Anyone Use An Instant Hot Water System?
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by jwh92020, Nov 17, 2014.
  1. jwh92020
    jwh92020 Member
    224
    Aug 24, 2014
    I'd like to have hot water at the sink but I don't want to go with a water heater. Any reason i couldn't use an instant system such as this:
    http://www.insinkerator.com/en-us/Household-Products/Water-Products/Pages/Model-Hot1.aspx
    It draws 4.3 amps, 115v. If I had a separate cord running to the 20 amp service, it should work, shouldn't it? As for the plumbing, that wouldn't be too hard to set up. Any thoughts?
  2. RotnMom
    RotnMom Am I there yet?
    4,125
    Apr 4, 2011
    I never used water in my PUP because I came up camping with water jugs. Now we have a TT and when I filled my tank on the first run, I totally forget the water heater filled up and I could have done dishes anyway. What I DID do, and did in the PUP, was use my coffee pot. 12 cups of hot water goes a long way!!
    Also, Coleman makes some nice table top units and they're MUCH cheaper than the unit you're looking at. Check it out...
    https://www.google.com/search?q=coleman+instant+hot+water&oq=coleman+instant+hot+water&aqs=chrome..69i57.4955j0j4&sourceid=chrome&es_sm=0&ie=UTF-8
    Happy camping!!
    [:D]
  3. colorado_camper
    colorado_camper Member
    852
    Apr 14, 2011
    Denver, Colorado
    We use a Coleman HWOD and love it. We use it for dishes, showers, inside the PUP and out. It does not need to be plugged or plumbed in because it runs on a rechargeable battery. We use it boondocking just the same as in a CG. We put it on charge each day while the sun is pounding on our solar panel and it is always ready to go. I bought mine used on CL, it was 3 years old then and I've had it for 3 years since; still running on the original battery. Can't beat it, IMO.
  4. jwh92020
    jwh92020 Member
    224
    Aug 24, 2014
    I think the link took us to a more expensive unit. The one I was looking at is $125 @ Home Depot. The Coleman looks interesting. I'll have look at it more in depth. We just want the hot water for dishes, hot chocolate, things like that. DW is not a boon docker, so we will always be somewhere with showers, but portable hot water could come in handy.
  5. West Coast Canuck
    1,623
    37
    Mar 3, 2005
    Can't beat the coleman hot water on demand...I have 2 of them, bought the second new one on sale for $149.00. Works very well.
  6. shelmily
    shelmily Well-Known Member
    3,209
    216
    Jun 7, 2012
    Northeast Pennsylvania
    I used to have a portable on demand propane heater (Ecotemp L5) I used when I had our old pup. I had added a second water inlet port to the outside of the camper, so I had both a hot and cold feed. I also installed a residential faucet at the sink. It was inexpensive, and worked really well.
    Robert1951 likes this.
  7. ChocoChock01
    4,019
    Mar 7, 2012
  8. wraenking
    wraenking New Member
    112
    Nov 10, 2005
    We have these below in our construction trailers. Seem to work fine. I think they are Bosch units. May work well with pups
  9. wecamp
    wecamp Member
    152
    Sep 28, 2006
    Grosse Pointe Park, Michigan
    We have something similar at home. It does not make enough hot water for us to do dishes using the 3 pot method. I have thought of put one in our HTT but am concerned about winterizing it. Not sure I want to have anti freeze in it for 4 or 5 months.
  10. swordfish
    swordfish Well-Known Member
    2,204
    31
    Sep 27, 2010
    That is a pretty neat setup. Where did you get the stand for the water heater?
  11. shelmily
    3,209
    216
    Jun 7, 2012
    I made it. It's a piece of 1" perforated square steel that I welded a plate on the bottom of. Drilled a few holes to drive stakes into the ground. The heater has two keyhole slots on the back of it to hang it. I used two smaller carriage bolts on the stand that the heater hooks on to. That way I can easily remove the heater for storage.
  12. Racerm305
    Racerm305 New Member
    Feb 20, 2015
    We just bought our first pup and were planning on adding an ecotemp inside. Our kids 7, 4, & 2 did not care for cold or luke warm campground showers. I was going to add a pump and larger tank to the pup. Then try to figure out how to construct a shower stall. Do you have any suggestions or warnings?
  13. ChocoChock01
    4,019
    Mar 7, 2012
  14. jerry_ma
    jerry_ma Member
    735
    Oct 25, 2012
    We have the coleman too with all the accessories.
    We use it for hot water and shower duties along with the 2 room shower tent.
    I have the adapter that allows me to connect it directly to the water supply which is a big plus :)
    Jerry in MA
  15. Jetent2
    Jetent2 New Member
    Oct 17, 2018
    Indiana
    Love the ideas, I have a portable shower heater could work?
  16. phoodieman
    phoodieman Active Member
    764
    70
    May 18, 2009
    Hutto, Texas
    Ecotemp worked for me. You can use green bottles or #20 tanks. It will scald a dog. You do need a minimum of 40 LBS water pressure to make it work though.
    Phoodieman
  17. silvermickey2002
    4,384
    240
    Sep 11, 2008
    Morris County, NJ
    We have a Coleman HWOD unit. It's works great and I got a sprayer for it to do those large pots. But the one thing that I have noticed is when we use it on really cold trips it will run for a minute or so and then shut down. We are talking 25 degrees or lower. I don't think the battery likes those cold temps [?:~{]
