
    rcaldwel New Member
    17
    Jan 21, 2014
    Goodyear Endurance 205 75R 15
  18. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    I guess it depends on where you live, but how much was freight?
    Something must be wrong. I entered my information and freight is $9.95. Reading down further, it does say actual freight
  19. rcaldwel
    rcaldwel New Member
    17
    Jan 21, 2014
    razcob
    you might try etrailer.com as well. I think you might get better pricing.
    Bob
  20. razcob
    razcob Member
    91
    Jan 4, 2018
    Powhatan, VA
    I checked with etrailer and they don't sell these axles.
    rcaldwel, I am looking to lift the camper 3-4 inches. You mentioned that you have a 24 degree down, the current offers are 22.5 and 45 down. How much extra lift did you get, and how did you know prior to ordering the 24 degree that this was the lift you wanted to achieve? My current axle is 0 degrees.
